Jeff T Posted October 5, 2021 Share Posted October 5, 2021 Hi all, I just purchased a new Iwata Air Compressor, and it comes with the black coiled rubber air hose, I have only ever used the braided type on my old one, my question is, are these black coiled ones better for air pressure, or is there no difference? Cheer's, Jeff. Link to comment Share on other sites More sharing options...
Woody V Posted October 5, 2021 Share Posted October 5, 2021 I'd say it's a matter of personal preference. Personally I don't like any coiled air hoses because of their constant tugging. I have an Iwata braided hose that I bought over 40 years ago and never had a problem with it. ivanmoe and MikeC 2 Link to comment Share on other sites More sharing options...
Jeff T Posted October 5, 2021 Author Share Posted October 5, 2021 Thanks for your input Woody!....I agree, the coil ones seem as though they will be a bit of a headache when using them, its just that I read somewhere that they were narrower, and therefore gave better air pressure, but how high do we need for what we do anyway?...I'll stick to the braided one, just wanted to see what others thought that may have used both. Cheer's, Jeff. Woody V and MikeC 2 Link to comment Share on other sites More sharing options...
Panzerwomble Posted October 5, 2021 Share Posted October 5, 2021 Can't speak to IWATA specifically but generally the larger diameter hose the better for airflow , hence control air more at the gun and not at the compressor, although this advice is more from my 1:1 scale spraying , MikeC, monthebiff and Woody V 3 Link to comment Share on other sites More sharing options...
Jeff T Posted October 6, 2021 Author Share Posted October 6, 2021 Thanks for the input Panzer!..good to know. Cheers, Jeff. Link to comment Share on other sites More sharing options...
Neo Posted October 6, 2021 Share Posted October 6, 2021 The only think ive read about coiled hoses is that i helps reduce pulsation in tankless compressor. But i have no idea if thats true or not. I use braided hose on a compressor with small tank Link to comment Share on other sites More sharing options...
Buster99 Posted October 9, 2021 Share Posted October 9, 2021 I have been using clear aquarium air pump hose for years. The clear tubing is very cheap and when used in sufficient length will help in reducing fluctuations in air pressure and will also show any moisture that may be present. I typically use more than 3 meters (3 yards). Jeff T and Greg W 2 Link to comment Share on other sites More sharing options...
Jeff T Posted October 9, 2021 Author Share Posted October 9, 2021 Thanks Buster!..good to know. Jeff. Link to comment Share on other sites More sharing options...
STM Posted October 6, 2022 Share Posted October 6, 2022 I have used straight Badger rubber air line hoses since the 1970's and they work fantastically well. I have one that I have had since I started airbrusing back in the mid 1970's and it still works perfectly. Link to comment Share on other sites More sharing options...
