upor Posted November 18, 2020 Share Posted November 18, 2020 Lemkits 1/32 Ilyushin Il-10 " Beast " – Limited edition resin kit - on sale https://www.ebay.com/itm/124446188698 https://www.ebay.com/itm/114527073145 http://lemkits.com/.../1-32-ilyushin-il-10-beast-limited.../ Out2gtcha, Rockie Yarwood, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
upor Posted November 24, 2020 Author Share Posted November 24, 2020 control build result, Lemkits 1/32 Ilyushin Il-10 " Beast " & La-11 "Fang" Rockie Yarwood, dutik, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
Kagemusha Posted November 24, 2020 Share Posted November 24, 2020 Looks great, very much looking forward to getting my hands on the kit. upor 1 Link to comment Share on other sites More sharing options...
dutik Posted November 25, 2020 Share Posted November 25, 2020 Very clean and nice build How did you attach the wings to the fuselage? The wings are hollow, so there is only a small contact area for the glue. I have concerns about the rigidity of that joint over times. Did you somewhere add some kind of a wingspar or wire pins? Regards - dutik upor 1 Link to comment Share on other sites More sharing options...
upor Posted November 29, 2020 Author Share Posted November 29, 2020 (edited) On 11/25/2020 at 6:57 PM, dutik said: Very clean and nice build How did you attach the wings to the fuselage? The wings are hollow, so there is only a small contact area for the glue. I have concerns about the rigidity of that joint over times. Did you somewhere add some kind of a wingspar or wire pins? thanks), just glued, when using high-quality CA and technology, you can't tear it off. Well, considering that the assembled model weighs only 240 grams, that's enough. To be sure, you can add some elements screwed to the end rib on the fuselage parts, which will go into the wing cavity. Edited November 29, 2020 by upor Anthony in NZ, Kagemusha and dutik 3 Link to comment Share on other sites More sharing options...
dutik Posted November 29, 2020 Share Posted November 29, 2020 Thank you very much! Most resin kits are heavy casts. I was not aware that your kit is that light Should cause no problems here, indeed. Regards - dutik upor 1 Link to comment Share on other sites More sharing options...
