LSP_K2 Posted December 14, 2018 Share Posted December 14, 2018 After being given this kit by a friend some time back, my first thought was to use the parts to finish my already well underway ceiling queen of the same kit. After thinking on it a bit though, I've decided instead to go ahead and do it up as a contest machine, to be entered in our local September 2019 show (and possibly some other shows in the region). Out2gtcha and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 14, 2018 Share Posted December 14, 2018 Sweet........I'll be following along, as I do so love the Rufe LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 I had initially considered the Vector or CMK Sakae engine as a replacement, but really couldn't convince myself that I needed the additional expense, so decided to just go box stock with the provided engine. Here it is, painted with titanium (it's what I had easily accessible) and given a dark wash. Some dry-brushing and painting of the gearbox, will improve it sufficiently for my needs. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 Pretty much the only AM that I've grabbed for it so far, is the Aires 'pit, which in itself is a nice little upgrade. So far, the fit seems OK, but I'll take whatever time is necessary to ensure the best fit possible. Out2gtcha and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 Dolly is all assembled and painted, but not yet weathered. Main float is approaching the painting stage too. Out2gtcha, LSP_Kevin and Alain Gadbois 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 14, 2018 Share Posted December 14, 2018 This kit is a fun little build! Did you add any weight inside the forward float? The model's a tail-sitter without it. Kev LSP_K2 and Out2gtcha 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 1 hour ago, LSP_Kevin said: This kit is a fun little build! Did you add any weight inside the forward float? The model's a tail-sitter without it. Kev No, that's something that I completely forgot about, Kev. I may just glue it to the dolly, then the dolly to the base, not real sure yet. I may also do as I did with my 1:24 kit, just bore a hole in the float front, fill with epoxied B-B's, then plug the hole. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 14, 2018 Share Posted December 14, 2018 Just now, LSP_K2 said: I may also do as I did with my 1:24 kit, just bore a hole in the float front, fill with epoxied B-B's, then plug the hole. That's what I did on my build of this kit, as I'd completely forgotten about it too! First, I drilled a couple of large holes: Then, I shoved in as many lead fishing sinkers as I could, and filled the cavity with resin: Worked a treat! Kev Alain Gadbois, Out2gtcha, LSP_K2 and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 That looks excellent, Kev. Out2gtcha and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 One thing that will perhaps help me here, are the decals that are included in the Kagero book, as several versions are included. LSP_Kevin and Out2gtcha 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 Wing floats mostly ready to go now. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 Engine now dry-brushed and gearbox painted. As far as I'm concerned, it's ready to be installed. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 14, 2018 Author Share Posted December 14, 2018 My drill made short work out of opening a hole in the main float that I can now dump some weight into. LSP_Kevin and Out2gtcha 2 Link to comment Share on other sites More sharing options...
dennismcc Posted December 14, 2018 Share Posted December 14, 2018 Looking good, I'm going Japanese at the moment so will tag along. Cheers Dennis Out2gtcha and LSP_K2 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted December 15, 2018 Author Share Posted December 15, 2018 Front of main float now loaded with B-B's, all super glued into place. Gazzas, LSP_Kevin, Alain Gadbois and 1 other 4 Link to comment Share on other sites More sharing options...
