Hubert Boillot Posted February 26, 2018 Share Posted February 26, 2018 I found it! http://forum.largescaleplanes.com/index.php?showtopic=52804&hl= Thierry Unfortunately, most of this thread has been « photobucketted » Hubert Link to comment Share on other sites More sharing options...
wunwinglow Posted February 26, 2018 Share Posted February 26, 2018 (edited) To Photobucket. Verb. Vulg. May be used as an expletive. To provide a valuable service that becomes relied on by many people, and then withdraw the service without warning, in a manner that not only destroys vast amounts of vital research, but also puts the providers business in dire peril. Edited February 26, 2018 by wunwinglow Harold, Tony T and thierry laurent 3 Link to comment Share on other sites More sharing options...
Tony T Posted February 27, 2018 Share Posted February 27, 2018 I should never have called them Pukebucket. Seriously, the Trumpeter Fresco kits are so outrageously cheap that few need fear practising surgery. Tony Link to comment Share on other sites More sharing options...
thierry laurent Posted February 28, 2018 Author Share Posted February 28, 2018 Indeed and if you want to correct at least part of the shape issues you must be ready to saw, cut, grind, sand, ...! At least they use a good plastic that is easy to work with. Martinnfb 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted February 28, 2018 Author Share Posted February 28, 2018 Why should I said I am nearly afraid to have a look at the kit...? The ailerons shape is also erroneous. Two changes may improve the look without correcting all the dimensions issues. First, remove a section of 3mm out of the pointy end close to the wing fence to glue it to the wing. Then, cut 3mm (at the trailing edge) of the wing tip to lengthen the other side of the aileron. Not perfect but already far better. T. Martinnfb and Kagemusha 2 Link to comment Share on other sites More sharing options...
