BloorwestSiR Posted May 2, 2014 Posted May 2, 2014 So, here it is; my first entry into this GB. I didn't realize I had so many choices in my stash. It figures that I choose the hardest one there. The base kit: Contents: The replacement fuselage: Man, has resin come a long way since this came out. The rest of the conversion bits: Carl Girlscanplay2 1
BloorwestSiR Posted May 2, 2014 Author Posted May 2, 2014 I don't think I have ever seen a thicker resin casting that wasn't completely solid. I have a strong feeling that this is going to be a tail sitter no matter what I do. The two fuselage halves weigh more than the rest of the entire kit, sprues and all. Following the instructions/recommendations from Belcher Bits, I glued the two halves together with Gorilla Glue epoxy and leave it until it sets: This is going to be interesting... Carl LSP_Paul 1
LSP_Paul Posted May 2, 2014 Posted May 2, 2014 I don't think I have ever seen a thicker resin casting that wasn't completely solid. I have a strong feeling that this is going to be a tail sitter no matter what I do. The two fuselage halves weigh more than the rest of the entire kit, sprues and all. Following the instructions/recommendations from Belcher Bits, I glued the two halves together with Gorilla Glue epoxy and leave it until it sets: This is going to be interesting... Carl Carl, When I looked at my set I thought to myself.. this is going to be more like Carpentry! What I started doing to mine is, wit ha dust mask, the vaccume running and my dremmel tool with a big and small sized sanding drum, start thinning out as much as the insides as you can get way with. It's the ONLY way to get the plane onto its nose gear, and you'l still have to add a TON of weight up front. YOU can do this! Just go slow! Looking forward to your most excellent choice of subjects starting to look like a plane! Paul Derek B and Girlscanplay2 2
BloorwestSiR Posted May 2, 2014 Author Posted May 2, 2014 Carl, When I looked at my set I thought to myself.. this is going to be more like Carpentry! What I started doing to mine is, wit ha dust mask, the vaccume running and my dremmel tool with a big and small sized sanding drum, start thinning out as much as the insides as you can get way with. It's the ONLY way to get the plane onto its nose gear, and you'l still have to add a TON of weight up front. YOU can do this! Just go slow! Looking forward to your most excellent choice of subjects starting to look like a plane! Paul Thanks for the vote of confidence Paul. I was thinking along the same lines but the only problem with that is my Dremel is banned in our house My wife says it causes too much noise in the house. Thankfully my compressor is virtually silent or I wouldn't even be allowed to airbrush. Either way, it's a big improvement over my previous building sessions. I might just mount it on a small base. Carl LSP_Paul 1
Derek B Posted May 2, 2014 Posted May 2, 2014 (edited) Carl, Great (and unusual) subject - you do pick some great aircraft. I have always liked the F-5A and want to make one one day. I have always liked the idea of making a conversion for the Hasegawa F-5E kit, but you have the Belcher set, which I hope will not give you too much grief as it looks a bit like a lot of work! Good luck Derek Edited May 6, 2014 by Derek B
LSP_K2 Posted May 2, 2014 Posted May 2, 2014 Interesting choice. I discovered last night that my Huey is going to need some counterbalancing too; it's way tail heavy.
marauderdriver Posted May 2, 2014 Posted May 2, 2014 Carl I have your tail-sitter solution,......... build it FLYING, couple of acrylic rods..... put the gear up..... or flaps down for landing. watch'in you jack
BloorwestSiR Posted May 6, 2014 Author Posted May 6, 2014 Carl, Great (and unusual) subject - tou do pick some great aircraft. I have always liked the F-5A and want to make one one day. I have always liked the idea of making a conversion for the Hasegawa F-5E kit, but you have the Belcher set, which I hope will not give you too much grief as it looks a bit like a lot of work! Good luck Derek Thanks Derek! I find it interesting that even though this is going to be a lot more work than the PR XI I just finished, I don't feel as frustrated. At least, not yet. The instructions even say it's rough and like Paul mentioned, carpentry skills will be needed. Now if that isn't a warning that this won't be a shake and bake kit, than I don't know what is. Carl I have your tail-sitter solution,......... build it FLYING, couple of acrylic rods..... put the gear up..... or flaps down for landing. watch'in you jack Thanks Jack, that might be an idea. But I'd have to find a suitable pilot figure to do so. Interesting choice. I discovered last night that my Huey is going to need some counterbalancing too; it's way tail heavy. Yeah, I just had to pick the unusual one.I hope the gear is up to if I do try to counterbalance it. Carl Derek B 1
BloorwestSiR Posted May 6, 2014 Author Posted May 6, 2014 A small update. The Gorilla Glue is set and after removing the tape and elastics, I have a very solid rear fuselage: The glue foams a bit as it cures which has the benefit of filling in any small gaps. The excess cleans up easily too. The instructions tell you to expect a mismatch at the rear of the fuselage and to just even it out afterwards.
BloorwestSiR Posted May 6, 2014 Author Posted May 6, 2014 Here's a comparison to the F-5E fuselage. You can see that it's not just a matter of a shorter fuselage. The instructions tell you to hollow out the rear end for the burner cans. They suggest using a 1/2" drill bit. I was lucky to have one as that is a sizable hole to drill. This GB got me to dust off another build and try to get it finished. Since it is well beyond the 25% started rule, I can't do a build thread for it but I thought I'd throw in a pic here: Derek B 1
LSP_Paul Posted May 6, 2014 Posted May 6, 2014 (edited) Excellent Progress Carl! The F-5C is going to look really really cool! Nice to see you get the Crusader back out too! Even though your F-8E cant be considered in the GB, please do continue posting pics and anything you find worthy of mentioning as far as construction with your build here. All the best, Paul Edited May 6, 2014 by av8shunmodels
Derek B Posted May 6, 2014 Posted May 6, 2014 (edited) Great work Carl - I think that I am going to have a look at my F-5 again as it one aircraft that I am always opening the box and putting away again, because I like looking at it, not because I don't want to build it. Cheers Derek Edited May 15, 2014 by Derek B
BloorwestSiR Posted May 15, 2014 Author Posted May 15, 2014 Excellent Progress Carl! The F-5C is going to look really really cool! Nice to see you get the Crusader back out too! Even though your F-8E cant be considered in the GB, please do continue posting pics and anything you find worthy of mentioning as far as construction with your build here. All the best, Paul Thanks Paul! The Crusader is an F-8C using the Fisher conversion set. I found the reason I stopped working on it. I thinned the front fuselage down to make the Aires cockpit fit and overdid a bit. The cockpit tub literally slid back and forth inside the fuselage. I've shimmed it with some card stock and that means I should be able to continue on with it. Great work Carl - I think that I am going to have a look at my F-5 again as it one aircracft that I am always opening the box and putting away again, because I like looking at it, not because I don't want to build it. Cheers Derek Thanks Derek, I actually thought about getting another F-5 kit to do as an E since my LHS has one in stock. But with my stash getting a bit big, I thought I should focus on what I have at hand. Carl
BloorwestSiR Posted May 15, 2014 Author Posted May 15, 2014 A small update for tonight. The instructions include a template on where to trim the wings so that they'll fit the new fuselage: It even shows the lower wing piece as well so you can trim both separately. Here's the port wing done compared to the stock starboard one: The curves at the wing tip are to accommodate the wingtip tanks. I've also started re-scribing the panel lines on the wings. I figure now is easier than when they're mounted to the fuselage. Carl Carl Derek B 1
