gunpowder Posted September 13, 2009 Share Posted September 13, 2009 Got this from Hannants on Friday. Great looking kit. The gun barrel troughs wre just naff indents , so i drilled them out and added plastic tubing. Then the ends were cut and sanded smooth. The front of the gunpack was also sanded to make it a little flatter as i feel it was a bit too curved. I also drilled out the vent holes. Still needs some work yet. Taped it all together. Looks good to me. Link to comment Share on other sites More sharing options...
Jack Posted September 13, 2009 Share Posted September 13, 2009 looks okay to me, and when compared to the Echelon issue (which by many is considered better than the Trump version) you did a perfect job correcting the front end of the "bulge" ..... Have a look at the picture enclosed..... J Link to comment Share on other sites More sharing options...
gunpowder Posted September 13, 2009 Author Share Posted September 13, 2009 Thanks! Heres the cockpit. On the whole i think its good. I have added a few scratchbuilt parts though. Link to comment Share on other sites More sharing options...
gunpowder Posted September 13, 2009 Author Share Posted September 13, 2009 It was pointed out to me that the strakes were a little off , so i decided to alter them. I had a photos of a flightpath strake. I got it on screen to the same size as the part , the chopped the trailing edge and added to the leading edge. Much better! I also moved the leading edge up the tank a little Link to comment Share on other sites More sharing options...
Azgaron Posted September 14, 2009 Share Posted September 14, 2009 Very nice work so far! Cheers, Håkan Link to comment Share on other sites More sharing options...
gunpowder Posted September 14, 2009 Author Share Posted September 14, 2009 Heres the basic cockpit tub. I know its not 100% accurate but its close enough fo me. Link to comment Share on other sites More sharing options...
DaveJ Posted September 14, 2009 Share Posted September 14, 2009 Very nice work! Link to comment Share on other sites More sharing options...
gunpowder Posted September 15, 2009 Author Share Posted September 15, 2009 Thanks Heres the IP. The white glue hasnt set yet so they look a bit white. You cant see too much of this once the coaming is on. Link to comment Share on other sites More sharing options...
Scotsman Posted September 15, 2009 Share Posted September 15, 2009 Excellent work so far - looking very impressive indeed Link to comment Share on other sites More sharing options...
Azgaron Posted September 15, 2009 Share Posted September 15, 2009 I agree, looking very good! Cheers, Håkan Link to comment Share on other sites More sharing options...
bcauchi Posted September 15, 2009 Share Posted September 15, 2009 That is a really nice pit. Great work so far. Link to comment Share on other sites More sharing options...
gunpowder Posted September 16, 2009 Author Share Posted September 16, 2009 Coaming all done. Fuselage is joined now and the gunpack fitted to the tank too. My main concern with this kit was the odd leading edge "kink". When i first looked at it in the box it appeared to be abscent. After assembling the wing , it is there albeit a bit vague. I think with some careful sanding it will become a bit more apparent. Link to comment Share on other sites More sharing options...
gunpowder Posted September 18, 2009 Author Share Posted September 18, 2009 Wings are on.....again. I have made a huge amount of work for myself by sanding that leading edge kink into the wing the wrong way round . I put the kit aside before i lost my temper and went back to the P-47. The leading edges are now back to how they should be , hence the filler and plasticard you can see. The filler on the wing/fuselage joint is really my own fault too after i pulled the wings off. Oh well im happier now so back on with the build. The only other problem now is shortening the main UC legs to get the model to sit right. I thing Trumpeter got this totally wrong with both Lightnings. They just sit too high. Heres an idea of what i cocked up Heres how i originally sanded it An heres how it is now. Honestly . what a dunce! Link to comment Share on other sites More sharing options...
theseeker Posted September 18, 2009 Share Posted September 18, 2009 Very nice pit! Rocky Link to comment Share on other sites More sharing options...
gunpowder Posted September 18, 2009 Author Share Posted September 18, 2009 Thank you Next i want get the undercarrage right before going on. As i said it sits too high on its original legs. Heres a photo I used the plastic legs to experiment with first. I cut a section out and reground the peg The results are much better. Looks "heavier" Link to comment Share on other sites More sharing options...
