LSP_Kevin Posted November 26, 2008 Share Posted November 26, 2008 Good work Butler. Looks like the wing sits a little aft compared to the plans though... Kev Link to comment Share on other sites More sharing options...
Butler Posted November 30, 2008 Author Share Posted November 30, 2008 Link to comment Share on other sites More sharing options...
Butler Posted November 30, 2008 Author Share Posted November 30, 2008 Edgar sent me a whole box of goodies including a fuselage, wings, canopy and some tailplane conversion parts so i'm in business now. I have to say that i'd already found everybody of this forum extremely generous with their knowledge and help, and this box from Edgar just tops it off! I've cut both fuselages along their length and glued the mkv top onto the mk22 bottom. The two kits are a near perfect fit, the only difference being the thickness of the plastic. The blue strips in the photo are dynotape - this holds the halves together a bit more securely than masking tape i've found. The fit between the two kits is so good that once glued, i'll keep the left and right parts separate and make them in the same way as the original model. Hope that makes sense!. For the wings i've decided to keep the Revel versions as I don't think they need much more work than any other wing, plus they have a nice 'solid' feel that makes scribing more pleasant! I've removed the wing tip and replaced it with the thinner mkv part (which fit with un-nerving perfection ) Link to comment Share on other sites More sharing options...
rotary Posted November 30, 2008 Share Posted November 30, 2008 your'e a game bird butler, iv'e got to give you that, and it looks like you've given this one a fair bit of thought. best of luck. dave. Link to comment Share on other sites More sharing options...
LSP_Ron Posted November 30, 2008 Share Posted November 30, 2008 Wow, quite a project you've started. Link to comment Share on other sites More sharing options...
Butler Posted December 21, 2008 Author Share Posted December 21, 2008 I've made a bit more slow progress with this in the last couple of weeks. I've made the cockpit quite basic with the addition of a couple of scratchbuilt bits, a bluetac seat cushion and some PE belts. The cockpit parts fit into the hybrid fuselage with no problems at all! Link to comment Share on other sites More sharing options...
Butler Posted December 21, 2008 Author Share Posted December 21, 2008 The cockpit is now safely enclosed in the fuselage halves. I haven't installed the cockpit floor (with control column) yet in case it gets damaged when sanding. I hope this picture shows the combination of parts here - the brown is Mkv, the blue is Mk22 and the yellow is a resin fin conversion part Edgar sent me (the grey is filler!) Link to comment Share on other sites More sharing options...
Butler Posted December 21, 2008 Author Share Posted December 21, 2008 One wing is nearly finished. I've added the cannon bulge and moved one cannon loction closer inboard. This wing also has it's radiator fitted and the bottom now needs scribing. This looks a mess because you can see some of the filled panel lines along with the new ones! I hope in the photo you can see that i've removed the revell wing-root panel line and moved it inwards. I'm doing one complete wing followed by the other. I know this is not the most economic way time wise, but I want to be able to see the differences between the two once one is finished! Link to comment Share on other sites More sharing options...
Butler Posted December 21, 2008 Author Share Posted December 21, 2008 Here's the same wing with a blow over of automotive primer and the original Mk22 wing alongside. I'm going to model the plane flaps-down; you can't see in the pic but the pop-up flap is open on the top surface of the wing. Hopefully this shows the panel lines a little clearer Link to comment Share on other sites More sharing options...
mattlow Posted December 21, 2008 Share Posted December 21, 2008 Wow Butler I reckon you're firmly in Russ territory here - both in terms of the 'hack and slash' style of this build and the relatively high speed at which you're performing the work. Great stuff and very entertaining as a watched build. Looking forward to seeing more of this come together. Matt Link to comment Share on other sites More sharing options...
Allok Posted December 21, 2008 Share Posted December 21, 2008 Good work, Butler. You're making it look easy! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 21, 2008 Share Posted December 21, 2008 Good work mate. It's nice to see such courageous builds. Kev Link to comment Share on other sites More sharing options...
Loic Posted December 21, 2008 Share Posted December 21, 2008 Excellent start on one cool project. Cheers, loic Link to comment Share on other sites More sharing options...
ruzlkampf Posted December 22, 2008 Share Posted December 22, 2008 Oh WOW, Oh WOW, OMG!!! I really must wander over into this area of the forum more often, I've completely missed this build. Butler,...you are The Man! This is exactly how I was going to try this conversion, using more of the Mk.22/24 parts than I did. How cool to see you trying this! Hurray!!! I didn't know squat about Spitfires when I started my conversion, so I ended up going down another path.(also didn't get reference material, or decent plans until I was 1/2way done. ) That was my first build here at LSP, and I shudder now that I realize how much 'cheek' I was showing even ATTEMPTING such a thing. I was such a 'shy young lad' then. he he Blast, if I wasn't going to be putting most of the Griffon nose on a P-51 racing Mustang, I'd have to try this again. Nice to know about the wing...I wish I knew then, what I know now about Spits and I would've used more parts. I'm actually thinking of retro-grading the parts I have left from my Mk.22/24 back into a MERLIN powered Spitty. Something like a MK.XVI, with a bubble canopy? Hmmmm. Looking real sweet on this build here, dude! Can't wait to see what you come up with next. Cool, Russ Link to comment Share on other sites More sharing options...
Butler Posted April 16, 2009 Author Share Posted April 16, 2009 Right - back to work on this I think! I'm currently working on the port wing in exactly the same way as before, only i'll open up the cannon bay. I'll post some pics once there's something to show Link to comment Share on other sites More sharing options...
