2,702 -
Days Won
78
Everything posted by chuck540z3
Tamiya F-16 Aggressor, Kicked Up a Notch- KLP Shout Out
chuck540z3 replied to chuck540z3's topic in Works in Progress
May 9, 2024 After many hours of picky, picky work, the main painting job is now over. Whew! I’ve never used so much masking tape in my life, as you’ll soon see. Before I start with the descriptions, I’d like to walk back some of my prior comments about the camo pattern on the tail as being “wrong”. Now that I’ve had a chance to paint the entire aircraft and compare it to several pics of the real deal, I found that about 75% of the masks are fairly accurate, another 20% or so are off a bit (like the tail) and 5% are just plain inaccurate, which is a good thing! If 95% of the masks arepretty good, that’s fantastic, especially on a camo-pattern that is so intricate and complex, with so many curved surfaces. The other comment I’d like to make about the masks themselves is that they are a good compromise of thin flexibility to conform to irregular surfaces while still being thick enough to be moved over and over again without losing their shape or adhesive. The painting instructions have you paint the top then the bottom. Since the bottom is white and the top is blue, I think it’s a lot easier to do it the other way around. After you have painted the radome and box beams with FS36251 (MRP-094) and any other antennae and other bits, mask them off with tape. As mentioned above, I went with pure White for the bottom, using MRP-004, which I hate. It takes at least 6-8 thin coats to cover, but it’s nice and thin and compatible with the other MRP paints I’m using. Note below that I didn’t load up the central areas with paint, since they will all wind up dark blue when the painting is finished. Apply the masks according to the instructions or “Maps” as they are called. Here you will want to have on hand some good reference pics, because it’s hard to figure out where the masks are supposed to begin and end. In a lot of cases, the wing edges or other prominent features dictate where they should go, so it’s easy. The 5 antennae at the front should be painted grey and masked off before you paint. The masks around the intake are by far the most complex and difficult to do, with multiple masks and many irregular surfaces to deal with. For ease of handling, I cut a few of the big ones in half, then spliced them back together with masking tape. The entire top of the intake remains white, so should be masked off completely using both the vinyl masks and tape. This takes a long time to do properly, but is well worth the effort when painted. The demarcation line between upper blue and bottom white is a straight line from the edge of the LEX to the nose cone. While the vinyl masks attempt to do this, you’re better off trimming them back and using masking to get a cleaner edge. Next step is to flip the model over and apply the light blue (FS35450, MRP-240). There’s no need to worry about masking the bottom, because that’s already been done (including box beams) and any overspray will be covered by the dark blue later. I painted the fuel filler door and dorsal antenna earlier, which were masked off first. Add the masks to the top side, which is a lot easier than the bottom. The only mask that was tough to do was the one over the gun, which is full of bulges, raised rivets and cavities. The masks on the canopy that I used have remnants that extend down onto the canopy sill. These were cut and retained earlier. To position them, I used the painted canopy as a guide to make sure they lined up properly if the canopy is closed. Next, paint the bottom with the dark blue (FS35109, MRP-238). Again, use several thin coats to avoid paint pooling and leakage under the masks. Then paint the top. Now the fun- and scary- part! Remove all the masks, other than the ones for the landing gear and cockpit. This reveals how well your masking and painting job worked, which in my case, worked out really well if I do say so myself. I expected quite a few errors and flaws and found that in general, 80% was as good as possible, 10% was “good enough” and 10% needed a bit of tweaking to make the overall paint job acceptable, as you will see below. With all that snow white plastic now gone, I can finally use a dark background to help show the details. I normally use blue, but with so much of that color already, I went with plain black. With the masks removed, I then painted the leading edges of the wing and “beer cans” with more FS36251 medium grey. That circular antenna on the top looks quite brown in this pic, but it’s really more grey in color and will get dirtied up a bit later. Here’s an example of the flaws that need fixing because they are noticeable with paint “blow-out” along irregular edges. One key thing I found when repainting these flaws was that you are far better off painting more dark blue over white than trying to paint more white to cover the blue, especially with MRP White. If the little blue rectangle is a bit bigger than the real deal at 1/32 scale, so what, it’s likely not the right size to begin with! The repairs. Did I mention I used a LOT of masking tape!? Overspray on the clean areas isn’t worth a few extra bucks of tape. The intake area had similar flaws on the other side. Overall, I had about 8-10 different repair areas over the entire model. I have a few pics that show that the gun opening is clearly grey and not blue, and about the same grey as the radome, so I painted it accordingly. Here’s an example of the 10% “good enough” flaws that aren’t worth fixing. On the bottom of the leading edge of the wings is a big gap, made even bigger by tilting the flaps up a few degrees, which creates an area that can’t be masked off properly. There shouldn’t be a gap of any kind on the real deal, so this is a case of just living with it, especially when it’s on the bottom that is rarely seen anyway. The Aero Mask instructions don’t tell you where Mask #20 and 24 go, which is here. I really like the engine nozzle collar I painted earlier next to the blue paint. With all of this complex masking and repairs, I can’t even imagine how I would paint the intake lip cleanly now, especially on the top where there's no clearance. Thankfully it’s already done! I have lots of flying pics that show these antenna are grey and not blue, hence the masking earlier. The instructions also have an error on the bottom, showing Mask #36 twice on Page 5. The rear ones are #32 (not 36) and 40, while #36 is right behind the wing. There was some discussion earlier about whether or not to use the Light Arctic Grey (FS36628, MRP-246) as the main color on the bottom as called for in the instructions, which is the same color on the port side of the tail. Here you can see why I went with pure white instead, because that grey is nothing like what I’ve seen with my own eyes in person. It was great to be able to paint the tail, horizontal stabilizers and brakes off the rest of the model for ease of handling. Here’s a couple of parting shots with them attached. When I first saw this paint scheme back in 2019 when it was new, I just knew I had to build it one day. So cool….. Next up is a good gloss clear coat of Tamiya X-22, followed by decals. I’m nervous using the Aero Mask decals which don’t look as good as I’d like, but thankfully I have at least 5 sets of Two Bobs Viper Aggressor decals to use as much as possible. Thanks for looking in. Cheers, Chuck -
Wow! So cool. You don't see a Viper that looks like this every day! Cheers, Chuck
Thank you Gents! Hi Neo! No worries about "hijacking" at all, because we're all here to learn from our shared experiences. From what I can see in your first pic, the ragged edges on your paint work is clearly due to the masks as you mentioned in a, "What you see is what you'll get", sort of way. My favorite masks are made from Kabuki tape, which is thin and adheres tightly to the model, reducing the chances of paint leakage underneath. Thin vinyl tape works well, but on more than one occasion I found that the adhesive reacted with the paint and dissolved a bit along the edges, creating a mess. These Aero Masks are thicker than regular vinyl masks, but the adhesive stays put and I haven't had any trouble with them so far. The adhesive is also evenly distributed so that you can burnish the edges down to create a tight seal, so I'm pretty happy with them, even if the camo pattern is a bit wonky here and there. They are certainly better than I could ever create on my own, so I really shouldn't complain. With so many tiny little squares in this digital paint scheme, paint leakage is a concern, but as mentioned above, this can be mitigated by doing the following: - Burnish down every single edge with a firm but flexible tool. I use plastic micro-brushes with the brush head cut off. They are firm, but won't scratch the paint. - Try to always paint at 90 degrees to the surface of the mask. This keeps the paint within the cutout areas, rather than sneaking underneath at an angle. - Use many thin coats of paint and don't let it get wet. While I usually paint with a good wet coat to keep the paint smooth, wet paint will leak underneath the masks into small recesses like panel lines, etc. - Use a paint that's thin, to help reduce raised paint boundary edges. - Use a paint that dries quickly and sets before it has a chance to leak underneath the masks. That's why I like MRP paints, which check off the last 2 boxes. While I also like Tamiya acrylics and lacquers, I find them a bit too thick for this kind of painting. Cheers, Chuck -
May 5, 2024 Painting begins! Since this “Ghost” camo scheme is so finely detailed, it will obviously be the focal point of the finished model, so I want to do as good of a paint job as possible. I would not have even attempted to paint this scheme if it wasn’t for the Aero Mask set, which generally does a very good job, as you will see below. One detail that I painted separately is the front intake lip, because it’s a lot easier to paint off the model than when it’s installed. While the fit of this lip is quite good as is, it does have some raised edges here and there, so I sanded it down accordingly before painting. The front surface is covered with a radar absorbent coating similar to the radome, so I painted it with the same medium grey color and several pics I have of my subject flying, shows that it has the dark blue paint on the bottom in a rectangular shape. I then carefully glued it onto the intake, trying to be careful to not have any glue ooze out and make a mess of the paint. The fit is really good after my prior sanding adjustments. I can now mask off the painted edges and the entire intake inside. I usually don’t use a paint primer, since the enamels and lacquers I use adhere to the plastic quite well without one. For this snow-white model which is hard to see flaws, however, I sprayed on a few thin coats of Mr. Metal Primer on the metal reinforcement plates and Mr. Surfacer 1200 on everything. A few blemishes popped out here and there, which were easily repaired. The “Box Beams” on the sides behind the wings have Radar Absorbent Material (RAM) on them and are not painted in the camo colors. These were painted with FS36270 Haze Grey as per the Aero Mask instructions, which is the same color as the missile rails and pylons. I also painted the Jet Fuel Starter (JFS) door with Alclad Stainless Steel, then masked it off. For my first camo paint task, I decided to start on the canopy to get it finished and out of the way. Other than the canopy latches, the bottom of the canopy is fairly void of detail, although it is missing the handles that are on either side. Thankfully the Aires cockpit set came with a set, which I thickened with thin CA glue before gluing them on, then painted the bottom flat black. The seam line on the canopy was removed in the usual way, with fine sandpaper and Tamiya polishing compounds. My subject has the tinted canopy, but the rear glass is clear. I also painted the interior of the canopy glass, which is easier to do without the frame attached, but masked off the sides where the two parts are glued together. Glued together, again being careful to not let any glue ooze out and harm the clear parts. The Aero Mask instructions call for the paint colors as shown below. I was surprised that they indicate the color used mostly on the bottom of the jet is FS36628 Light Arctic Grey, because I always thought it was White. More on that later. While we all have our favorite paints, I really like the MRP line which is tough to buy in Canada, due to no Canadian suppliers and our ridiculous ban on paints being mailed across the border. I get paint mailed to me all the time from Canadian suppliers, but if it comes from any other country, it’s against postal regulations. Stupid. In any case, this paint is perfect for the task at hand, because it usually covers well with thin coats and dries fast. The only color that I don’t like is MRP-004 White, which needs as many as 5-8 thin coats to cover. After masking off the canopy inside and out, I painted it with the light blue, FS35450, then applied the Aero Mask subsets #7 and 9, using pics I have of the real jet(s) to position them. This was where I discovered the following: · You need to paint in light coats and not allow the paint to get wet, which can wick under the vinyl masks down panel lines, etc. · The airbrush should always be positioned 90 degrees to the surface and not at an angle · Keep paint buildup to a minimum, to minimize raised edges · There are at least 3 F-16’s painted in this Ghost scheme, with the camo pattern generally the same · There are lots of subtle differences between each jet, where the camo pattern varies, so small changes will not be noticeable · While this Aero Mask set is for my subject, 84-1220, some of the patterns apply only to the other Ghost jets, 86-0299 and 84-1301 · There are a few places where the Aero Masks are just plain “wrong” for all 3 jets, which I will show below · It’s probably best to take what the paint masks create and just live with it. Unless you have pics of the real deal beside you, you probably won’t notice any errors · The painting instructions are very hard to understand, so I will create my own which you may want to follow · The vinyl paint masks are excellent The camo pattern of the whole jet is the mirror image of the other side. After painting dark blue, FS35109, and removing the masks. The paint edges are nice and crisp, with no appreciable raised edges. I’m leaving the masks on the clear canopy, since I will be spraying a gloss clear coat for decals later. Here is what the vinyl masks look like, with a guide for each set. They are very sturdy and fairly easy to position. Unlike the painting instructions, the mask guide is easy to follow. I decided to do the tail section next, which has a very curious difference from the rest of the jet. On the port side- and only on this side, the light grey is used, which is the only place it’s found on the upper surface. This light color is masked off with masks “A” and “B”, while the rest of the masks are numbered. The light blue is then painted on both sides, then the masks are removed. Masks #17 to 19B are then applied. Make sure to burnish down all the edges to prevent leakage. The other side, which is a mirror image. You need to then use masking tape to cover any gaps. The dark blue is then sprayed on, in light coats to prevent paint from leaking underneath the masks. The masks were removed after the paint dried, then the entire tail was masked off to apply the leading-edge film, which I painted with the radome color. Note the little blue rectangle within the first coat of light grey paint, which shouldn’t be there. While the color looks white in this photograph, it's definitely light grey in person. While I don’t have a closeup pic of this side of the tail on my subject, I do of 86-0299. Here you can see the subtle differences, but nothing should be in the light color. The other side. As mentioned above, I was surprised that the instructions called for Light Arctic Grey for the side of the tail, but also the entire underside of this jet. Checking the pics I took at Nellis AFB in November 2022, I think the instructions are wrong. While the tail does look light grey the underside is definitely white. My subject flying, which is a bit harder to see the differences. After looking at this pic, my mind is made up. I’m painting the underside white instead of light grey! Well that’s it for now. My next update will likely be painting the entire model and I’m really glad I started on a few smaller items before attacking this big and complex paint scheme, which should be a lot easier as a result. Cheers, Chuck -
Tamiya 1/32 F-16C CAS Viper - 50th Fighting Falcon Anniversary
chuck540z3 replied to Piero's topic in Works in Progress
Great modeling and a really cool and different paint scheme. Beautiful! Cheers, Chuck -
F-18F Super Hornet VFA-2 BOUNTY HUNTERS Trumpeter 1:32
chuck540z3 replied to Koralik's topic in Ready for Inspection
Effective weathering that looks real vs just dirty, is very hard to do, but you always have this art mastered. Congrats Koralik on another masterpiece! Cheers, Chuck -
Everything looks terrific Piero! Lot of neat looking details everywhere. Where did you source the "No Push" placards on the engine nozzle? I'm having difficulty trying to find something similar. Cheers, Chuck -
Tamiya F-16C - Block 50 w/Upgrades - Finished and In RFI.
chuck540z3 replied to Juggernut's topic in Works in Progress
Too bad, especially when the pod was painted and decaled so nicely. Model on! Cheers, Chuck -
You are a brave, brave man! I didn't have the guts to fill the panel lines on my model, so I'll be keenly watching how you handle these filled ones. Cheers, Chuck
- 98 replies
F-16C Block 52+ "Raven" Polish Air Force - First LSP
chuck540z3 replied to chaos07's topic in Works in Progress
That's a lesson I've learned the hard way when getting near the finish line. I want the build over with by that time, so I used to rush the final details and wound up making a mess here and there. Now I take my time when finishing a model and make less mistakes, but they still happen of course. Cheers, Chuck -
Small detail, but really well executed and clean looking. It's nice to have this and another Viper build going at the same time, all in totally different directions. Cheers, Chuck -
Those prices are smoking good, even if you just kept the needles! As much as I have used and bragged about my Iwata CM-C+ over the past few years with it's tiny 0.18mm needle, my "go-to" airbrush these days is back to my older HP-CH workhorse with the regular 0.3 mm needle, now that I use MRP paints whenever I can. The MRP paints spray very well without thinning, assuming the orifice is big enough, but the CM-C+ struggles and often sputters with this paint after a few minutes. Right now this thin needle airbrush is restricted to Alclad or other extra-thinned paint where it excels, while the rest of my painting goes through the HP-CH. One other observation. Both of these airbrushes have a screw at the bottom to further fine-tune the pressure and paint flow. I never use it, so I recommend buying the cheaper version without them, since I don't find them helpful. Cheers, Chuck -
No paint cup on those airbrushes Duane? Cheers, Chuck -
Thanks Duane. I really appreciate your "heads Up" tips as we build this very cool kit at the same time- in very different directions! As far as the Kopecky LAU-129 launchers are concerned under the wing, I don't seem to have any real gaps with the pylons, probably because I cut the notch based upon what the pylon required rather than what the Kopecky resin indicated. They fit really well right now and under the wing behind the wingtip launchers, any gap from the side cannot be seen. No real update, other than I have applied a nice thin coat of Mr. Surfacer 1200 on everything to check for flaws (a few big ones) and mostly to get rid of that snow white plastic! Maybe I can photograph this build properly from now on with some level of color and contrast balance. Cheers, Chuck -
How well do you know the Dambusters?
chuck540z3 replied to Pete Roberts's topic in Aviation Discussion & Research
7 and proud of it! All I really knew is that the leader was Guy Gibson. Cheers, Chuck -
Thanks Niels and Guy! Niels, The Modern Viper Guide book that I have shows this light on page 21, not 107, which is GBU-24 bombs instead, so maybe there are two editions? The caption on that page says that the position lights have "recently been modified to be compatible with NVG (Night Vision Goggles)", so I'm guessing that some Vipers just have a round light instead? In any case, the light on page 21 isn't just the light blanked off at the front. The red lens is offset to the back of the housing so that 80% of the red color is still visible, with the rest blanked off like Guy's pic with dark grey. This blanked off area has the tiny InfraRed light at the front. Having said all that, the best solution that I see is to add a small half-moon dark decal to this area after painting, to get the "look" without worrying too much about how much of the lens still shows since it's in the middle. Same thing for the other InfraRed lights like the ones at the rear of the vertical stabilizer. A small cockpit decal that shows 4 tiny dots within the oval housing should do the trick. The 2 small IR lights at the rear of the intake navigation lights are already there in the plastic, so I'll just darken them with a wash. I'd love to just take a pic of the book and post it here, but that would be crossing a big copyright line with our friend Jake. Cheers, Chuck -
April 11/24 Here is the problem that Niels has pointed out. Also, after looking at many pics I have of F-16’s, I couldn’t find one with these panels on any of them either. Although the lens is a bit too deep, the real fit culprit is the diameter, so I carefully sanded down the outside edge to get it to fit into the hole without removing the fastener detail, but also the depth quite a bit. These are position lights that are clearly red in Jake’s book (P 21), but the red color is almost at the surface. By making the lens thin and painting it red from behind, the red is shallow like it should be. There is also a tiny InfraRed Emitter light at the front of the light (left), which I will likely add later as a decal. Once the lights are cemented in and painted, you will only see red from the area covered with liquid mask on the right. Since I was on to lights, I decided to attack the little navigation lights on the wingtips as well, which are part of the launchers with rods holding them in place. As Pete mentioned earlier, the lenses are not tinted red and blue/green like those on the intake, but have a small bulb in each with those colors instead. To accomplish this, I usually just drill a small hole from behind, then place a dab of the corresponding paint color in the hole as a bulb replacement. Unfortunately with these lights that are almost directly on top of each other, a hole from the bottom interferes with the other light, so as a compromise I just drilled holes from above, filled them with paint, then sealed them with clear CA glue. Not very accurate if you want the bulb look, but a lot better than a painted lens. The Kopecky LAU-129 launchers need a notch cut out and holes drilled to fit the wingtip, so I used the kit parts as a guide for exact width and pin location. A view from the side, showing that the top light is always a bit offset to the rear. Not exactly the true bulb look, but this still looks better than painted lenses. More lights and more detailing options. The rear navigation light is red, but only at the very back with the side’s painted fuselage color. Here I painted just the insert that goes into the tail, which is slightly scratched from repeated insertion. I'll fix that later.... From the side, you won’t see any red when the tail is painted. But from the rear, like a fiber optic, you can clearly see red. Above that light is an oval recess for 4 more tiny InfraRed light emitters where Tamiya placed an outward oval instead, that many modelers just cut off. Here I dug a small recess and added outside fastener detail, where I will again add a small decal inside later to replicate the lights. The anti-collision strobe light for the top of the tail has a silver light housing for a white light bulb. After drilling a hole from behind to replicate this a bit, I just left a used drill bit in the hole and glued it in after trimming it for size. I then painted the insert silver so that you can see some of that from above, much like the rear navigation light. I had to be very careful about how deep I drilled the hole, because the lens at the top is tapered and very thin at the top. This about is about all I could do without risking ruining the part. Recall that I was looking for something to sort of replicate all those small “No Push” placards that are on the engine nozzle petals. What I found is a compromise of what I knew would work, but a bit too shiny for accuracy. Since you can’t read what the placard says on 80% of the P&W nozzles, even at 1/1 scale, I wasn’t too worried about 1/32 scale. I ruled out paint masks because you can’t fix flaws and paint bleed without making a mess, so I used some Aluminum ANYZ decal film that I’ve used many times before, but in other colors like black, red and yellow. While I was at it, I bought some new hose clamp film that will come in very handy with my next build, which is likely the 1/24 Airfix Spitfire Mk IX, if my new JetMads 1/32 AJ37 Viggin doesn’t call me to another jet! After carefully cutting the aluminum decal film, applying the “placards” and spraying a dull coat, this is what you get. Like I said, the placards are a bit too shiny and pronounced, but I think the overall look is still an improvement on overall accuracy. I’ll see if I can dull them up a bit without wrecking them, but at this stage I’m really getting tired of showing this nozzle time and time again, which is entirely self-induced! On to other things…. Cheers, Chuck -
Thanks Niels! I notice that this panel is on the other side of the kit as well, so I assume that I should delete them both? Also, just down from this panel and hidden by the horizontal stab (of course!), is the position light on both sides, which most modelers paint silver from behind. In Jake's book (P. 21), however, they are mostly red. Anybody know or have a good pic from above? As for the adhesion of the metal stiffeners, I have already added CA glue to the small ones at the front, while the rear ones appear to be quite solid. It is my hope that when I spray Mr. Metal Primer (X-22?) on them, some of it will wick underneath, adding to the adhesion. Further coats of primer and paint should help as well. Cheers, Chuck -
April 9/24 Lots of small updates, but mostly an introduction to 7 different after-market items you might not be aware of for this and the Block 50 kit. First some housekeeping, to remove that panel line around the AOA probe on both sides of the nose cone. While it’s usually stained this way due to the protective cap that's placed over the probe when parked, it isn’t a real panel line, so I want to remove it. Same thing holds true for the Tamiya F-15 kits. This kit has a removable nose cone to show off the radar stuff like the Block 50 kit, but it doesn’t have the radar screen anyway, so it should be glued into place instead. The nose cone join isn’t very strong as a result, so to reinforce the join I glued Part F-35 to the nose cone first, then a styrene spacer from scrap that was sanded down to size to fill the gap behind it. I used thick CA glue to weld it to the metal weight at the front, which gives you about 5 minutes to wiggle it around to get the best fit from all sides and angles with ordinary Tamiya ETC applied around the margin. The nose cone join was then sanded down where needed, with eroded fastener detail restored with the usual tools to do so, like a Mega Tool for the big fasteners. For the AOA probes I cut off, I’m using Master brass replacements which I’ve used a few times before on my other jets. I think they really “kick them up a notch”. The other side. These probes fit into small holes that I drilled, so I can leave them off until the end of the build. Another addition to this build is Kopecky horizontal stabilizers, which I heard about from our friend Marcel about 18 months ago, so I ordered a set for this future model. The Kopecky resin I’ve used so far is excellent and probably on par with ResKit, which is saying a lot! The service is excellent and their website is here: Kopecky Website This set comes with nice subtle rivet detail, but if you want almost no rivets, they now make a smoother version (32028). Although most of these stabilizers are quite smooth, there are a few where you can clearly see the rivets like on Page 30 of Jake’s book, so I’m happy to stick with these instead. As usual, trying to photograph this snow-white plastic is a real struggle, but next to this dark resin, it’s even tougher. As you probably know, those moon craters next to the stab axle on the kit parts are way too deep, while the Kopecky rivets are at the surface where they should be. The Kopecky stabs also have really nice recessed hollow internal detail that is missing from the kit. Even if you don’t care for the resin stabs, you should buy this kit for the super fine brass static wicks that come with it, also made by Master. The kit one in the middle sure looks crude and chunky when set next to them. As an added bonus, there’s enough wicks for the vertical stabilizer and the rear tips of the wings. The little resin wick holders fit the kit parts perfectly. While we’re looking at the vertical stab, that top panel line at the front should be filled and rivet detail added, while a static wick should be added, right behind the top light assembly that will be added later. Kopecky also makes really nice LAU-129 missiles rails, which thankfully come in a set of 4, because you’ll need all of them. And a really detailed center-line pylon, which comes in two parts, just like the real deal. This will be added at the end of the build, along with the landing gear cover piece it attaches to, Part C27. It looks so good from the bottom, I may not add the fuel tank, so that you can see all the work I did in the landing gear bay unobstructed. I have struggled for years to find a decent ACMI pod, because up until recently, the only resin ones available were poorly made and it’s hard to keep up with all the new versions that seem to come out every second year. Here’s the one on my subject, which I took in 2022. Thanks to 3D printing, we now have a few good options, like Phase Hanger Resin (1 ordered) and a new aftermarket supplier I found in the UK, Bandit Resin Factory. This supplier doesn’t have a full website yet, but they do have a Facebook presence, where you can see some of their products and contact the owner below, who will send you his catalogue. Bandit Resin Factory (Facebook) Apparently the ACMI pod above is a “Type E”, so I ordered 2 of them so that I had a spare for the stash. This is the nicest ACMI pod I’ve ever seen and it even comes with decals. Highly recommended! I also bought a travel pod that I’ve never seen before, which is also excellent with a door that opens. I didn’t open it yet, because I’m not likely to use it on this particular jet. As mentioned before, the front flaps on F-16’s rest a few degrees in the upward position when parked for some reason. So I decided to cement mine in permanently now, just in case I struggled with the fit and angle later. With a microbrush holding up the flaps while the glue dried, they seem to be roughly correct. Rear flaps were attached as well, but these ones can still move up and down. The next aftermarket parts I used were the CrossDelta external reinforcement plates that I showed earlier, which for Block 25 and Block 32 Vipers have the “lawnmower blades” to reinforce the vertical stabilizer base and the big 5-piece plate at the wing root to reinforce the fuel tanks. Tamiya includes a decal set to replicate these plates, but they are too thin and the rivet detail won’t show, unless you leave them unpainted white. I thought these CrossDelta plates would be metalized plastic, but they are actually made from real metal and are self adhesive. Tough to see on the white plastic, but this is where they belong based upon the instructions and Jake’s book (P. 23). Since they are super glossy and metal, I scuffed them up a bit with 1000# sandpaper to help with paint adhesion, which isn’t too rough to leave scratch marks. I will need to use a metal primer as well if I want the paint to stick. Not in the CrossDelta instructions or in Jake’s book, Block 25’s like my subject have a small reinforcement strap just below the canopy hinge on both sides, so I cut up one of the bigger plates to create 2 of them. Since they are so small, I wicked a little thin CA glue underneath them to hold them securely, then cleaned up the edges with CA glue remover. On the starboard side, the strap is just aft of the panel hinge. I also opened up that tiny vent on the side, which I should have done earlier from behind before the top fuselage Part B28 was cemented into place. One thing that’s a little surprising to me with F-16’s is that there’s a small gap at the base of the vertical stabilizer, unlike other jets. This small gap is perfect for the very tight fitting kit stabilizer, which is friction fit, so you don’t really need to glue it on, so it can be painted and decaled off the fuselage for ease of handling. Note that the small air duct on the base was cut off, which Block 25’s don’t have. Well that’s it for now, but I thought I would throw out a question that I’ve always wondered about. If F-16’s have 16 static wicks trailing all the control surfaces, why don’t other fighter jets like F-15’s and F-18’s have them as well? Hmmmm……. Cheers, Chuck -
Wow, that's a very kind comment sir and I thank you. "By doing something til it works" it pretty accurate for me, because I often try things that don't work at all, like my first attempt at exhaust staining using bits of masking tape, which turned out quite bad. With the pressure from the air brush the tape was pushed against the exhaust, creating a bit of a mess, so it was back to the drawing board with something I knew worked before, which was bits of stiff styrene instead. I have often seen some of my relatively unique techniques used by others which makes me smile. What's the saying? "Imitation is the sincerest form of flattery" or something like that? Having said that, I use plenty of techniques in my builds that I learned from others, but I always try to recognize where I got my ideas from if they are special. Marcel's anti-skid walkways using a rough surface Rustoleum in a spray can and Pete's white latex paint dipped F-16 intakes come to mind, but there are many other techniques I can't think of right now. Although I don't use these methods any more, they really helped with some of my past models, so I try to give back to these forums whenever I can. The Viper Aggressor is coming along very nicely now, with most of the parts now used. I should have an update in a few days once I finalize a few assemblies that needed a tweak here and there. Cheers, Chuck -
Thanks Neils. Your Viper Demo Team F-16 is still the benchmark for me, so I'm honored. That Viper is bad-ass gorgeous! Cheers, Chuck -
Thanks Guy! I ordered some decal material that might work for those “No Push” stencils instead. I prefer decals to painting them, because if I don’t like them or screw up, I can just remove them. With paint, I’d have to repaint them all over again and I’m not doing that again! April 4/24 One of the interesting features of these PW100 engines is the color of the shroud around the engine just back of the nozzle, which I’ll just call the engine collar. The Pratt and Whitney collar is quite different than the GE110 collar, which is shallow and always dull titanium grey. The PW100 collar is fairly wide, irregularly shaped, shiny and is often blue, presumably due to heat. I say “often”, because it’s not always blue and the intensity of the blue color is all over the place. After looking at dozens of PW100 collars, here are some examples of what I'm talking about: Intense Blue and evenly colored, which is fairly rare. I think if I painted my model like this, it would look unrealistic, despite the fact it can be real. No blue at all. Again, sort of rare, but they exist. And a few examples of what I think is more common, which is more interesting to my eye. The blue is there, but it’s mottled due to weathering and other factors, like type of engine and maintenance. Note that some of the bands are not blue. Blue almost everywhere, but blotchy. I decided to paint the model engine collar right now for a bunch of reasons: - Since it’s metallic, I want a super smooth surface with no other paint underneath, like a regular primer or paint from adjacent areas. - This collar is situated in an area between the speed brakes that will be difficult to paint later - I just want to! The first step like I always do with Alclad metallic paint, is to start with a primer coat of Tamiya Gloss Black Lacquer from a rattle can decanted into a bottle. I’ve tried the relatively new LP line of Tamiya lacquers in a bottle like LP-1, but I don’t find it as glossy as good 'ol TS-14. The collar is predominantly a relatively shiny metallic color, so I started with Alclad Stainless Steel. Unlike the “High Shine” Alclad colors like Chrome, this one is tough and can be masked without lifting. To create a mottled look, I applied liquid mask with a sponge. Salt would work just as well, but it’s messy. I then sprayed Alclad Hotmetal Blue followed by more liquid mask and Alclad White Aluminum in an iterative sequence of light mist coats. 2 of the rings were masked off so that they would not pick up as much of the blue. Everything was then sealed with clear coat of Tamiya Semi-Gloss lacquer to knock down the shine a bit. The results. This is tough to photograph to see the real colors and relative shine. Parked on the model fuselage with the nozzle attached, it starts to look more natural and you can see that it's much shinier than the exhaust, as it should be. I used a screw at the top through the alignment holes to hold things in place, since this assembly isn’t glued in yet. The small gap between nozzle and collar will be much tighter with glue. Of course I had to show off the exhaust staining again. I’m pretty happy with how things turned out, because now I have the “blue look” of the collar, without it looking too pristine and unrealistic. With the engine collar now painted and sealed, I can then mask it off and assemble the entire engine as described earlier. It now just slides into place And is now securely glued to the fuselage. Last peek at the afterburner face before I fill this engine cavity with foam and mask it off. That’s it for now and thanks for your continued interest and “like” responses, which I appreciate very much. Cheers, Chuck -
Gorgeous! Very realistic looking cockpit details and what I really like is the wiring. Straight Lines, just like they should be rather than twisted bundles like so many of us modelers do, because it's easier. Cheers, Chuck
Thanks Everyone! Much appreciated. Thanks Peter. Here's one more pic of them to see the exhaust staining better from the rear. The staining turned out a bit better than my current exhaust, but after 3 attempts, I'm done! Similar angle and lighting... Cheers, Chuck
