Allok Posted February 8, 2010 Posted February 8, 2010 (Before) When I first built this kit, I made a few terminal errors. The first mistake was painting the cockpit floor in a wood colour but this will be too much of an arse to correct, so I’m going to leave this as it is. The real problem was the paint finish. I used Tamiya acrylics, which look good and accept water-slide decaling well but they tend to come off when applying dry transfers. The rest of the decals fared no better as they were from the spares box and began to discolour as soon as the final sealing coat was applied. The next thing I did wrong was to damage the tires trying to give them a weighted effect… And then a shelf fell on it. Because I don’t have the heart to throw it out and the basic kit is actually pretty sound, I thought I’d just give it a quick spruce up. Paint removal: The paint came of real easy but the decals were stubborn and some will have to remain. My poor old RNZAF Mustang has been through the wars:
Allok Posted February 8, 2010 Author Posted February 8, 2010 I replaced the belts, prop blades and wheels with more accurate AM products. I fixed the flaps and tidied up the elevators. Rocket hard-points were scratch-built. I re-located the windshield part and masked it out. This is the first time I’ve ever done this BTW. Normally, I hand paint them and put them on afterwards. RNZAF planes were all painted (with a colour they called High Speed Silver) so I mixed my own interpretation of this shade using 3 parts Tamiya flat aluminum and 1 part metallic gray, which I then sprayed with a nice hard coat of Gunze gloss. This should fix the flaking problem. New decals came from Hobbydecal (data), Xtradecal generic roundels and I used the leftover checkerboards and serials from Ventura.
LSP_Kevin Posted February 8, 2010 Posted February 8, 2010 Great work Keith! She didn't look too shabby at the start, but you've really kicked it to another level now. Can't wait to see it finished. Kev
Allok Posted February 8, 2010 Author Posted February 8, 2010 ScanmanDan said: Excellent recovery! "and then a shelf fell on it." That has to be the best line I've read in ages. Thanks for sharing your Mustang looks great. you'd never tell it was smacked by a shelf. Dan True story: 750mm x 750mm x 6mm glass shelf collapsed on top of the one below it destroying 7 of my LSPs. It was a few years ago now and most of the models have since been repaired but it was heart breaking at the time... lucky it's only plastic. LSP_Kevin said: Great work Keith! She didn't look too shabby at the start, but you've really kicked it to another level now. Can't wait to see it finished. Kev The photo at the top was taken just after I completed it the first time around. You may be able to see a small amount of discolouration of the wingtop roundels. This "staining" gradually got worse untill it looked like I'd spilt coffee on it. You will also see the cuffed prop blades, over sized roundels (in a variety of colours) and different coloured checkers. The dry transfering is well under way and working beautifully. The gloss coat worked a treat!
fam43 Posted February 8, 2010 Posted February 8, 2010 Hi Allok, I love those reanimated kits of yesterdays specially if done so well!
Marek Posted February 8, 2010 Posted February 8, 2010 WOW! Allok, You´v done a amazingly good job. That Mustang is a beauty now. Congratulations.
Ironwing Posted February 8, 2010 Posted February 8, 2010 Nice looking Mustang...great recovery. I look forward to the finished product. Cheers, Geoff
V8Goose Posted February 8, 2010 Posted February 8, 2010 Well done Keith... I have seen worse dredged up in the jungles and swamps to fly again, so stick with it! Good to see Canterbury colours on her too. Cheers Goose
dennismcc Posted February 8, 2010 Posted February 8, 2010 Great job of recycling, feels good when you look at the result. Cheers Den
Alburymodeler Posted February 8, 2010 Posted February 8, 2010 That has come out a lot nicer. Well done. What would really help my own modelling is if you can provide contact details for the rather nice gal on the computer. Thanks in advance. Greg
Allok Posted February 8, 2010 Author Posted February 8, 2010 Alburymodeler said: That has come out a lot nicer. Well done. What would really help my own modelling is if you can provide contact details for the rather nice gal on the computer. Thanks in advance. Greg Anne Hathaway.
LDSmodeller Posted February 8, 2010 Posted February 8, 2010 Hi Keith Don't know how far you are in painting? Couple of points. The Overall colour of RNZAF P 51D's (circa 1954-55 at least) was HSS- High Speed Silver (for those not in the know, HSS was actually a 50/50 mixture of aluminium and clear (transparent) cellulose dope paints). But the spinner was NMF and the area around the exhaust stubs was also NMF (though usually discoloured) as in this photo (Photo used to illustrate only under fair use) An important note The P 51D in this photo is in HSS. HSS when newly applied in quite shiney, but dulls down in use to a grey silver colour much like this RNZAF Vampire Hope that helps Alan
Allok Posted February 9, 2010 Author Posted February 9, 2010 LDSmodeller said: Hope that helpsAlan Great photo. Thanks Alan, you're always a huge help. The plane in the picture you posted is actually only one number away from the one I'm doing! Here's a couple of pics from "The Scale" (Anthony Galbraith) of my plane: The exhaust staining is not quite so obvious on the one I'm doing but I see what you mean about the spinner. Interesting to note in the photo you posted, the gear doors are green on the inside! The one at the Museum has them in Aluminium. Note also, the absence of Checkerboards.
LDSmodeller Posted February 9, 2010 Posted February 9, 2010 Hi Keith I believe that photo is of an Ohakea 14 Squadron P 51, which as I understand it didn't have the checkerboards like the provincial Squadrons. Was used primarily for target towing for the glory guys flying the Vampires. I wonder why the Air Force Museum posed their Mustang with Aluminum gear door inners?? The one I have (part built) has Chromate yellow gear door inners from the photos I have seen and info given to me. Most interesting!!!! Look forward to your finished project Regards Alan
Allok Posted February 9, 2010 Author Posted February 9, 2010 LDSmodeller said: I wonder why the Air Force Museum posed theirMustang with Aluminum gear door inners?? Although authentic, I don't think the Mustang in the RNZAF Museum is actually an RNZAF plane, much like the Canberra and Skyhawk they have on display. As the Mustangs were delivered in standard USAF format, I'm going with that.
