williamj Posted February 20, 2018 Author Share Posted February 20, 2018 Thanks a lot for the pics guys,,This will help immensely. MikeMaben 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted February 20, 2018 Share Posted February 20, 2018 Well done William. Love reading about this kind of stuff. Troy williamj 1 Link to comment Share on other sites More sharing options...
imatt88 Posted February 20, 2018 Share Posted February 20, 2018 Love it!!! Kitbashing at its finest. RCAF conversion anyone? R Palimaka and williamj 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 20, 2018 Share Posted February 20, 2018 Has anyone tried fitting the Tamiya late canopy on the -5 Revell kit at all? williamj 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted February 21, 2018 Share Posted February 21, 2018 Has anyone tried fitting the Tamiya late canopy on the -5 Revell kit at all? Hi Brian, they (all 3) of the Tamiya canopies should fit as they're all the same dimensionally except for the bulges. One of them is the flat (relatively speaking) sided -5 version. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 21, 2018 Share Posted February 21, 2018 Hi Brian, they (all 3) of the Tamiya canopies should fit as they're all the same dimensionally except for the bulges. One of them is the flat (relatively speaking) sided -5 version. Thanks Mike! I was hoping that was the case, although I might at some point try it for myself. Even though Ill likely wait to do the late filleted version till Revell puts theirs out. Cheers, Link to comment Share on other sites More sharing options...
R Palimaka Posted February 21, 2018 Share Posted February 21, 2018 RCAF conversion anyone? That would be interesting! This last version would likely be the most logical, with the loop antenna housing on the spine. I wonder how much demand there would be? I have all the documentation to the produce the masters. Richard williamj 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted February 21, 2018 Share Posted February 21, 2018 (edited) Here's the rest of the set-up, thought maybe others would like to have it in case they do a post-war RCAF Mustang. This is the late arrangement of signals equipment with the ARN-6 radio-compass (the one with the black housing on the spine). There were a couple of other earlier radio/signals combinations that you can see in photos from earlier periods. I am researching and working to have all this published. Note that the frame under the equipment is different than that provided in the kit. It has two parallel beams running from front to back of the compartment. SCR-695 set with rack. VHF radio ARN-6 receiver and associated equipment: Edited February 21, 2018 by R Palimaka MikeMaben 1 Link to comment Share on other sites More sharing options...
williamj Posted February 21, 2018 Author Share Posted February 21, 2018 Here's the rest of the set-up, thought maybe others would like to have it in case they do a post-war RCAF Mustang. This is the late arrangement of signals equipment with the ARN-6 radio-compass (the one with the black housing on the spine). There were a couple of other earlier radio/signals combinations that you can see in photos from earlier periods. I am researching and working to have all this published. Note that the frame under the equipment is different than that provided in the kit. It has two parallel beams running from front to back of the compartment. SCR-695 set with rack. VHF radio ARN-6 receiver and associated equipment: Thanks for this....will be very helpful. R Palimaka 1 Link to comment Share on other sites More sharing options...
