Wurzacher Posted March 22, 2014 Share Posted March 22, 2014 Close enough? Rick, this is top notch modelling! Rick K 1 Link to comment Share on other sites More sharing options...
Rick K Posted April 2, 2014 Author Share Posted April 2, 2014 The landing flaps on the Hasegwa kit are weak in detail and nasty sink marks. Using Eduard PE FW190 A8 Landing Flaps I get to work. Thinking in 3D is required when bending these. PE folding tool a must. Whew! Internal detail above has to be removed. Bottom shows all clean. Test fit looks good. Kit part compare to Eduard PE. This was tricky to bend and shape. Patience and the right tools required. Major work done. Will add hinges later during build as test fitting will be required. This was time consuming. Worth the effort? Yes, am happy with the detail. Wurzacher and dutik 2 Link to comment Share on other sites More sharing options...
seiran01 Posted April 2, 2014 Share Posted April 2, 2014 looking good! Link to comment Share on other sites More sharing options...
Rick K Posted April 28, 2014 Author Share Posted April 28, 2014 Some bench time this weekend. Tail Wheel enhancement. Piston removed and drilled out with a 1.10mm micro bit. A 2mm x 0.45mm aluminum tube is cut and a plastic rod 1.0mm dia will be used as shaft guide. Test fit is good. Will align and glue then install prior to fuselage button up. Link to comment Share on other sites More sharing options...
Rick K Posted April 28, 2014 Author Share Posted April 28, 2014 (edited) Engine and tail wheel mount. Engine aligned and glued with 5 minute epoxy. Turbo supercharger plumbing is not mounted. Will mount prior to wing assembly. Tail wheel assembly aligned and glued with 5 minute epoxy. Next step will be to mend rear port fuselage install the pit and mount the wings. Edited April 28, 2014 by Rick K Mal_Belford 1 Link to comment Share on other sites More sharing options...
Guest Posted April 28, 2014 Share Posted April 28, 2014 Great work Rick !. Still looking in......Harv Link to comment Share on other sites More sharing options...
Rick K Posted May 20, 2014 Author Share Posted May 20, 2014 Great work Rick !. Still looking in......Harv thanks Harv! Link to comment Share on other sites More sharing options...
Rick K Posted May 20, 2014 Author Share Posted May 20, 2014 Fuselage mended and ready to install the pit then the wings. Used CA glue and that seam is smooth. Will have to do some scribing later. Before After Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 20, 2014 Share Posted May 20, 2014 Aw man, now I want to drag out my dormant 190S conversion! Kev Link to comment Share on other sites More sharing options...
Rick K Posted May 20, 2014 Author Share Posted May 20, 2014 (edited) Aw man, now I want to drag out my dormant 190S conversion! Kev Tandem Wurger! Love it! Bring that bird to the bench! My challenges pale compared to what you have been through. Albeit, it's gonna be a "test of will" when I mount the wings. Lots of Milliput in my future. Edited May 21, 2014 by Rick K Link to comment Share on other sites More sharing options...
Rick K Posted May 27, 2014 Author Share Posted May 27, 2014 Had some bench time this weekend, slowly making progress. Control stick and seat belt/harness added. Wiring loom on starboard side of pit added. Will cover the MG ammo counters before inserting pit into fuselage. Wiring loom on starboard side. Port side wires to come. Link to comment Share on other sites More sharing options...
Rick K Posted June 21, 2014 Author Share Posted June 21, 2014 NO FOCKEING WAY! When I first test fitted the Planet Model FW190c conversion I noticed the fuselage was slightly warped at the tailplane. No problem, right? A little hot water and the shape was corrected. No problem, right? Fuselage glued, wings glued. Some putty, sanding and scribing on deck, No problem, right? Spidey sense is tingly. Ready for some more? Look carefully at the alignment of the stabilizers. The starboard plug is about 2mm higher than the port side...the hits just keep on coming. Image credit Doogs' This build is really testing me. There is some more major surgery in my future! Engine and cockpit fit turned out ok. Well, so it seems. No alignment pins or stringers the engine from the Hasegawa FW190D9 donor kit fit in the Planet Model fuselage with little fuss and alignment. HGW belts used and am not sure on final position of the left harness. TBD. Have a tailplane solution figured and hope to get to work on it in a few days. D Bellis 1 Link to comment Share on other sites More sharing options...
seiran01 Posted June 21, 2014 Share Posted June 21, 2014 Argh! I've built several planet kits in the past (ok, started building) and many had that same stabilizer height issue when copying fuselage halves side to side. I think you need to build a plane where the name doesn't already sound like swear words D Bellis and Rick K 2 Link to comment Share on other sites More sharing options...
Rick K Posted June 23, 2014 Author Share Posted June 23, 2014 Did some cutting today. Line up cut at a seam. Did not want to cut on a seam, this was closest to common width with the Hasegawa tail. The twist is very clear here. Hope I can correct when the new tail is installed. Successfully removed the tail wheel, etc. some minor breakage, no prob to fix. Just some more work. Hasegawa tail cut at same panel line and is a close to match I can can get. Comparison C Tail (below) and D Tail (above)...FICE! FICE indeed! tomv87 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 23, 2014 Share Posted June 23, 2014 Great recovery Rick! Very skilled and determined modelling there. Looking forward to your continued, unhampered progress! Kev Rick K 1 Link to comment Share on other sites More sharing options...
