Juggernut Posted December 12, 2022 Author Share Posted December 12, 2022 (edited) Hey all, I think I got a little "creative" with the 82 camouflage pattern and I'd like to know if this is a "possible" scheme for an Erla 109G-10 or not? I'm thinking I need to start over and tone the wavy lines down a lot. Note that the paint job isn't complete...I wanted to get some input before I go out in left field any further. I'm also not sure I really like the RLM76 or the 82 colors. Again, they're Vallejo air and I'm thinking the 76 looks more like 65 and the 82 resembles 81 (of which I've heard there are many iterations). What say you? Edited December 12, 2022 by Juggernut CShanne, denders and John1 3 Link to comment Share on other sites More sharing options...
MikeMaben Posted December 13, 2022 Share Posted December 13, 2022 Hi Tim, most of the G-10s I have reference to use 83 and 75 for upper surface and 76 lower. You're rigth that 76 looks too blue., but if you're not doing a specific a/c, you could go with what you've got. Juggernut 1 Link to comment Share on other sites More sharing options...
Juggernut Posted December 13, 2022 Author Share Posted December 13, 2022 Well, I solved the issue....I stripped all the acrylic paint off the model using isopropyl alcohol and it's back on the stand as a clean slate. I've had enough with the acrylic paints and order several MRP lacquer-based paints (and two Mr. Color RLM76 because SB is out of MRP RLM76) and we'll start over. I don't know if it's my Paasche H airbrush that's the culprit (it's decades old) or if it's me (I'm decades old too) but the H just seems to splatter acrylic paint all around the area in little spits. I have an Iwata Eclipse with the gravity feed cup and I think I may break that out and see if it performs any better. I'm also wondering if the air pressure for a siphon feed needs to be higher than recommended because of the fact that it's a siphon feed.... didn't make any difference anyway...still spattered paint in spite of several different combinations of air pressure and thinner:paint. MikeMaben 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted December 14, 2022 Share Posted December 14, 2022 15 hours ago, Juggernut said: I have an Iwata Eclipse with the gravity feed cup and I think I may break that out and see if it performs any better. Well yeaaah . I have an old siphon feed too (my first) but it just sits and looks at me collecting dust. Have fun with your next attempt. Juggernut 1 Link to comment Share on other sites More sharing options...
denders Posted December 14, 2022 Share Posted December 14, 2022 When I use Vallejo Air, I add thinner, Liquitex Flow Aid, and Liquitex Slow Dri to what probably amounts to 50% paint and 50% others in an effort to slow down the "tip dry". I've also airbrushed those down to about 10 psi. And that's with a gravity feed airbrush. I have been using MRP for a couple of projects and I like it because I can pour it into the airbrush cup and when I'm done, I can pour it back into the bottle. I don't have to be careful about how much I mix and end up throwing out. Uncarina and Juggernut 2 Link to comment Share on other sites More sharing options...
