AnthonyWan Posted August 10, 2022 Posted August 10, 2022 Stumbled onto this the other day... Has anyone used it? https://www.scalemates.com/kits/icaerodesign-01-mig-21-lancer-c-conversion-set--1129431 Looks like nicely cast parts, I see a couple items potentially missing for a Lancer, but not hard to scratch. -A
Kagemusha Posted August 10, 2022 Posted August 10, 2022 I've got the set, very nice indeed, it doesn't include the Pompidouesque fuselage fairings, nor a seat. AnthonyWan 1
Rick Griewski Posted August 10, 2022 Posted August 10, 2022 Pompidouesque? Pipes and cables in the outside?
Kagemusha Posted August 10, 2022 Posted August 10, 2022 1 hour ago, Rick Griewski said: Pompidouesque? Pipes and cables in the outside? Pretty much.
Radub Posted August 11, 2022 Posted August 11, 2022 (edited) This is a great conversion, you won't regret it. The missing item that Kagemusha referred to is this trunking under the canopy on the right side of the fuselage. The two-seater version has a more elaborate device there, but the single-seater is not too difficult to scratch-build. You also need this decal sheet: https://www.hobbypark.ro/en/decals/16797-decal-132-mig-21-lamcer.html The only other thing that is needed now is a decal sheet with a full set of stencils in Romanian. HTH Radu Edited August 11, 2022 by Radub AnthonyWan and Paul in Napier 2
AnthonyWan Posted August 11, 2022 Author Posted August 11, 2022 4 minutes ago, Radub said: This is a great conversion, you won't regret it. The missing item that Kagemusha referred to is this trunking under the canopy on the right side of the fuselage. The two-seater version has a more elaborate device there, but the single-seater is not too difficult to scratch-build. You also need this decal sheet: https://www.hobbypark.ro/en/decals/16797-decal-132-mig-21-lamcer.html The only other thing that is needed now is a deal sheet with a full set of stencils in Romanian. HTH Radu Appreciate the feedback! That fairing under the canopy should be no issue at all... Are you volunteering to do some Romanian stencils??
Radub Posted August 11, 2022 Posted August 11, 2022 20 minutes ago, AnthonyWan said: Are you volunteering to do some Romanian stencils?? Unfortunately, no... AnthonyWan, Rick Griewski and Kagemusha 1 1 1
Sabrejet Posted August 11, 2022 Posted August 11, 2022 Complicating things further, LanceR (sic) stencils are a mix of red, grey and white. Would make a great-looking model in 1/32 though. AnthonyWan 1
Radub Posted August 11, 2022 Posted August 11, 2022 (edited) 4 hours ago, Sabrejet said: Complicating things further, LanceR (sic) stencils are a mix of red, grey and white. Would make a great-looking model in 1/32 though. There are also blue stencils. Radu Edited August 11, 2022 by Radub thierry laurent, Sabrejet and AnthonyWan 1 2
