REJ Posted November 7, 2020 Share Posted November 7, 2020 Just a sample. This is the AF OV-10A dash on the museum display. I'm going to get more detailed interior views in about a week. Placards on the gear struts and rocket pods should not be a problem. daveculp, dodgem37 and Greg W 3 Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 Okay...got a bunch of pictures from the museum as promised. However, there is a problem. I have an up-close of the data plate on the LAU rocket pods, but there were no plates on the nose or main gear legs. None in the wheel wells either. A retired Marine pilot flew one of the Broncos stated he had never seen any he could remember. Next question is how do you want these pictures...here on your thread or PM? Let me know.... Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 Just a teaser... dodgem37, Landrotten Highlander and daveculp 3 Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 Teaser #2... daveculp and dodgem37 2 Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 Closeup of teaser #2... dodgem37 and daveculp 2 Link to comment Share on other sites More sharing options...
daveculp Posted November 14, 2020 Author Share Posted November 14, 2020 Perfect! Those will make for some nice decals. I'll just change it to LAU-68 and lower the weights a bit. Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 I have more details of the winglets and ground power port as well as landing gear legs and wells. What surprised me was the simplicity of the boarding ladder/foot holds. Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 The mockup was apparently #1 from the original proposal and about 80% wood. It's tucked away in an open faced hangar awaiting restoration for display. dodgem37 1 Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 The wingspan is shorter, but the rest is very close to what production A models looked like. The main difference appears to be the stub wings and gun mounting in them. daveculp and dodgem37 2 Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 The Marine version was outwardly identical to the AF version except for these stencil markings on each of the propeller blades. Thought you might could use this too. dodgem37 1 Link to comment Share on other sites More sharing options...
REJ Posted November 14, 2020 Share Posted November 14, 2020 This was tucked away in the interior museum with other models and I think was a manufacturers fiberglass model. It looks to be about the same scale as the aircraft you're building. dodgem37 and daveculp 2 Link to comment Share on other sites More sharing options...
daveculp Posted November 15, 2020 Author Share Posted November 15, 2020 Nice photos! Yeah, that manufacturer's model looks sweet. #2 prop looks like it turns the wrong way Link to comment Share on other sites More sharing options...
daveculp Posted November 16, 2020 Author Share Posted November 16, 2020 After completing both main gear I decided the angles on the gear were wrong, so I moved things around around a bit in CAD and am reprinting the gear. Here's a photo of the new left main gear fresh off the printer compared with the previous version. The print takes about 12 hours or so. The sanding/bondo/primer/paint work takes about four more hours per gear. Greg W, patricksparks and Rockie Yarwood 3 Link to comment Share on other sites More sharing options...
daveculp Posted November 25, 2020 Author Share Posted November 25, 2020 Finishing up some LAU-68 rocket launchers. I printed up some inert warheads (painted blue), and some WP warheads (green/yellow/green). The WP warheads are printed in one piece, and I didn't think about how I was going to paint them when I designed them. I tried dipping them in yellow to get one edge of the yellow stripe, with the intent to dip them again in dark green, leaving a yellow band. I found that didn't do, so I'm going to work on plan B, in the mean time putting inert warheads in all the rocket launchers . Plan B is to print the WP warheads individually so I can paint them. In order to accomplish the painting I'm starting to build a low-speed lathe (about 50 rpm). I had previously bought a small lathe for this kind of thing, but it spins way too fast. I already bought the motor, so now I need to mount it to the existing lathe. That project may take some time, which I why I decided to go with the inert warheads for now. Gotta keep this project moving chukw, Greg W, Rockie Yarwood and 1 other 4 Link to comment Share on other sites More sharing options...
daveculp Posted November 29, 2020 Author Share Posted November 29, 2020 Finished the LAU-68 launchers. The sway braces are built into the attachment lugs because it makes more sense to build it this way. When the launcher is locked into place on the pylon you won't know that the sway brace is really part of the launcher. The weight of the piece is 26 grams versus the 8 grams of the original foam launcher. LSP_Kevin, Brett M, Greg W and 2 others 5 Link to comment Share on other sites More sharing options...
