zerosystem 58 Posted April 9, 2018 Share Posted April 9, 2018 (edited) I've been trying to finish this kit up and managed to finish enough of it up for a show this weekend. Prior to the show though I noticed that something looked off to me and found that the rear fuselage has a twist to it and each the stabilizers are off by...1/4 of an inch. At first I was trying to scramble to find out why and what I might have done to cause this. I checked the wingtip heights off the ground, they are only off by about 1/16" (within my acceptable margins in the scale). Then I saw that the tail is over slightly as well and figured it was a previously unseen warp. Has anybody else seen this in their builds and any solutions for a nearly finished build that won't set everything back? (pictures here http://www.arcforums.com/forums/air/index.php?/topic/303447-124-kinetic-p-47-razorback/) Thanks, Peter Edited April 9, 2018 by zerosystem Link to post Share on other sites
Rob Colvin 529 Posted April 9, 2018 Share Posted April 9, 2018 My kit had a slightly warped fuselage halves. A bit of heat and some bending took the warp out for me. Rob Model_Monkey 1 Link to post Share on other sites
zerosystem 58 Posted April 9, 2018 Author Share Posted April 9, 2018 Thanks Rob, I wish I had seen it before assembly and painting. I've since committed to breaking off the lower stab in prep for reattaching it at the same height as the other. I'll have to live with the vertical stab and rudder being off and hope that judges just can't stand up straight. LSP_K2 1 Link to post Share on other sites
Theo 283 Posted April 9, 2018 Share Posted April 9, 2018 Use hot water, nearly at cooking point, bend it when soft enough, hold in position and let someone else poor cold water over it. That should do the trick without damaging your paint job. MikeMaben 1 Link to post Share on other sites
Guest Posted April 10, 2018 Share Posted April 10, 2018 Use hot water, nearly at cooking point, bend it when soft enough, hold in position and let someone else poor cold water over it. That should do the trick without damaging your paint job. Yep, since the vertical's off too you'll need to twist the whole empenage. Link to post Share on other sites
zerosystem 58 Posted April 10, 2018 Author Share Posted April 10, 2018 Thanks gents, I committed to repositioning the low stab this afternoon and successfully broke it off without too much damage and and in the process of resetting it now. I'll give the hot water a shot on the vertical stab later this week. The Vallejo paint has me a bit worried though since that doesn't seem to last though handling well but most of the tail is metalizer. Link to post Share on other sites
zerosystem 58 Posted April 10, 2018 Author Share Posted April 10, 2018 Use hot water, nearly at cooking point, bend it when soft enough, hold in position and let someone else poor cold water over it. That should do the trick without damaging your paint job. Question, would you recommed dunking the vertical stab or pouring over it for the best results? Link to post Share on other sites
Theo 283 Posted April 10, 2018 Share Posted April 10, 2018 Pouring water will not help, I recommend to put it in water for a while, and it's important to hold it in place while it's cooled with cold water. Good Luck and let us know. Link to post Share on other sites
Guest Posted April 10, 2018 Share Posted April 10, 2018 Either way would work Peter, but the times I have had the best result was letting a stream of hot tap water run over the area I wanted the twist to take place. It takes time to let the plastic absorb the heat. Good question, good luck zerosystem 1 Link to post Share on other sites
LSP_K2 24,434 Posted April 11, 2018 Share Posted April 11, 2018 When I reviewed the kit (here), I actually noticed how absolutely straight the vertical tail was, and was quite happy to see that. I agree with the others though, hot water to bend it back to the correct position, then set with cold water. MikeMaben 1 Link to post Share on other sites
zerosystem 58 Posted April 12, 2018 Author Share Posted April 12, 2018 (edited) I wasn't able to reset it much with hot tap water, the tail just flexes and doesn't seem to have softened, I might try again tonight but I've got to figure out a way to do with hotter water and only 2 hands... I love this hobby? Edited April 12, 2018 by zerosystem MikeMaben, LSP_K2 and Bomber_County 3 Link to post Share on other sites
