Brian79 Posted May 17, 2016 Share Posted May 17, 2016 The instructions call out Azure blue for the underside, is this accurate, probably grey?, or impossible to know? Any thoughts appreciated! Link to comment Share on other sites More sharing options...
D Bellis Posted May 17, 2016 Share Posted May 17, 2016 Who's instructions? There is a profile floating around dating back to the '80s (or possibly before) showing Azure Blue undersides. Personally, that artist's conclusion seems highly unlikely given the rest of the scheme (DuPont Dark Earth and Dark Green topsides). So, unless there's a color photo of that aircraft showing Azure undersides, then gray would be most likely. D LSP_K2 and Zero77 2 Link to comment Share on other sites More sharing options...
LDSmodeller Posted May 17, 2016 Share Posted May 17, 2016 The instructions call out Azure blue for the underside, is this accurate, probably grey?, or impossible to know? Any thoughts appreciated! "Texas Longhorn" was (to my understanding) a P40E-1 which was an export aircraft built to British MAP specs, so would have been in RAF TLS (Temperate Land Scheme). The DuPont Colours would have been Dark Earth (71-009) /Dark Green (71-013) /Sky (Duck Egg Blue) being DuPont 71-021 Sky Type S- Grey DuPont 71-021 is not a grey colour in any respect, it is a Duck Egg Blue. The RNZAF received P 40E-1's in early 1942 in the above colours The link below are the above colours off an RNZAF P40E-1 elevator that crashed circa 1943 in New Zealand (Apologies about the scan, I would take photos close up but moving house, I put them in a safe and secure place, and they are still safe and secure ) https://drive.google.com/file/d/0B3Yff6LKWML1VS00MVFaR04ycjg/view?usp=sharing The scan doesn't do it justice, but the Duck Egg Blue is a very pale Blue with a greenish tinge. You don't mention what paints you are using, but Humbrol have duck egg blue (Hu 23) that is very close. Hope that helps? Regards Alan Zero77 and David66 2 Link to comment Share on other sites More sharing options...
Brian79 Posted May 17, 2016 Author Share Posted May 17, 2016 The kit is the 1/32 Hasegawa version. So it appears that this color is what was on British a/c like the Spitfire, not really a blue at all based on the picture. Link to comment Share on other sites More sharing options...
D Bellis Posted May 17, 2016 Share Posted May 17, 2016 The link below are the above colours off an RNZAF P40E-1 elevator that crashed circa 1943 in New Zealand... However, RNZAF and RAAF aircraft were eventually repainted with local colors (Earth Brown, Foliage Green and Sky Blue). These colors are not what the aircraft was painted with at the factory, and are quite different from the DuPont colors used by Curtiss. Texas Longhorn would have been painted in Curtiss/DuPont colors, not RNZAF or RAAF colors. This site may also be of some use: http://www.ipmscanada.com/ipms/Reference_%20Article/Aircraft/Aircraft_Page/P40%20Underside%20Colour.html HTH, D David66 1 Link to comment Share on other sites More sharing options...
waroff Posted May 17, 2016 Share Posted May 17, 2016 (edited) In the factory drawings, "markings & insignia scheme for P40E", Curtiss gave the equivalent forbrown 71-009green " "013red " " 007white " " 001bleu " " 012yellow " "010But not for the "Sky type S", there is any information for this line. It was wrote "undersurfaces" onlyIs it possible that the british had furnished these "Sky" paint? Azure blue (71-062) was specified for "desert camouflage" applied on the p40K only Edited May 17, 2016 by waroff David66, Zero77 and D Bellis 3 Link to comment Share on other sites More sharing options...
D Bellis Posted May 17, 2016 Share Posted May 17, 2016 Is it possible that the british had furnished these "Sky" paint? Not likely. All of their specifications call for "US Equivalent" colors. Another relevant discussion on this topic (which includes both DuPont color chips and relic evidence): http://www.network54.com/Forum/149674/thread/1271801585 D David66 1 Link to comment Share on other sites More sharing options...
waroff Posted May 17, 2016 Share Posted May 17, 2016 (edited) Ok, i'm just intrigued why Curtiss has not gave Du Pont equivalent for Sky color as for the others Edited May 17, 2016 by waroff David66 and Zero77 2 Link to comment Share on other sites More sharing options...
D Bellis Posted May 17, 2016 Share Posted May 17, 2016 Ok, i'm just intrigued why Curtiss has not gave Du Pont equivalent for Sky color as for the others Agreed. Very interesting that the underside color is not noted on that drawing. Rato's article cites "71-021" for the undersides, based on the references at the bottom of the page: http://www.ratomodeling.com/articles/AVG_cammo/ D Link to comment Share on other sites More sharing options...
RBrown Posted May 18, 2016 Share Posted May 18, 2016 Zero77, D.B. Andrus and D Bellis 3 Link to comment Share on other sites More sharing options...
LDSmodeller Posted May 18, 2016 Share Posted May 18, 2016 However, RNZAF and RAAF aircraft were eventually repainted with local colors (Earth Brown, Foliage Green and Sky Blue). These colors are not what the aircraft was painted with at the factory, and are quite different from the DuPont colors used by Curtiss. Texas Longhorn would have been painted in Curtiss/DuPont colors, not RNZAF or RAAF colors. This site may also be of some use: http://www.ipmscanada.com/ipms/Reference_%20Article/Aircraft/Aircraft_Page/P40%20Underside%20Colour.html HTH, D You obviously have access to Highly Classified information that the RAAF or RNZAF does not possess, the Infromation you mention is not found in any of my RNZAF Reference books (especially by those who flew/maintained these aircraft) I am finding it quite annoying that people insist on telling we Kiwi's and Aussies, what our Air Forces aircraft were/are or looked like and when you read what is posted by these people, you realise the poster has no idea. Do people ever consider that we Commonwealth Forces the "End User" may/do have information not readily available on the net on these things - not that it matters, when we post it, it gets pooh hooed anyway by "others who know better" The colours I posted above, are the colours the aircraft arrived in from the US in 1942, so are correct for colours painted on the aircraft by Curtiss, and are verifiable with the Curtiss document that arrived with the aircraft in 1942. These documents give the DuPont colours top and bottom including the DuPont colours for the Roundel paints used for the RAF Insignia. The RNZAF museum has copies of these documents which gives these colours. Grey or Sky Grey (or any type of grey colour) for the lower colour is not mentioned, but Sky (Duck Egg Blue) is. Those repaints you speak of occured much later, and for RNZAF aircraft nothing like you mention. Of Interest Texas Long Horn has the RAF code ET600. The aircraft from which the DuPont swatches are from NZ3031, had the RAF serial ET770. Incidently I have a copy of an British AMO A.926. Aircraft Colouring and Recognition Markings dated 12.12.40, states that all RAF aircraft "Including American and Allied types in use by British Air Forces" were to be camouflaged on the undersurfaces in Duck Egg Blue (Sky Type S). When the Minsitry of Aircraft Production placed orders with the likes of Curtiss, Duckegg Blue was to be the undersides - not eqivalent colours, those came later. If you want to read properly researched information on this I suggest contacting Nick Millman on Britmodeller. Regards Alan David66 1 Link to comment Share on other sites More sharing options...
D Bellis Posted May 18, 2016 Share Posted May 18, 2016 You obviously have access to Highly Classified information that the RAAF or RNZAF does not possess, It is all posted right here in this thread by myself and others. Take it or leave it. D Troy Molitor 1 Link to comment Share on other sites More sharing options...
Brian79 Posted May 18, 2016 Author Share Posted May 18, 2016 Ok, so if I understand correctly the sky blue color is correct for this application? Almost seems like RLM76 ish type blue. Link to comment Share on other sites More sharing options...
D Bellis Posted May 18, 2016 Share Posted May 18, 2016 Ok, so if I understand correctly the sky blue color is correct for this application? Almost seems like RLM76 ish type blue. No, DuPont "Sky Type S Gray 71-021". A sample of which can be sen in the bottom left of the image posted by RBrown above. HTH, D Link to comment Share on other sites More sharing options...
LDSmodeller Posted May 19, 2016 Share Posted May 19, 2016 (edited) No, DuPont "Sky Type S Gray 71-021". A sample of which can be sen in the bottom left of the image posted by RBrown above. HTH, D Brian 79 If you look at the image i posted, the lower Blue Colour (and it is blue) is DuPont 71-021 Duck Egg Blue aka Sky Type S- grey. Irrespective what has posted above. Bottom line is we Kiwi's and Aussies had aircraft delivered in 1942, from RAF Stock in the US. Curtiss Documents arriving with the aircraft give the DuPont colours INCLUDING DuPont 71-021 Sky Type S-Grey. None of our P 40E-1's (especially RNZAF) were repainted on arrival - more mythical nonsense. Texas longhorn was part of the British order, taken back by the USAAF due to aircraft shortage. I have shown that both the RAF serials between Texas Longhorn and mine (NZ3031) were not too far apart Good luck with your build Regards Alan PS I would, if you are serious about this, look up Nick millman on Britmodeller, surprisngly Nick's comment will echo mine on DuPont Sky Type S- Grey. Remember it's your model Edited May 19, 2016 by LSP_Ray Removed personal attack. David66 1 Link to comment Share on other sites More sharing options...
