Aluxe Posted September 6, 2014 Posted September 6, 2014 (edited) Hi guys Interesting Group Build, fits perfectly with my problems, because it doubles parts to build Helicopter. Double seat, double remote control, collective double, double landing skid and often twin-engine, twin rudder, two doors on each side, are almost always well ... I want to realize my crazy idea of ​​having a Military Helo every American country and if possible without repeating the model! ... already finished my first, a 1/32 HH-43 Huskie Testors USAF. and now is the turn to a second model, I would like to participate with the 1/32 Revell 04402 Bk-117, The model: teh sprues: http://www.super-hobby.es/products/Medicopter-117-1066831.html After considering several options, I decided to build the MBB-117 kit that militarized American countries Helo I know this only two Colombia and Chile, My decision made ​​quickly for their showy: the Colombian Helo . This model has a few in my view detail, and with a little scratch to see who did it. Edited September 24, 2014 by Aluxe EmperorKai, andromeda673, Girlscanplay2 and 1 other 4
Aluxe Posted September 6, 2014 Author Posted September 6, 2014 So let's start ...This model does not come with the doors open, with fine knife # 11, patience and a bit of force, start the cuts. The drivers door was more delicate, the front post is too thin. If problems resulted. Interested adjust the profile of the nose, so we removed the same way This image corresponds to the cuts. Then I make holes to the cabinet control panel and by the time it's all folks .. success with their projects Girlscanplay2, Avenger2614 and EmperorKai 3
Anthony in NZ Posted September 7, 2014 Posted September 7, 2014 Wow! Now this is my kind of build! I will definitely be following along with this one Cheers Anthony
Aluxe Posted September 9, 2014 Author Posted September 9, 2014 Hi Anthony Your work is part of my motivation with this model, hopefully we can finish at the same time... Cheers
Aluxe Posted September 11, 2014 Author Posted September 11, 2014 (edited) Hola everyone, MARU5137 Thanks Hi mark31, I have seen your projects .. as will the Lynx ... seems good job, well, I continued with a small advance, reviewed the fuselage skin, retirement fuselage reinforcements and accessories, lamps and mouth taking bunkers, open bays and filter area. not in the picture but the cabin air intake was opened. oh ... sanded and defective surfaces injection,,, appear more sanding ... fine sandpaper and some putty ... um .. I have not here, I'm away from home ... I miss my workbench. Cheers! Edited September 11, 2014 by Aluxe Girlscanplay2 and EmperorKai 2
Aluxe Posted September 24, 2014 Author Posted September 24, 2014 Hello friends Another known event that might classify this work as is Double Trouble The first flight for the Navy of the Republic of Colombia of this helicopter was on December 22, 2005, unfortunately seven years later he suffered an emergency landing with severe damage, and May this year, he made his second first flight ie one Double Trouble resolved and now here with some progress I started renovating the space where I put the sliding door here appreciates the space where the door post A) I put poles reinforcements and air intake duct installed guide coverC) space was left for the gate guidesD) undercover adjusted the outer frameE) as I said the air intake was openedF) We had to attach styrene to align the doorG) snap the plastic frame with styreneH) removal of the rear doors. by the time it's all greetings Iain, EmperorKai and Girlscanplay2 3
Anthony in NZ Posted September 24, 2014 Posted September 24, 2014 Wow, that is fantastic indeed!!!! You are doing an inspiring job, and I am in awe of your work. You want to check out ARC, Niek (Seaking Pilot) is building a Revell 32nd BK as well and is top stuff. You might want to check his out as well. Let me know if I can offer any help Cheers Anthony
andromeda673 Posted September 24, 2014 Posted September 24, 2014 nice...........the rotor heads are out! nice work with all the scratch building and detail work, can't wait to see more.
Aluxe Posted September 24, 2014 Author Posted September 24, 2014 Hi Anthony oh yes, I need a lot of help ... always 'm locating references, only work with what little I've seen ...and I saw each other and work Seaking Pilot interesting to know that several projects have this Helo ... maybe we create a new group construcción.jjj welcome all the help and suggestion. ummm I think the first will get better camera ... greetings andromeda673 1
Aluxe Posted September 24, 2014 Author Posted September 24, 2014 Hi Andromeda673 thanks for your good comments,,, andromeda673 1
Aluxe Posted October 2, 2014 Author Posted October 2, 2014 Now, a small advance inner panels to fit windows in this kit, once you open doors, you'll see that the deck does not fit to the inside panels, you need to add 3.5mm styrene. the door is already aligned to the pillar and slide smoothly making panels for pillars. by the time it's all folks,, seems little ... ... EmperorKai 1
mark31 Posted October 3, 2014 Posted October 3, 2014 Great work i know what time that cost to make the details. Keep up the good work. Mark
Aluxe Posted October 9, 2014 Author Posted October 9, 2014 Thanks guys, so is .. slowly, now a little more. Thanks to the work of Anthony I noticed my mistake, so I will rebuild, you tell me, as was? also advances the instrument panel EmperorKai and Girlscanplay2 2
