Tamiya Spitfire Mk. IXc UPDATE 4/20/13 Complete and in the books.
Guest Peterpools
Thanks Matt.
You sure it it right on the head. Papa Tamiya makes it a pleasure to build a kit OOB; add a bit of weathering a detail here and there and and you're good to go.
  • 2 weeks later...
Guest Peterpools
My bench time is starting to show the effects of the pool season kicking into gear. Progress has been slow but the fuselage has been primed, basic cammo work completed and four coats of Future applied. I thought I would try using Future rather then Glosscote for all the obvious health reasons, not to mention the odor with all the windows buttoned up. It's getting glossy but not where I would be with Glosscote at this point. Looking for a finish with some weathering but wanting the look of a well maintained aircraft, I started to break up the solid colors slightly, working towards that goal. This is the first time I've attempted a cammo finish since my nearly 30 year vacation from the hobby and looking at the photos, there are a few areas that will need a bit of touch work
So far, so good, as the Tamiya acrylics laid down nicely. I still need to air brush on the yellow leading edges and then I should be ready to start the decaling process.
The Merlin is just about done and needs a bit of semi gloss and that should be that as well. The gear is just screwed in place for painting and still needs to be worked on.
The prop was painted NATO black to ease off the stark black color and cowl panels are primed and ready for their cammo skins.
Thanks for looking in and following the build.
Edited by Peterpools
NICE! I always did like the gray/green Brit camo a LOT. When I got done with my Mk XIV I still kinda wished Id done it in the Ocean gray/green camo like yours.
Looks stupendous Peter :D
Guest Peterpools
J
Thanks Bubba
Much appreciated
Guest Peterpools
Dennis
Appreciate the kind words. Have to agree .. Love those Spits.
Guest Peterpools
Brian
Totally agree, as the ocean gray/dark green cammo has a look and feel all of it's own
Thanks Buddy, much appreciated.
Cheers Peter, she's looking VERY good! Great idea on the NATO black for the prop, looks much better than the straight black.
Well, I must say this is really outstanding work, my friend. Love the camo.............Harv :popcorn:
Guest Peterpools
Thanks Ron
Much appreciated
Guest Peterpools
Franks
Much appreciated. Thought I lean towards a scale color effect and see how it looks. So far, seems to be headed in the right direction.
Guest Peterpools
Harv
Thanks for the kind words ... so much appreciated
Do you spray your Klear? I find that brush painting gives a much shinier coat much faster than spray. The brush tends to put down a slightly thicker coat but since its self levelling, this tends not to be a problem, in fact its an advantage! When I built my Tamiya Spit a couple of years ago I brush painted the Klear and it went down great. Just use a large soft brush
Edited by KallistiUK
