Uncarina Posted August 8, 2014 Share Posted August 8, 2014 I've been in a bit of a modelling slump: assembling and cleaning 22 Mk-82 bombs for my A-6A Intruder build can only get me so much entertainment, and the F-117 bomb bay has me temporarily swallowed up, so I decided to step back and build a basic build. The Revell Erla 109 is inexpensive, simple to build, nicely detailed, and just the thing to get me back into those more complex builds. I will be building this mostly out of the box, with BarracudaCast props, spinner, intake and exhaust set, and EagleCals decals. Just got the kit last night, and time to get started! First thing, fix the box: cut the sides and one end of the top panel, then tape the side panels, and voila! A top opening box. Assembly starts with the cockpit, and the parts fit well and have nice detail. The pedals are okay, but be careful trimming the flash around the outline. The fuel line is clear, a nice feature, but the section of line remaining clear has a sprue attachment point, suboptimal as I like to say. So here's where I'm at after a couple of hours: Testors Acryl RLM-22 (Airbrushes nicely, with a slight gloss. I just add a drop of dish soap to distilled water to thin). A brush coat of Future, then a dark sienna/black oil wash. Painting highlights and seeing what I can do with the molded seatbelts comes next! Cheers, Tom Mal_Belford, Girlscanplay2, Nic C.D. and 1 other 4 Link to comment Share on other sites More sharing options...
tucohoward Posted August 8, 2014 Share Posted August 8, 2014 Nice start, Tom. Just started one myself. Everyone says it's a simple build, but I just chucked a G-6 in trash. Totally unenjoyable and way too much like real work. Haven't thrown a model away in mid-build in a long time. Maybe I have been spoiled by how nice the Hasegawa 109's go together. Why I started a G-10 I have no idea. Anyhow, I am sure yours will be nice. Jay Link to comment Share on other sites More sharing options...
Uncarina Posted August 8, 2014 Author Share Posted August 8, 2014 Jay, Thanks for checking in. I do like those Hasegawa 109's. I built two back to back, the only time so far for me. I certainly hope your current build is more fun! From what I've read, having a full-length fuselage makes this one a little more straightfoward than the G-6. Is there anything you suggest I look out for? Cheers, Tom Link to comment Share on other sites More sharing options...
tucohoward Posted August 8, 2014 Share Posted August 8, 2014 Mainly for me, it was all the seams that had to be dealt with, the general engineering of how it goes together, and a bit of the inaccuracies. I didn't even salvage the Eduard exhausts or the HGW seatbelts. That's how annoyed I was. That was over a month ago and I am just getting back to the workbench. This is supposed to be fun, and that wasn't. Jay Link to comment Share on other sites More sharing options...
Uncarina Posted August 8, 2014 Author Share Posted August 8, 2014 An update: painted highlights, applied decals for the instruments from an MDC Luftwaffe decal sheet, added buckles from an Aires set: I wanted to see how well I could get the molded seatbelts to look, since I didn't want to remove them unless I felt compelled to do so, and I'm pleased with the results; I just need to touch up the buckles. I have to say I'm having a lot of fun with this! Cheers, Tom Nic C.D., Mal_Belford and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
Uncarina Posted August 12, 2014 Author Share Posted August 12, 2014 Some progress: Overall fit so far has been pretty good. I've only fitted the engine cover until the BarracudaCast exhausts come in. One anomaly that no one else has mentioned is that I found a large gap between the oil cooler fairing upper plate (part 35) at the forward junction with the fuselage. I had to fill in this space. Also, the cooler filters (part 66) had to be reduced in height around a millimeter so that the fairing would fit to the fuselage. Cheers, Tom Nic C.D. and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
Guest Posted August 12, 2014 Share Posted August 12, 2014 That's a good start. I look forward to seeing the finished model! Link to comment Share on other sites More sharing options...
Uncarina Posted August 12, 2014 Author Share Posted August 12, 2014 John, Thanks! It will hopefully go fast. I'm looking forward to trying out the Barracuda parts. Cheers, Tom Link to comment Share on other sites More sharing options...
Nic C.D. Posted August 12, 2014 Share Posted August 12, 2014 Looking good, Tom! You'll be happy with the Barracuda parts, especially the oil coller, because the fit is amazing! I was surprised to see that part 35 was so short. I've never had that on my builds. I know that the kit has two similar looking parts; 35 and 36. One is too short, so I used the other one, which fits quite good actually and I didn't have to alter the filter parts either. I look forward to your next post and have fun ! Nic Uncarina 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted August 12, 2014 Share Posted August 12, 2014 Tom....WOW This looks real great, i like that weathering of your cockpit, like that style of dirt...... looking forward to see more of this progress on this one... So keep em coming. /Mal Uncarina 1 Link to comment Share on other sites More sharing options...
Uncarina Posted August 12, 2014 Author Share Posted August 12, 2014 Looking good, Tom! You'll be happy with the Barracuda parts, especially the oil coller, because the fit is amazing! I was surprised to see that part 35 was so short. I've never had that on my builds. I know that the kit has two similar looking parts; 35 and 36. One is too short, so I used the other one, which fits quite good actually and I didn't have to alter the filter parts either. I look forward to your next post and have fun ! Nic Nic, I knew I should have checked with you first! I will check but I bet I picked the wrong one. Cheers, Tom Link to comment Share on other sites More sharing options...
Uncarina Posted August 12, 2014 Author Share Posted August 12, 2014 Tom....WOW This looks real great, i like that weathering of your cockpit, like that style of dirt...... looking forward to see more of this progress on this one... So keep em coming. /Mal Mal, Thanks very much, and thanks for checking in! Added a dark oil wash on top of a gloss coat, then drybrushed with a gray blended from black and white oil paints. It's my favorite part of building these cockpits. Cheers, Tom Mal_Belford 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 12, 2014 Share Posted August 12, 2014 Great update! I know all about an easier more basic "sanity check" kind of build to get the juices flowing..................sometimes it just has to be done to get to the more complex projects. Looks like you moving fast on this one! Progress and/or completion always motivates me! Uncarina 1 Link to comment Share on other sites More sharing options...
Uncarina Posted August 12, 2014 Author Share Posted August 12, 2014 Brian, Thanks for checking in! So far this kit seems like a great choice for this. Kind of like slipping in a short story between reading those huge novels! Cheers, Tom Out2gtcha 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted August 12, 2014 Share Posted August 12, 2014 (edited) Mal, Thanks very much, and thanks for checking in! Added a dark oil wash on top of a gloss coat, then drybrushed with a gray blended from black and white oil paints. It's my favorite part of building these cockpits. Cheers, Tom Sound similar.... Yep The oils are the key for us then , drybrushing oils is indeed very very effective, i use them more and more drybrushing and effects, off course oilwashes with different tones.... Im very exited, wich indevid are you going for?..... /Mal Edited August 12, 2014 by Mal_Belford Uncarina 1 Link to comment Share on other sites More sharing options...
