Delayar Posted March 9, 2014 Share Posted March 9, 2014 (edited) Hi! After enquiring on this forum for some details about the P-51D Jumpin Jacques, I finaly started with the build. It is my second build in 1/32, so far I only built the Revell F-15E Demonstrator (twice actually, the first time as teenager, the second time a few years ago, see http://forum.largescaleplanes.com/index.php?showtopic=49441). I usually build in 1/48, since the kits are cheaper and don't require that much space. But I could't pass the big Tamiya P-51D. Jumpin Jacques is a P-51D-20NA aircraft, and was based on the Philippines. Here is the kit with the detail sets I will be using. Eduard Interior PE Eduard Engine PE BarracudaCast cockpit details BarracudaCast diamon thread tires BarracudaCals Cockpit stencils G-Factor Landing gears HGW seat belts Eagle Strike decals So far I started with the engine. I assembled it and painted it black to prepare for some detailing. Next I will paint the nuts and bolts silver and add the ignition harnesses. Markus Edited December 19, 2018 by Delayar Mal_Belford 1 Link to comment Share on other sites More sharing options...
Uncarina Posted March 9, 2014 Share Posted March 9, 2014 Looks like a great start! I will be watching this. Thanks for sharing. Tom Link to comment Share on other sites More sharing options...
Ironwing Posted March 9, 2014 Share Posted March 9, 2014 Markus, Just wonderful to see another Mustang build start. I hope you'll post many photos of your progress. Best Geoff Link to comment Share on other sites More sharing options...
Delayar Posted March 20, 2014 Author Share Posted March 20, 2014 (edited) Hi! A small update. I know I am not a fast builder.... I painted the nuts and bolts and added some oil piping. In all pictures of the real engine I found, there is a device at the front of the engine, under the propeller shaft, where the two oil pipes go, but this device is not present on the Tamiya engine. As this area will be hidden anyways, I just let the pipes float freely. The same is true for the other end, where they go somewhere behind the magneto. Regards, Markus Edited December 19, 2018 by Delayar Mal_Belford and CANicoll 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 20, 2014 Share Posted March 20, 2014 Markus Very nice start on your Tamiya P-51and from the looks of your AM sets, you're all set to bring her up to the next level. So far, I've built three Tamiya Mustangs - awesome kits. Only point to be aware of is Tamiya color call outs for parts of the front office, the radio deck framing and wheel wells are inaccurate. Not a biggie but it's easy to correct. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Delayar Posted March 20, 2014 Author Share Posted March 20, 2014 Thanks for the hints. I will use all the other great builds on this forum as a reference, so I hopefully will avoid some serious mistakes. Markus Link to comment Share on other sites More sharing options...
Delayar Posted April 2, 2014 Author Share Posted April 2, 2014 (edited) Hi! Here is another update. The Engine is almost finished, only the weathering is still missing. I added the ignition harnesses. Here is a picture of the intake harnes prior to installation. The main part is made from 0.9mm brass tube, where I drilled 0.6mm holes to take the leads. The ignition leads themselves are made from 0.5mm solder, glued into place with CA. The tube is a vinyl tube from a Tamiya 1/12 motorbike kit. And here is the engine with the ignition attached: the other side: And the top: There are also some parts from the Eduard PE set attached. Now I am a little bit at a loss, because I have never weathered prop engines. Do you have any tips as how to proceed? Regards, Markus Edited December 19, 2018 by Delayar Mal_Belford 1 Link to comment Share on other sites More sharing options...
tbell Posted April 2, 2014 Share Posted April 2, 2014 Looking good, Markus. For your engine weathering I would suggest a wash of a greyish-brown, plus some understated chipping on the bolt heads and select high points. A few oil and fuel stains using something like AK Interactive or MiG prodicts would work well, too. For a bit of inspeiration, here is a shot of Chris Wauchop's Spit IX Merlin: Link to comment Share on other sites More sharing options...
Delayar Posted April 2, 2014 Author Share Posted April 2, 2014 Thank you! Markus Link to comment Share on other sites More sharing options...
Delayar Posted July 29, 2014 Author Share Posted July 29, 2014 So, after a few month, there are some news. I didn't have much time during the last months, so I couldn't do much at one time, so progress was very slow. Anyway, I drybrushed and washed the engine. The oil tank was enhanced with Eduard PE and solder. Sadly, one of the fastener tabs got lost :-( The two parts glued together: The HGW seatbelts are really fiddly to get together, but they look fabolous: I will apply a wash at a later stage. I decided to add the BarracudaCast sidewalls. The cockpit parts so far: I have to add cockpit stencils to the middle part of the instrument panel. The Barracuda decals are for the later area switchplate, so I have to use some artistic license. Also, stencils to the cockpit floor have to be added and then the parts will be clearcoated. Thats it so far. I hope to make some progress in the next days. Regards, Markus Mal_Belford and DesertRat 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted July 29, 2014 Share Posted July 29, 2014 Nice detail work. Sincerely, Mark Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2014 Share Posted July 30, 2014 Looking good Markus! Good to see you back at it. Kev Link to comment Share on other sites More sharing options...
JJYL Posted August 2, 2014 Share Posted August 2, 2014 Looking good Link to comment Share on other sites More sharing options...
Delayar Posted November 30, 2014 Author Share Posted November 30, 2014 (edited) Time goes by... Since my last post, I had a lot of other projects going on, one of them my own wedding, so I didn't have much time to work on Jumpin' Jacques. Now, however, I hope to find more time to complete this build. The parts for the cockpit are finished. They recieved a wash and flatcoat. Here is a detailed shot of the IP: the radio and battery assembly from BaracudaCast. The bottle is made from clear sprue. The cockpit assembly without the IP: The pipe from the fuel tank was made with 1mm solder. And here is the cockpit with the IP, glareshield and gunsight in place. The gunsight is from the Baracuda set, with the transparent parts cut off from the kit parts. Right now I am working on the sidewalls of the cokpit. I also noteced a thing with the Eduard PE parts. For part V25, there are PE parts, which do not fit into the plastic part, but have to be applied "on top": Is this correct, or should I leave these PE parts off? Best regards, Markus Edited November 30, 2014 by Delayar Mal_Belford 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 30, 2014 Share Posted November 30, 2014 That's looking very nice indeed! No idea about the PE part, unfortunately. Kev Link to comment Share on other sites More sharing options...
