mark31 Posted February 24, 2014 Share Posted February 24, 2014 Hello to u all. Im doing some resaerch on one of the kits in my stash. I know so far that the trumpeter kit is a late D model. But what are the big difrences between those 2? I have read somewhere that the air intakes are a bit difrent and the spine? Are this big difrences are can i let it like it is? Many thanks. Mark Link to comment Share on other sites More sharing options...
Lee White Posted February 24, 2014 Share Posted February 24, 2014 (edited) Hi Mark, That is an interesting question. Other than the prototypes having a "straight" intake, I thought that the "M" style intake remained the same thru the whole production run. The aft air intakes, which cool the afterburner, did change. Early planes had NACA ducts, while later, Vietnam era planes had enlarged intakes. Maybe that is what you read about? Edited February 24, 2014 by Lee White Link to comment Share on other sites More sharing options...
Ken Stetzenko Posted February 24, 2014 Share Posted February 24, 2014 (edited) Mark. the very late F-105D's after the vietnam war were modified with an enlarged spine to house more electronics and most went to a wrap around paint scheme. The air intakes never changed. What you have in the trumpeter box will be fine for a Vietnam bird. I do think you have to remove a couple of stiffner plates as these were not on the Vietnam birds. I will check and come back to you. Edited February 24, 2014 by Ken Stetzenko mark31 1 Link to comment Share on other sites More sharing options...
Lee White Posted February 24, 2014 Share Posted February 24, 2014 With regards to the spine, early 105s had a flat area between the aft "point" of the spine, and the base of the fin. Combat experience showed Republic that it was important to re-route some systems from the bottom of the plane to the top, and thus a 1/2 "pipe" shaped cover was used over the new system location. That is on the Trump kit, and most others. I can only point to the hump on later A-4's as something similar. The F-105 at the Wings over the Rockies Museum is supposedly the only Thud that never received this modification. mark31 1 Link to comment Share on other sites More sharing options...
Dave Williams Posted February 24, 2014 Share Posted February 24, 2014 (edited) AFAIK, the enlarged spine was only a feature if the very few Thunderstick II conversions., not an early/ late feature. I don't think the D intakes were ever changed. For me the early/late features are things like the strike camera under the nose, ECM bumps on the tail, and the afterburner cooling scoops on the side of the rear fuselage. Regarding the spine, I think the small narrow spine running to the tail wasn't originally on early Thuds. I think it was added during the war and covered lines for a backup hydraulic system. Edited February 24, 2014 by Dave Williams mark31 1 Link to comment Share on other sites More sharing options...
mark31 Posted February 24, 2014 Author Share Posted February 24, 2014 Many thanks for the repleys. Mark Link to comment Share on other sites More sharing options...
mark31 Posted February 24, 2014 Author Share Posted February 24, 2014 I whas tinking for going NMF finnish so that will be a early. Now i know where to look at in de pics. Mark Link to comment Share on other sites More sharing options...
Rob Colvin Posted February 24, 2014 Share Posted February 24, 2014 (edited) To do a NM/ Silver painted F-105 D......you will have a little work ahead...It kind of comes down to aircraft. 1 The spine has to be removed, and vertical smoothed into the fuselage 2 "Aircraft dependent" the RWR and strike camera have to go 3 The reinforcement plates under the wings should be removed 4. Step 3 forces a fill on the wing pylons to make them flush 5 The reinforcement plates/ ram air scoops on the rear of the fuselage should be removed for "most" aircraft. I have seen a couple of pics of silver birds with the ram air (look close) Then there are the "fixes" to make the kit closer to an F-105....those are all well documented look here this guy captured most of the changes http://www.largescaleplanes.com/articles/article.php?aid=1568 Edited February 24, 2014 by Rob Colvin Link to comment Share on other sites More sharing options...
mark31 Posted February 24, 2014 Author Share Posted February 24, 2014 To do a NM/ Silver painted F-105 D......you will have a little work ahead...It kind of comes down to aircraft. 1 The spine has to be removed, and vertical smoothed into the fuselage 2 "Aircraft dependent" the RWR and strike camera have to go 3 The reinforcement plates under the wings should be removed 4. Step 3 forces a fill on the wing pylons to make them flush 5 The reinforcement plates/ ram air scoops on the rear of the fuselage should be removed for "most" aircraft. I have seen a couple of pics of silver birds with the ram air (look close) Then there are the "fixes" to make the kit closer to an F-105....those are all well documented look here this guy captured most of the changes http://www.largescaleplanes.com/articles/article.php?aid=1568 Thanks for the info and the link. I have seen those pics and thats why im asking abou the difrences maybe one day............ F-105s went through "Project Lookalike" starting in about 1959. They went from actual bare metal finish to a painted aluminum finish. The vast majority of D's were painted that way prior to the advent of SEA camouflage starting in 1965-66. Thanks Mark Link to comment Share on other sites More sharing options...
thierry laurent Posted February 24, 2014 Share Posted February 24, 2014 Hi Mark, This may be useful as well: http://forum.largescaleplanes.com/index.php?showtopic=40546 Cheers Thierry Link to comment Share on other sites More sharing options...
