Dpgsbody55 Posted March 23, 2023 Share Posted March 23, 2023 (edited) Here is my latest model build, ICM's Yak-9T. The model represents a Yak-9T of the VVS 3rd Fighter Group active in the Kursk region of Ukraine in 1943. Like all recent ICM kits this is another fine kit and an enjoyable build. The kit is well detailed as we've come to expect from ICM and parts fit is generally very good. My model has almost no filler anywhere, and the wing to fuselage join is excellent. The biggest area of concern to me was the way the undercarriage fits, which to me is not that positive. However, with a little thought and care, it still appears to be a strong enough joint for the job. You can find my WIP on this model here. The model is enhanced with Eduard etch cockpit details and seat belts, and the exhausts are Eduard Brassin 3D printed plastic. I've done very little in the way of weathering, just enough to give it a little life. As most of the plane was wood, the usual scratching doesn't really apply, so I've confined myself to some stains to take away the factory fresh look. The model comes with a representation of the Klimov V-12 engine as well as the armament consisting of a 37mm engine mounted cannon and a 12.7mm UBS machine gun. This can be built in detail and the cowlings left off, or just the barest engine to mount the prop and cowlings fitted. However, I've built mine with the detailed engine and guns, and also made the cowlings fit over this. The only compromise is the cowling frames can't be glued in and go on in place of the cowlings when I display it opened up. I've also made the canopy slide. One final modification is to the ammunition boxes which are not well detailed. I cut out that detail and added a string of bullets to each of these, made from left over etch ammo belts from a P-47 build. These modifications are very easy to do and don't detract from the finished product. Here's the photos. Definitely a good build and one I'm happy to recommend. It looks good next to my Special Hobby Yak-3. Cheers, Michael Edited March 23, 2023 by Dpgsbody55 Cicciuzzo, mywifehatesmodels, MikeMaben and 7 others 10 Link to comment Share on other sites More sharing options...
Rampenfest Posted March 23, 2023 Share Posted March 23, 2023 Well done! Dpgsbody55 1 Link to comment Share on other sites More sharing options...
Cicciuzzo Posted March 23, 2023 Share Posted March 23, 2023 Ben fatto Dpgsbody55 1 Link to comment Share on other sites More sharing options...
Greif8 Posted March 24, 2023 Share Posted March 24, 2023 I enjoyed following your build of this aircraft Mike. It is a real eye-catcher. Ernest Dpgsbody55 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 24, 2023 Share Posted March 24, 2023 Looks great Mike Dpgsbody55 1 Link to comment Share on other sites More sharing options...
Dpgsbody55 Posted March 26, 2023 Author Share Posted March 26, 2023 On 3/24/2023 at 3:52 PM, Greif8 said: I enjoyed following your build of this aircraft Mike. It is a real eye-catcher. Ernest Thank you. I enjoyed building it and I'm pleased with how it turned out. It's nice to have something different to work on too, so looking forward to see what ICM have lined up for next year. On 3/24/2023 at 4:43 PM, MikeMaben said: Looks great Mike Thanks Mike. It turned out well, but there's a couple of things I'd do differently if I do a Yak-9K. Cheers, Michael MikeMaben 1 Link to comment Share on other sites More sharing options...
