Stuka Posted January 29, 2022 Posted January 29, 2022 Hey Guys, Liquitex Flow-Aid and Slow-Dri are two reagents I've used with every acrylic paint I've shot in the last 20 years. Issues common to spraying acrylic paints like like tip-dry, clogging, intermittent spraying, and dry, over-spray are all drastically reduced by the addition of Slow and Flow to your favorite acrylic thinner or acrylic paint mix. After a protracted search I've found a reliable supplier of Liquitex products that allows me to put them on MPS at a reasonable price. Here's a line to an article describing how to use Liquitex Slow and Flow when diluting/spraying acrylic primers, paints, or clear coats: https://modelpaintsol.com/guides/liquitex-flow-and-slow-the-tools-for-taming-acrylic-paints Thanks! --John Elftone, thierry laurent and coogrfan 2 1
denders Posted February 4, 2022 Posted February 4, 2022 Thanks for the article. I've been experimenting with Flo and Slo since listening to a previous mojo podcast. I need to experiment with it in Stynylrez primer. Dave
Colin F Posted January 16, 2023 Posted January 16, 2023 It’s important to add that the Slow-Dri being mentioned is the Additive, not the Medium, both of which exist in the Liquitex lineup. Additionally, Flow-Aid is a concentrate. It’s meant to be diluted 1:20 with water or thinner right out of the bottle. So, it’s not 5% to an airbrush cup, it’s 5% to a thinner mix which you’ll then thin your paint with as normal. Christa 1
KUROK Posted February 4, 2023 Posted February 4, 2023 On 1/16/2023 at 10:14 AM, Colin F said: It’s important to add that the Slow-Dri being mentioned is the Additive, not the Medium, both of which exist in the Liquitex lineup. Additionally, Flow-Aid is a concentrate. It’s meant to be diluted 1:20 with water or thinner right out of the bottle. So, it’s not 5% to an airbrush cup, it’s 5% to a thinner mix which you’ll then thin your paint with as normal. The 1:20 dilution in water that is recommended by Liquitex is for brushing, no?
Stuka Posted February 6, 2023 Author Posted February 6, 2023 Hey Folks, I get the question about diluting Liquitex Flow-Aid 1:20 before using it a lot through my site. I don't prepare a 1:20 and never have. I use it neat; straight from the bottle and have for 20 years w/out an issue. I usually add it to all my acrylic thinners to 5 or 10% by volume depending on what I intend to use the thinner for (general work or fine-line, respectively). Using it neat also allows you to "spike" an airbrush paint cup with just a few drops of Flow but have a demonstrable effect on tip dry since it's concentrated (not diluted). I hope that helps:) Let me know if you have any questions. Best, --John Elftone 1
