Padraic Conway Posted January 31, 2019 Posted January 31, 2019 (edited) Thanks Vincent; that seems like a fair suggestion to consider. It's noteworthy that we don't appear to see much evidence of flaking/worn paint on contemporary Luftwaffe pictures (I'm thinking of the degree to which Japanese aircraft suffered from flaking/worn paint in the final years of the war), so when an airframe was painted, it was done to a fairly high standard by and large. Perhaps its also possible that towards the end of the war the expected lifetime of the airframe might be measured in days, rather than weeks or months? Then we see increasing tolerance of bare metal or incomplete painting of airframes (especially Me262s, Fw190s and He162s). It would be interesting to know how well RLM76 (or any RLM paint) adhered to bare metal, as opposed to a primer paint. Padraic Edited January 31, 2019 by Padraic Conway Correct grammatical atrocity D.B. Andrus 1
Guest Vincent Posted January 31, 2019 Posted January 31, 2019 (edited) Removed contribution Edited February 2, 2019 by Vincent/MDC
Padraic Conway Posted January 31, 2019 Posted January 31, 2019 14 minutes ago, Vincent/MDC said: the combo rlm76 will stay on until end of time OR until a crack appears in the outer layer of the paint. Then it will slowly start to chain flake as corrosion makes it way underneath the outer layer which is typically semi gloss. Upon drying the "varnish" part of the paint migrate to the surface while the pigments and passivizing components stay in a rather porous state so that the metal can flex without the paint cracking. But it was good stuff, until the very end. What wasn't good at the end were the painters and the way they applied the paints. I will give you an example : one finnish G2/trop rebuilt in 1943 spent about 60 years in the baltic. When lifted, the RLM79 on the wings was basically like new So perhaps it was very effective both with or without a primer undercoat? There's certainly photographic evidence of RLM76 applied directly to bare metal late war (thinking of Bf109G wings in handling crates at Prague airport) and RLM81 applied to the metal sides of Me262s (Yellow 3 of KG(J)54 - the subject of the Experten decals) where the panel sealant can be seen through the green paint. D.B. Andrus 1
mattlow Posted January 31, 2019 Posted January 31, 2019 There's a series of Signal magazine photos of one of the Bf 109G production lines where all the aircraft are painted in a light blue colour (I always thought it looked more like RLM 65 but that could be due to age of photos etc). The use of 76 as a primer answers the overall application of the colour which had in the past seemed a little illogical. That would also explain (as we'd touched on way back - Gazzas I believe) the overall 76 airframes coming out of Mtt after they lost their paint shop. I can't get to my books at the moment, but I'm sure there's a two part number reference for RLM colours. If I recall half refers to the pigment and the other (I suppose) to whether it was a 'primer' or non-'primer' I suppose it may also have indicated whether it was suitable for 'priming' metal or wood. Case in point I recall is RLM 99 which could have been the red oxide colour or a green hue or others as the 99 referred to the priming quality, not the colour. Am I horribly wrong there? Matt D.B. Andrus 1
mattlow Posted January 31, 2019 Posted January 31, 2019 I believe I have seen the images of Me 262s with a very thin spray of RLM 81 that does allow the putty in the panel lines to show through. That would suggest that 81 maybe was also a 'combo' paint (I like that term).. It would surely make sense to make any of the new primary camo colours 'combo' paint formulations for exactly the reasons you've mentioned Vincent (weight/time/resource use) why paint entire airframe in 76 if you can use the uppersurface camo colours without an undercoat as well.. I'd assume the formulation could be given any pigment you wished, so it'd merely be a case of applying the RLM 81/82 pigmentation to the 'passivizing components' and you have uppersurface 'combo' paint. I suspect you may tell us it wasn't quite that straightforward? Matt D.B. Andrus 1
mattlow Posted January 31, 2019 Posted January 31, 2019 So finding a document mentioning 7122 .81 or 7122 .82 would be rather useful.. D.B. Andrus 1
mattlow Posted January 31, 2019 Posted January 31, 2019 Aha! Thanks. But our friends RLM 81 and 82 would be no problemo as they are (in their recorded variety) always green or brown (violet).. so they could be produced as combo paints... I can really buy into the idea of 76 becoming more green/yellowish as the quality of the blue-grey pigment got worse... Thanks Vincent, I feel like I am actually learning some useful stuff here. Matt D.B. Andrus 1
mattlow Posted January 31, 2019 Posted January 31, 2019 Useful... Just because it is one of the only 'higher number' colours we haven't mentioned, what about RLM 80. I sometimes wonder if it is to be more associated with 78 and 79 or with the 'green group' of (80) 81 and 82.. Do we know how it came about? was it 'designed' to complement 79 on uppersurfaces of tropical schemes? I hardly ever even think of RLM 72 and 73 but just thought I'd mention them for completeness. Did they have a special formulation due to their maritime application? Regarding your last post, is the 7140/7141 indicating the use as a finish suitable for wood? D.B. Andrus 1
