D.B. Andrus Posted January 9, 2019 Share Posted January 9, 2019 Decided to move my discussion in Pastor John's Erla G-10 thread to give him some breathing room. LSP_K2, nmayhew, LSP_Matt and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 9, 2019 Share Posted January 9, 2019 46 minutes ago, D.B. Andrus said: Decided to move my discussion in Pastor John's Erla G-10 thread to give him some breathing room. You can copy/paste your comments from there to here if you wish, Damian. D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Hardcore Posted January 9, 2019 Share Posted January 9, 2019 What intrigues me, among many things, is that it appears to exist both a true mono colour scheme, and one almost - but - probably - not - after - careful - examination - of - photos. (I hope the Germans will dig up some documents on that!) My thinking is that both where done at the factory. It simply is no logic to the idea of such big paint jobs being done at unit level. If they wanted extra cover on the ground there where camo netting to use, tree lines to disperse the aircrafts to, and simple overspraying of the blue gray sides with anything at hand. Speaking of the later we got remarkably neat paint jobs. Link to comment Share on other sites More sharing options...
D.B. Andrus Posted January 9, 2019 Author Share Posted January 9, 2019 37 minutes ago, LSP_K2 said: You can copy/paste your comments from there to here if you wish, Damian. I'll do that, thanks. LSP_K2 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted January 9, 2019 Author Share Posted January 9, 2019 Here's something to stir the late color pot: Original. B&W conversion Bf 109G-14 WNr. 785 XXX Wels, May, 1945. Looks like brown 81/82 to me. Same a/c as above, but earlier time frame? This is an interesting one. Brown 81/82 as well? Cheers, D.B. RBrown and Martinnfb 2 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted January 9, 2019 Author Share Posted January 9, 2019 Here's another interesting example: The Grafenwohr G-10 in B&W Screenshot of same a/c in high contrast color. Note NMF on outer wing under surface. Photo lightened substantially showing a patch of brown outboard of the port wing root and the outer l/e, as well as on the starboard l/e near the wingtip. It may may point toward the fuselage being two colors rather than one color overall. Personally, I'm leaning toward 81/70 rather than 82.......take a look at the prop and wing l/e's. Cheers, D.B. Martinnfb and RBrown 2 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted January 10, 2019 Author Share Posted January 10, 2019 Here are a few late FW 190A's: As you can see the schemes run the gamut of combinations. Personally, I don't use color photos to determine an exact shade, rather to tell if the colors tend toward a green, brown or grey. Yet this method can also be fraught with chances of misinterpretation. In the end you roll the dice and take your chances. Love this subject! Cheers, D.B. MikeMaben, nmayhew, Alain Gadbois and 3 others 6 Link to comment Share on other sites More sharing options...
Padraic Conway Posted January 10, 2019 Share Posted January 10, 2019 Slightly OT from 81/82, but still within the colour debate, those first 2 FW190 shots beautifully illustrate the distinction between late war 76 (almost chalky white by this time) on the cowl underside and oil cooler ring, compared with the un-numbered beige colour used underneath the wings. I have read a description of this shade as 'concrete' - which seems pretty accurate to me! But a world away from 76 in its usual form... D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Guest Vincent Posted January 10, 2019 Share Posted January 10, 2019 (edited) Removed contribution Edited February 2, 2019 by Vincent/MDC Link to comment Share on other sites More sharing options...
Padraic Conway Posted January 10, 2019 Share Posted January 10, 2019 2 hours ago, Vincent/MDC said: By the way, about the beige color or so called RLM84 : I have several Fw190 D9 parts wih this color. I took a couple of them to try to establish the origin of that color. In both cases, i found, pigment wise, a normal RLM76 but the greenish tint came from what appeared to be pigment carrier oozing on top of the pigmented layer in this greenish hue. With model, i was able to reproduce the exact same effect by painting the part in RLM76 first then overspraying a layer of diluted tamiya clear green. Therefore i'm with Mr Ullman on that one : the so called RLM84 is plain normal RLM76 where the binding agent has turned green and oozed over the pigments. Why is that is another question but what is clear is that the painters were applying paint labelled RLM76 at that time Mindful of thread hijacking here, but... With the greatest of respect to Vincent I feel the issue around lower surface colours I highlighted in this case is more complex than just a bad mix of pigment and binder. I would offer a number of points to support this proposition Look again at the 2 FW190s above. The underwing paint isn't the greenish 'RLM 84' but a beige/concrete colour that is quite different from either 76 or the so-called 84 Being applied right next to 'conventional RLM76' in the same print frame means that we can discount any photographic shift or print degeneration as the cause The old 'Monogram Painting Guide' offered a number of 76 variants that are generally still accepted within Luftwaffe camo debates as valid when compared to real aircraft parts (as I acknowledge that Vincent has done), so the situation is more complicated than poor binder in some 76 paint So we are off to the races with multiple shades of undersurface paint on late war airframes - some bluish, some greenish and some beigeish. (New word there ) RLM 76 itself varies significantly from a light blue to chalky almost white Some airframes are painted in three or more different underside colours (the RAAF Bf109G for one example), with shades on the same airframe including white/blue, concrete and the 'sky' lookalike widely referred to as 'RLM84' (although I use that term reluctantly as it has no formal meaning backed by RLM documents, but rather is a label now in widespread use). The RAAF airframe is accepted as a rebuilt airframe (that doesn't necessarily negate my point about 3 different colours), but for an everyday airframe FW190D-9 Blue 12 is another example with varied undersurface colours Finally, I fully accept Vincent's (and Michael Ullman's) proposition that some examples of late war greenish undersurface paint could be as a result of solvent and pigment changes within RLM76. I feel however that this theory doesn't easily account for all the observed colour variations from period evidence and the points I have presented above. Phew! Padraic RBrown, Troy Molitor and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
LSP_Mike Posted January 10, 2019 Share Posted January 10, 2019 An interesting discussion. One thing for sure, is that we still have an almost infinite variety of paint options. I'm learning a bunch here. D.B. Andrus 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted January 10, 2019 Author Share Posted January 10, 2019 In photos 1-3, 5 & 6 there appears to me a use of a brown hue in combination with a green and/or gray. My determination is this is brown 81, given the limits of the color photography in these particular cases. Kiroff's formula for 81 leads to a brown color. With that said, how do we explain the original container Tomas Poruba has in his possession marked as 81 yet containing a green hued RLM paint. Could it be as simple as if the can was marked as 81, for example, then the color in the can, whether it was green , brown or purple was officially 81 in that instance? Link to comment Share on other sites More sharing options...
Guest Vincent Posted January 10, 2019 Share Posted January 10, 2019 (edited) Removed contribution Edited February 2, 2019 by Vincent/MDC expired picture Link to comment Share on other sites More sharing options...
