BradG Posted August 16, 2016 Share Posted August 16, 2016 This is the Trumpeter kit in 1/72, with Red Roo Decals. I cut out the radome from the lower fuselage and filled it with plastic card as the T2's didn't have this fitted. The instructions also have you put the flaps down, but I glued them in the up position. As usual, fit of the parts was hit and miss, with the major sections fitting nicely, but the smaller parts left a bit to be desired. Unfortunately I screwed up the paint job the first time around and it has sat in my cabinet half finished since January, but with Wings Model Show coming up I pulled it out, sanded down the rough as guts paint and repainted it. I was unable to cram enough weight in the nose to make it sit so I whipped up a base from an MDF board, sanded and painted with a little MiniNatur grass to add some interest and glued the model down. Derek B, Alex, CJP and 1 other 4 Link to comment Share on other sites More sharing options...
Jack Posted August 16, 2016 Share Posted August 16, 2016 Now, THAT i would like to see in 32nd scale, how bout you??? BradG 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted August 16, 2016 Share Posted August 16, 2016 Pretty crisp work mate. Good stuff! Jim BradG 1 Link to comment Share on other sites More sharing options...
BradG Posted August 17, 2016 Author Share Posted August 17, 2016 1/32 would be impressive! I kept it pretty clean because the real ones looked very well maintained. Even in the scrap yard, they were stripped but not particularly dirty. Jack 1 Link to comment Share on other sites More sharing options...
JohnWMorale Posted February 4, 2021 Share Posted February 4, 2021 (edited) On 8/16/2016 at 4:19 PM, BradG said: This is the Trumpeter kit in 1/72, with Red Roo Decals. I cut out the radome from the lower fuselage and filled it with plastic card as the T2's didn't have this fitted. The instructions also have you put the flaps down, but I glued them in the up position. As usual, fit of the parts was hit and miss, with the major sections fitting nicely, but the smaller parts left a bit to be desired. Unfortunately I screwed up the paint job the first time around and it has sat in my cabinet https://sheetmaterialswholesale.co.uk/ half finished since January, but with Wings Model Show coming up I pulled it out, sanded down the rough as guts paint and repainted it. I was unable to cram enough weight in the nose to make it sit so I whipped up a base from an MDF board, sanded and painted with a little MiniNatur grass to add some interest and glued the model down. Lovely clean finish there, nice to see a RAN Gannet. Edited February 4, 2021 by JohnWMorale BradG 1 Link to comment Share on other sites More sharing options...
