Harold Posted July 19, 2016 Posted July 19, 2016 (edited) Our buddy Harv twisted my arm......a bit more refinement and he will have his brand spanking new radar pod. Edited August 26, 2016 by Harold Vandy 1 VX 4 and Kagemusha 2
Martinnfb Posted July 19, 2016 Posted July 19, 2016 Gallant gesture from one gentleman to another. Hats down.
Harold Posted July 19, 2016 Author Posted July 19, 2016 Gallant gesture from one gentleman to another. Hats down. Harv was good enough to send a wing to use for prototyping.
Guest Posted July 19, 2016 Posted July 19, 2016 Quick question Harold , I was under the impression that the top didn't taper at the back end. Your thoughts?... Harv
Harold Posted July 19, 2016 Author Posted July 19, 2016 Quick question Harold , I was under the impression that the top didn't taper at the back end. Your thoughts?... Harv The wooden prototype did. The production tapered back but I think had a flat section on/under the rear of it, but I can't find good refs that show it.
Harold Posted July 19, 2016 Author Posted July 19, 2016 The wooden prototype did. The production tapered back but I think had a flat section on/under the rear of it, but I can't find good refs that show it. I think I have enough info now to correct the upper fairing.
ziggyfoos Posted July 21, 2016 Posted July 21, 2016 Are you doing a full F4U-2 conversion or only the pod? Harold 1
Harold Posted July 21, 2016 Author Posted July 21, 2016 Are you doing a full F4U-2 conversion or only the pod? So far, just the pod itself. Maybe more later.
Guest Posted July 21, 2016 Posted July 21, 2016 There is a small air scoop for the generator on the right side near top by fiterwall.....Harv
Harold Posted July 21, 2016 Author Posted July 21, 2016 There is a small air scoop for the generator on the right side near top by fiterwall.....Harv Plus the exhaust, right?
Guest Posted July 21, 2016 Posted July 21, 2016 Yes. Exhaust flame dampers. The LS set also has bomb racks that look pretty good. There is also the radar scope for the IP. But there are NO pics of it so don't know how accuret it is....Harv
Harold Posted July 22, 2016 Author Posted July 22, 2016 Yes. Exhaust flame dampers. The LS set also has bomb racks that look pretty good. There is also the radar scope for the IP. But there are NO pics of it so don't know how accuret it is....Harv Thanks Harv, I will have to do some research.
