Metallicus Posted January 26, 2011 Share Posted January 26, 2011 that is some great work you are doing!! Cant wait for more Link to comment Share on other sites More sharing options...
blackbetty Posted January 27, 2011 Author Share Posted January 27, 2011 thanx brenden! i worked some more on the wells (pretty boring, huh?) made a box out of sheet, using the eduard part for the roof Link to comment Share on other sites More sharing options...
blackbetty Posted January 27, 2011 Author Share Posted January 27, 2011 since the part is too small i added self made strips of ribbed material on the sides and the strengtheners on top i had a pretty hard time bulging in the rear part, but finally managed Link to comment Share on other sites More sharing options...
blackbetty Posted January 27, 2011 Author Share Posted January 27, 2011 some boxes went between the little spars on the outside Link to comment Share on other sites More sharing options...
blackbetty Posted January 27, 2011 Author Share Posted January 27, 2011 i have one side finished and it actually snaps in place Link to comment Share on other sites More sharing options...
blackbetty Posted January 27, 2011 Author Share Posted January 27, 2011 it is not totally correct, the rear bulged part should be higher it dawned to me that the upper fuselage skin might be the actual roof of the well gona think about this a little more.... Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 27, 2011 Share Posted January 27, 2011 NICE! I always like little detail additions that PE brings to applications like this........vents look really great. Cheers, Brian Link to comment Share on other sites More sharing options...
Loic Posted January 27, 2011 Share Posted January 27, 2011 Lovely job Carl, I like it a lot mate! Cheers Loic Link to comment Share on other sites More sharing options...
mattlow Posted January 27, 2011 Share Posted January 27, 2011 Beautifully crafted Carl. You'll have a uniquely accurate Mig 29 at the end of this. Your extreme patience and staying power is an inspiration. Matt Link to comment Share on other sites More sharing options...
Martinnfb Posted January 29, 2011 Share Posted January 29, 2011 You must just love Mig-29, otherwise there is no explanation for this kind of work. SPLENDID!!! I am amaized and thrild by every post of your progress, keep it comming. Thanks Martin Link to comment Share on other sites More sharing options...
blackbetty Posted January 31, 2011 Author Share Posted January 31, 2011 thanx for watching my build and the kind comments brian, loic, matt and martin! walked away from the bench for a day or two, then sat down and took a good hard look at the wells and decided they wont do. i will try and use the uppere fuselage as a roof, that should not only give me the desired depth, it should also have the right curvature of the roof, as well as the taper present to the front and back first i marked the position of the well i made against the upper fuse Link to comment Share on other sites More sharing options...
blackbetty Posted January 31, 2011 Author Share Posted January 31, 2011 then i ground off the raised portion that serves as a base for the fin on top Link to comment Share on other sites More sharing options...
blackbetty Posted January 31, 2011 Author Share Posted January 31, 2011 this would be in the way of the well i taped on to get an idea of the depth i was after Link to comment Share on other sites More sharing options...
blackbetty Posted January 31, 2011 Author Share Posted January 31, 2011 voilá, the gap tells the story, i think its worth doing the wells over Link to comment Share on other sites More sharing options...
blackbetty Posted January 31, 2011 Author Share Posted January 31, 2011 so i broke the previously scratched wells (i had done both before thinking ) Link to comment Share on other sites More sharing options...
