bcauchi Posted June 17, 2007 Author Share Posted June 17, 2007 Been working on some details on the underside of the aircraft. These include the fuel overflow, a streamlined opening on the underside of the rear fuselage, the fuel feed lines from the external centreline tank, the overflows just under the front wing root and also the anchor points for the tank cradle. here is a photo showing most of these details. These have been produced three times. The fuel feed lines are made from wire sheating, the overflows from hypodermic needles and the anchor points from sheet aluminium. Link to comment Share on other sites More sharing options...
bcauchi Posted June 17, 2007 Author Share Posted June 17, 2007 Also did work on the undersarriage. The doors have been modified. The upper part is way too thick, the lower part has been sanded and thinned down. The upper part has been replaced by one made from thin plastic card. also the guide rod for this has been made. The hydraulic lines which were molded on were removed and remade with copper wire and brass nuts. Link to comment Share on other sites More sharing options...
bcauchi Posted June 17, 2007 Author Share Posted June 17, 2007 Sorry for the qaulity of the photos. I shall try to retake them with a different camera. Link to comment Share on other sites More sharing options...
Schwarze 1 Posted June 18, 2007 Share Posted June 18, 2007 That's just way too much for me to handle. My Sturmbock is nothing compared to that!!! Link to comment Share on other sites More sharing options...
AngoMango Posted June 18, 2007 Share Posted June 18, 2007 Brilliant work yet again Brian. You continue to amaze and inspire. Were the brass nuts that you used on the hydraulic lines from the same supplier that Klaus gets his? They look wonderful, however, I'd love to see more pics showing those components in greater detail. Keep em coming mate! Cheers Ango Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted June 18, 2007 Share Posted June 18, 2007 Hi Brian, excellent work there! Can´t wait to see you start painting! Cheers, Chris Link to comment Share on other sites More sharing options...
bcauchi Posted June 18, 2007 Author Share Posted June 18, 2007 Thanks guys, yes Ango, those are the same brass nuts. They look ok. i wish the photos were better. I desperately need a new camera. Link to comment Share on other sites More sharing options...
bsarnoffca Posted June 18, 2007 Share Posted June 18, 2007 Very, very nice Brian. Link to comment Share on other sites More sharing options...
bcauchi Posted July 3, 2007 Author Share Posted July 3, 2007 Hi guys I have completed the undercarriage for all three planes and I can finally post some decent pics. Excuse the repetition but I got carried away. Link to comment Share on other sites More sharing options...
bcauchi Posted July 3, 2007 Author Share Posted July 3, 2007 That was the undercarriage for the old revell 109. The doors are kit's modified/scratched and the wheel legs are brass. Torqu links and other details are scratched. Link to comment Share on other sites More sharing options...
bcauchi Posted July 3, 2007 Author Share Posted July 3, 2007 Another Link to comment Share on other sites More sharing options...
bcauchi Posted July 3, 2007 Author Share Posted July 3, 2007 Detailed/corrected kit parts. I think I already explained that the kit doors are way too thick and the upper part of the wheel cover was separate and had a sliding guide rail to keep alignment. Link to comment Share on other sites More sharing options...
bcauchi Posted July 3, 2007 Author Share Posted July 3, 2007 Last pic. Sorry but I got carried away trying out my new camera. But at least you can finally see the work better. Link to comment Share on other sites More sharing options...
JCote Posted July 3, 2007 Share Posted July 3, 2007 Hi Brian, Your updates are relatively few and far between, but ALWAYS more than worth the wait and leaving us wanting more. Quite apart from your peerless skills, I'm particularly impressed by the fact that you have the patience to do three concurrent builds from very diverse kits and achieve such consistent and uniform excellence. Best Regards, Jean P.S. Thanks so much for the contact in B.C. Haven't worked up the nerve to use it yet, but I will at some point. P.P.S. Your new camera really makes a difference! Link to comment Share on other sites More sharing options...
