Bobsyouruncle
LSP_Members-
14 -
Everything posted by Bobsyouruncle
What a collection. Completely awesome.
1/18 P51C Mustang "Lopes Hope the 3rd"
Bobsyouruncle replied to airscale's topic in Works in Progress
Amazed every time I come across an upgrade on this beauty. -
That's a gorgeous looking Mustang. Superb.
Typhoon bubbletop bomber ZippX, Airfix
Bobsyouruncle replied to Bobsyouruncle's topic in Works in Progress
In a small window of spare time I had, I managed to tackle a couple of areas that I'd been thinking about. The first one was the spinner. Not everyone will see it how I do, or bother about it, but (to me) the four bladed spinner looked a little too long when seen from the side, compared to photos. I decided to see what I could do to try and convert the short 3 bladed spinner to a four bladed one (with some filing I thought this shape looked more accurate and a better length). First thing was to file to shape and fill in the 3 blade apertures. For added strength, especially when cutting four blade apertures, I first cut down and inserted the other 3 bladed spinner within this one. When filled, the spinner looked like this. I sat it on a plan of the prop to show where the 4 blade apertures needed to go. I wanted the spinner to have the correct shaped apertures and not to have to use the raised triangular parts which are on the Airfix baseplate (I removed those). Note the 'scoop' into the baseplate also at the spinner apertures in my rough sketch. Here's how the internals of the spinner looked after cutting the apertures. I rotated the inner spinner through 60 degrees to the outer to reinforce areas. This is it when tried with the 4 blade prop. And again from the side (you can just see a scoop in the baseplate). To see how the shape matched up from the side to the real thing, I held it in front of an online Imperial War Museum shot of Harry Hardy's Pulverizer IV (IWM MH6865), using a spare brush handle and a blob of blu-tac. To my eyes, it's a good enough match (note the actual topline just above my spinner). That left me here so far, with the wing lower half on cannon bay started and a new spinner. The other area that I'd been thinking about was the radiator cover and Vokes air filter (for the Normandy dust). Airfix give a front piece for this, but I wanted to add a little more in this area. I decided the best way around this for me, was to assemble the front of the radiator housing and match it with the rest at a later date. Here are the raw materials for my filter. What we've got here is a length of plastic strip, the body of a ballpoint pen, size 12mm, 10mm and 8mm plumbing olives and what's left of the stoneguard mesh radiator protector with the centre part removed (thought I'd save part 16 as a back-up). First thing I did was cut the strip into small lengths which were glued around the pen body (to make the filter). I cut down a 12mm olive for the ring at the back of the filter. The smaller ring was from the 10mm Olive and this was for the front 'cuckoo doors' face. The 8mm Olive was a perfect fit for the filter to mount on, in the centre of the radiator (shown inserted). This allowed the filter to positioned correctly. This shows the assembled radiator housing front (cut down from the original parts). I wanted to use something strong and maleable for the frame that holds te filter in the radiator intake (plastic strip just snapped when bent). My son Matt, found this piece of thin steel that he'd brought back from his college work. I was able to cut this into strips (one on the right). So this is what I then ended up with. This shows my filter with a modified Airfix part on the front, ready to mount into the radiator intake frame. This in front of the radiator shows how the filter sits in front of the radiator (on that brass olive). This one is a loose dry-fit test of the parts together. Looks a little rough now, but I think it'll be ok after some tidying up work, (filing and sanding, perhaps thinning the filter 'blades' a little, proper positioning and a some careful painting). Cheers Bob. -
Great to see a 'Bombphoon' and a really nice job on the Pulverizer.
1/32 Tamiya Spitfire Mk.IXc, "Kicked Up A Notch"
Bobsyouruncle replied to chuck540z3's topic in Ready for Inspection
What a beautiful Spit. Lovely work. -
Thanks very much for the encouraging words and welcomes, Gents. Hope to get back on with this when I've finished this other Lightning painting for someone. I was really enjoying it. I'd just started the cannon bays and was thinking about how the different type 20mm rounds (AP, HE, etc.) are arranged on the belt and whether to replace with brass rod segments. Hi Rob, it's a mix of different diameter wires called 'beading wire' (for threading beads onto) from my local hobby shop and copper electrical wire, plus the outer casing sheaths from some electrical wires (for the wider pipes). Cheers, Bob. -
Hi Gents, this is my first post here on stuff I'm actually doing myself, so hope it's not so rough you have to look away. I'm working on the Airfix bubbletop Typhoon and hopefully heading towards Johnny Button's MP195 Zipp X with a couple of 1000 pounders slung underneath. I had to break off to do a painting for someone, but have got the lower wing on now. Here's some shots to show progress so far:- Started on the regular cockpit parts I won't be having the fuel tank on display, so if it's another colour it doesn't matter (to me). Started adding some additional details to this area as I want to leave this panel off, including an extra pipe to the engine (that I'd seen in photos of the real ones). I decided to articulate the control column (as I figured it would be forward when the elevators droop, but didn't know how far). Stick fully forwards Originally my engine started like this, with just some extra lines added near the supercharger and hexagonal joints added. I'd also committed to replacing the ignition leads with my own. Initially, I put the Airfix pipe part on, going to the generator on top of the engine, but after looking at photos.... .....I removed a section of it and replaced it with this one. I also changed the pump type and added the offshoot piping. At this point I slightly drifted ahead, thinking about the windscreen framing. In photos, the external framing is minimal so I thought about making a replacement. This is the first prototype. After deciding it might work, I went back to the engine. I loved the Radu Brinzan radiator, so had to have one. As I'd decided to only have the port side of the engine on display (with the top cowling on), I only concentrated on this side. A lot of the upper stuff goes out of sight with this on, unless you sneak a look from a low angle. Cheers Bob.
Amazing work. Just found this. Love what you've done here.
A Wee Side Project: 1/24 Cardoor Tiffie
Bobsyouruncle replied to Uncarina's topic in Works in Progress
Lovely work. A fair bit neater than mine and you work a lot faster too. great stuff. -
Hawker Typhoon walk around photos, just added
Bobsyouruncle replied to LSP_K2's topic in General Discussion
John, Hi, I've been trying to research about one of your Uncles aircraft as the subject and would definitely be interested in seeing any photos please. I'm using the Airfix 24th scale kit and would ideally like it to be MP195 (DP-Z) Zipp X. I came across some IWM film footage showing a little of the starboard side and nose, but haven't as yet managed to see anything of the port side in actual photo form. In the film, they were loading 'Nickle' leaflet cannisters for dropping on troop concentrations near Falaise around the 17th August. I dug out the Squadron ORB and saw that your Uncle flew this mission and also the 1000lb equipped raid six days earlier. Any photo or other information would be very welcome. Thanks Bob.
