Madmax
LSP_Members
  • Posts
    578
  • Joined
  • Last visited
  • Days Won
    4
Everything posted by Madmax
  1. Great insights, thanks Mike.
  2. That's Ok Craig, more entertainment for us!
  3. Epic, in many ways! I'm concerned that one day you are going to complete this...
  4. You've got me wondering Mike - new camera or new phone? Either way, the result is fantastic. Suddenly I can see the reddish brown tones in the weathered OD. Great stuff!
  5. Thank you! You are not alone in this Hunter breeding program. A mate of mine popped in yesterday, keen to see my progress on the model, but he clearly doesn't have access to the hormones or whatever you're feeding your kits - he only has 4 in his stash! Thanks Tony! Tricky question. I think that any extra weight aft of the main wheels will obviously require more weight in the nose, and it is quite a long lever arm to the back of the model. I have roughly measured it, and despite my 30cm jet exhaust exaggeration, it would actually be close to 21cm. I sadly don't have a Reskit exhaust (it wasn't available when I was ordering AM stuff way back when), so the question really is how heavy it is? I can't imagine too heavy, since it is a printed part. Checked it out online today, and it looks fantastic - wish I had one. I reckon one should just live with a heavier model, and buy brass gear legs!
  6. Back to the story. We last left XF309 in the capable hands of Hawker Siddeley Aviation(Ltd), where she was about to undergo an upgrade to FGA.9 standard. In her case, she was about to become what was known as an FGA.80, meaning that she was an FGA.9 destined for the Kenyan Air Force. Most FGA.9's were updated Mk.6's, but as you may recall, our star was a lowly Mk.4 dressed up as a Mk.5! She would be getting a big makeover, as explained in the following photograph of what I believe is a Mk.5, but will suffice for illustrative purposes. On completion of her transformation, our Hunter was ferried to (presumably Nanyuki) Kenya via Malta, where the prolific photographer, Mr John Visanich, took this photograph: https://www.airhistory.net/photo/390322/805 You will notice that she now carries the Kenyan Air Force serial number of 805. This is at odds with what some publications say, but I believe it to be correct. 'Wingleader Magazine', for example, had XF309 as becoming KAF 806, but that's just part of the intrigue of tracing an aircraft (or a racehorse's) provenance! The airfame 'Wingleader' touted for KAF 805 (WT778) was indeed sold to the Kenyan Air Force, but in pieces - as spares. Enough intrigue for now. Here is a colour photo of a Kenyan Air Force Hunter (803) as it passed through Malta in 1974, on its way to Africa. It would seem that Revell GmbH put their top team (the 'Chaps from Flaps') on tail-section and propulsion. Despite some warnings about the fit of these extremities, I found them to be superb. I can just imagine Kurt, Willy and Ernst, slide rules in hand, replicating such a very British part at 32 times smaller than it should be. Their team leader, Herr Pabst von Ohain (this is meant to be amusing) took this shrinking thing to a new level, and produced a 10500 lbs of thrust engine at 32 times smaller diameter, and about a 10th of it's scale length! This is a very good thing, as any more weight behind the main wheel axles would almost certainly make the model 'sit on its arse'. Here is a photo of the diminutive power-plant (the little tube below the ruler). The tail-section itself, with its drag chute housing, is beautifully moulded and fits perfectly onto the rear fuselage. The photo above shows it dry-fitted in place. In the photo below you can see how well the shape is reproduced. I merely added a little fictitious structure to the internal 'ribs' to finish them off where there is a gap on the top and bottom. The instructions advise glueing and taping the power-plant in place, but being a bit wary of the instructions, I dry fitted things first and discovered one can just pop the engine in afterwards. It does take a bit of imagination to look down 3cm of jet exhaust and imagine it to be 30cm, but maybe some very dark paint will help. The thermocouples were added in an attempt to create an illusion of depth. Lets see. Maybe a FOD cover instead? Cheers, Sean
  7. Thank you Paul! It is actually a lovely kit, so I have an easy job enhancing certain areas. Only solution, thanks Mike! If you look closely, you will actually spot mistakes in the riveting all over the show. Like many others who indulge in this insanity, I draw pencil lines where I think the rivets generally exist, and then free-hand the riveting wheel down the lines (or as close as possible). Often, the accuracy is better at a reasonable pace, so you don't have to concentrate for all that long! Give it a go sometime... Hi Max, thanks for checking in. Your Echelon Hunter must be very, very close to completion by now - but I notice there is often another Hawker aircraft to distract you.
  8. The rivets really make this pop! Excellent tonal values too...
  9. I have to admit that the air intake assembly has taken me a bit by surprise. It is a lovely bit of moulding, but it has an inherent design problem. Come to think of it, real intake ducting for full size jets must pose some engineering challenges too. The snag is that it has to slide into two grooves on the side of the fuselage, and in order to do that it has to be flexible since the grooves taper toward the front. The instructions don't really solve this puzzle, unless I have missed something? The first step indicates that the parts should be glued together, but held together with tape. I understood this as: tape will be required to hold the parts together while the glue dries. Notice also that the assembly is 'upside down' at this point. Tape will definitely be necessary to squeeze these shell halves together! I cut auxiliary bypass slots into the trunking, after going to school on all the information that Art Murray gleaned on his Swiss Hunter build. And painted the inside a creamy white to look like the flexible intake paint used in the later marks of Hunter. Then I glued the intake halves together, not thinking about all the warnings not to in previous posts, and not attempting to slide them onto the fuselage first. Dry fitting is just so boring! Now it was a simple case of following the instructions, flipping the assembly over and popping it onto the nose section... Even though it says to use glue (in the corner of the instruction box), even I could clearly see Mr Revell didn't really recommend glue for this step. But of course, the intake doesn't slide into position, no matter how good you are at twisted metal puzzles or Rubik's cubes. So I resorted to the next best thing - force! In this photograph, I make it look as if I planned a solution, but of course I didn't. The intake broke. It does however now slide into the slots with a bit of scraping sounds, and If you are intending to build one of these in the future, you might want to just leave the glue off one side of the splitter plates. Then it's flexible enough to squeeze into position... Right, now that that is out of the way, I wanted to lightly rivet the aircraft as the basis for some later weathering that reveals where some rivet lines run. Rivet a Hunter??? Yes, I know that seems wrong, but just look at what I did to the intakes. I have a plan. Most of the rivets are going to disappear under paint, but I couldn't think of a way of only doing some sections. Let's see how it works out. I accentuated the rivets on the 'shoulder' of the aircraft, since that's where the most of the weathering happens. Then I got a bit carried away with the top of the wings. The patterns are really intriguing... At least I left most of the underside unblemished by the wheel of holiness. I am really impressed with the flaps. Despite requiring a bit of attention on the ejector pin marks, they are a lovely subtle bit of detail. Mr Revell clearly put his best team on flaps, and the rest were left to work out the intakes, and instruction drawings. Apparently the tail assembly and mini-jet pipe have some issues. Maybe I'll actually contemplate that section before reaching for the glue. Until then, Cheers! Sean
  10. Hi Alain, I know you've got a thing for wheel wells too! I agree, something would have been missing... thank you. I'll be following your example in future Kev! Hey Nick, I think I was actually an aircraft hydraulic pipe; trapped in an airliner and seemingly always under pressure! This has become abundantly clear to me Derek. Thanks Zac, there's still a long way to go. Enjoy!
  11. An excellent choice Peter - I suspect people are going to faint from sheer delight when they discover what it is (assuming Shoggz, Derek and I hit the same Google button)! Korean colours would be awesome... just saying.
  12. WOW Chris, the heated metal effects on these exhaust nozzles is absolutely fantastic!
  13. Hello John, I have to admit that the wheel-well fetish is truly silly. I don't ever leave my models upside down in the display cabinet! Howzit Black Mamba! Yeah, I think it will pop under some silver, and a lot of oil and grime... Thank you! Hey Tony, I took a look at the G-Factor gear. It does look great, but was sadly not part of the Hannants catalogue when I was shopping for AM. Brass looks like a far better choice for the legs in comparison to the near crystalline metal in the SAC casting. Thanks for the input, much appreciated! Hi Kev, yup - SAC. I don't have much experience working with their products, and in retrospect it looks as if one should possibly just use a fine wire brush on the legs to clean them up. The heavy filing and sanding clearly isn't the best approach! Thanks Jaro, I'll do my best to keep you entertained! The intakes should be fun, since it looks like there are a whole lot of different approaches to getting them glued together, if one glues them at all...
  14. After a rather lengthy contemplation, something finally happened! It's the bas-relief effort that many kit manufacturers apply to detail that clearly doesn't resonate with me. Even though it can be enhanced with clever paintwork and washes, it still lacks depth. So, I decided to make one particular portion of the wheel well deeper - the bit that sits right up against the fuselage. This section is characterised by ribs, cables and what looks like a drive shaft of sorts. Here is the kit part that was cut out, and the ribs and longerons that will replace the kit's shallow representation. I then added some deeper sides to the well and glued on a flat styrene roof. Doesn't look like much from this side, but it actually adds an amazing amount of depth. Once the replacement structure is in place, the whole 3-D effect comes to life. You will notice that I also cut shaped ribs to add to the flat 'ribs' that are in the kit. Many of them are doubled-up on the actual aircraft. With the added structure in place, it was time to add as much plumbing as I felt I could, without being silly. The real aircraft is actually full of pipes and wires, but much of it is tucked away under a lip, that doesn't exist on the kit (and I certainly wasn't going to rebuild the entire well ). I have attempted to incorporate the kit's plumbing by starting and ending runs at the same points as the kit does. Since the wells were so easily accessible at this point, I figured it was a good time to work on the main gear legs. I have mentioned before that the kit mouldings are very thin towards the bottom, where the wheel attaches. Having bought cast metal legs, I reckoned the problem was sorted. I'm not terribly keen on the shabby look of the metal casting however (which is just the kit part made worse, but stronger). So I thought at any rate. No problem, out came the metal file and sand paper strips, and I set about neatening up the metal leg. After some filing and pulling strips of sandpaper over to oleo to get it to shine beautifully, I discovered that the uneven heating of the metal had curled up the leg like a shrimp chip in hot oil! I quickly straightened it out while it was still warm, but the muffled creaking sounds it made in the process make me think that my cleaning efforts have possibly compromised the metal's strength? Not wanting to push and prod too much, I decided to look at a way of strengthening the original kit legs. Here is the cleaned (and mostly straightened) leg to compare with the casting straight from the box. The kit leg got chopped up and cleaned back to basic shapes. Metal rods have been shoved in wherever possible and a strip of flat brass on the thin lower part of the leg will hopefully do the trick - otherwise the aircraft is going onto jacks - which might even be appropriate as you'll see by the end of the story! At least the Reskit wheel looks great... The retraction/extension piston also got some metal added, for strength, and to get the arm length correct. It all looks rather nice, upside down, with no weight on it! Almost time to contemplate the next step - the engine intakes! Cheers, Sean
  15. Unbelievable - three models!!! Well done Nick...
  16. Finally got the nose gear wheel-well painted, and then remembered this model needs nose weight! 40 grams of it according to the instructions, depending on where you can fit it in. Since I messed with the ideal space, it seemed like a good idea to stack 50 grams around the top on the unmodified well - like this: If you have built this model before, you'll probably know that this is a very poor idea, since it now no longer fits into the fuselage. Oh cock! (as James May was won't to say) Just have to take it all out and try again. This time the lead went into the upper part of the fuselage and hidden behind a styrene bulkhead, same as in the forward part of the nose. This is painted grey to form a dark background for the detail in the wheel well. This was as much lead as I could fit in the lower portion, and still get it to fit. You can also see just how much superglue and accelerator was holding my misplaced sinkers in place. The cockpit was then glued together, the seat checked to see if sits correctly, and that the red pulley assembly is in the right place. Last chance to see - before it disappears into the tub. I did actually use some pastel dust on the seat Nick, but as you know, it doesn't show up well in photos. The parts of the nose assembly all fitted together rather well I thought, and certainly didn't need any filler. The detail in the well stands out well, and some spare while stencil decals on the oxygen/air tanks finish it off quite convincingly. Now my contemplation will shift to the main gear wells, that despite looking ok, are really just a pantograph copy of their 1:72 scale Hunter! This is the 1:32 scale version... ...and this is the 1:72 scale rendition. Going to need some work! Cheers, Sean
  17. Thanks for the insight Sepp, makes sense now! Much appreciated Grunticus. Excellent observations Derek. It is interesting how one can trace the Martin Baker lineage through the seat models, and see how the face screen firing-handle changed over the years. The most modern seat I got to ride was the Mk 10, and that didn't have a face screen firing-handle at all! Nick, I look forward to the next milk tart occasion. Maybe we can eat the pastels too?
  18. Now, where has that airframe gone? Ah yes, in the October 1973 newsletter of the Yorkshire Air News we were led to believe that XF309 (disguised as WP190) was shipped off to the RAF Museum in Hendon. I suspect this is a bit of a red herring. The RAF Museum in Hendon had already been opened by Her Majesty the Queen on 15 November 1972, and I assume the 'Camm Collection' existed with a Hawker Hunter in place, as per this brochure of the time. Unfortunately the serial number is totally obscured in the photo by the pesky little Cygnet. According to the 'ukserials' website (which I consider to be quite authoritative), our Hunter was in fact sold back to Hawker Siddeley Aviation on 08/03/1973 and thence to G-9-420; which I can only assume means a conversion to FGA.9 standard. Where exactly that happened I can't tell, but let's leave her there for now. I'm afraid the wheel-well obsession struck again - to a lesser extent that on my Mirages, but still there. The forward part of the kit moulding is all 'boxed-in', so I cut away much of the sides and the roof. I then added the structure that the battery is mounted to, as well as some basic hydraulic bits and some piping. Here you can see the battery and the air/oxygen bottles that will be painted separately before being attached to the framework. This is what will be seen from outside, and the intention is just to paint the inside of the fuselage black. I certainly won't be adding ribs and 'stringers' to make for an authentic backdrop! Notice that the canon troughs have been drilled open to prevent the dreadful noise of the first rounds having to clear their own way... Some careful checking of the size of the modifications is required, to make sure things still fit into the nose. The substantial nose weight requirement is a bridge that will have to crossed a bit later. I haven't forgotten - yet! The undercarriage of this model has raised some concerns over the years, and so it should, when one looks at how thin the lower portion of the main-gear legs are. I bought a set of Scale Aircraft Conversions gear legs, and thought I'd give the nose-gear leg some attention first. The white metal (I assume) mouldings aren't terribly crisp, and the plan was to separate the fork from the strut and then clean it up from there. I didn't get that right, and managed instead to break the strut. That left me no choice but to modify the kit leg. Brass tubing and superglue are wonderful things to work with! Once the plastic fork was cleaned up , it became apparent why the kit leg looks so odd (sorry, should have taken a picture). The front portion of the fork casting is too short, and the attachment arm for the oleo piston doesn't end up under the centre of the strut. The darker bits of plastic are my modifications to address that issue. The resin wheel is a lovely Reskit replacement. Once assembled, the geometry of the arm and oleo make more sense. Revell would have one attach this leg before closing up the nose section, but my ability to break anything protruding from a model means that won't happen. I'll just cut slots in the fuselage for the locating pins to slide through, and fill them after fitting the leg. Now for the main wheels. This should be fun! Cheers, Sean
  19. Thanks Grunticus! I see in your Storch build that you too are an industrious manufacturer of miniature aircraft seats... Hmm , interesting observation John. I always thought the early MB handles looked odd, and it never occurred to me that it was actually a 'D' type once the pin was removed! Sepp, that is very kind of you. Intrigued by the use of the French acknowledgment, the Patrouille picture and yet, presumably, an English domicile. Hmm again .
  20. Yup, you got it Tom! Pictures are easier to interpret than words, so here is one to illustrate the point for anyone else who is interested. Excuse the hijack Tom...
  21. That is looking wonderful Tom! Gosh, when one sees the delicate surface details of the kit under a coat of AS-12 you really have to marvel at what Mr Tamiya created in this model. You are doing it great justice, and you have nailed the shade of 'grey'. Good catch Joachim - I believe you have understood it correctly...
  22. Valuable knowledge, and the kind of input that makes other people's models better, thank you Derek! It's not an exact replica, but closer to the mark. In the meantime the pulley got some paint and the unit it is connected to has made an appearance on the back of the fixed rail. Time to look at the wheel wells, but I think I'll leave that for next year...
  23. I love these days between festivities when nobody knows if you're actually working, or building models. The ejection seat just happened to get finished in this time vacuum.. Here are some general views that show the effect of having the parachute back-pad and light tan parachute harness separate from the seat. The blue straps form the safety harness which secure the pilot to the seat. In a change from previous seats, I decided to include the thin blue leg-restraint straps. In retrospect, I should have left myself some longer straps for the blue shoulder harnesses, but it is what it is now. Can we blame the armourer Derek? In the next views, you get a feel for how the straps and the back-pad interact, as well as the components on each side of the seat. The decals are from Peter's excellent Airscale 'Modern Cockpit Dataplate and Warning Decals'. You'll notice that I haven't fussed with detail on the seat-pan sides, since they can't be seen except for the height adjusting lever. And finally a view from the top, showing the busy drogue-chute compartment. That's it for now. Let's see how many days I can still milk out of the confusion in the start of the new year. Cheers! Sean
