James Rademaker Posted March 4 Share Posted March 4 Guys, I have been using Tamiya black panel line to highlight my builds. My question to you all is when? Do you finish painting the subject , gloss, panel line, re-gloss and THEN apply the decals or do you gloss,apply the decals and then panel line. I’m thinking that the panel line could creep under some decals and ruin or lift them. Thanks, Jim Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 4 Share Posted March 4 I almost always (IF Im using decals that is) apply a gloss coat, then decals then panel liner, as I personally always want to make sure the decals are "blended" in and snuggled down nicely, so the panel line wash goes over them too. To me it doesn't really look right if the panel lines that go across/through decals dont have the same color or wash as the rest of the airframe, but that is just me. HTH Daniel Leduc, Modelboy and JeepsGunsTanks 3 Link to comment Share on other sites More sharing options...
James Rademaker Posted March 4 Author Share Posted March 4 Thanks HTH. That’s what I’ve been doing. Jim Out2gtcha 1 Link to comment Share on other sites More sharing options...
Stuka Posted March 19 Share Posted March 19 Hey James, I agree with HTH. When using decals, I always shoot a coat of gloss over them before using Tamiya Panel Liner, which is my go-to for such work. Ditto that if' I'm going to use rendered oils, which tend to behave like Tamiya Panel Liner if used really diluted. Once, the panel liner work is complete, I usually go with a semi-gloss/matte in preparation for using rendered oils (not diluted) and weathering powders, which prefer something with a little texture for application. I hope that helps:) Best, --John Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 21 Share Posted March 21 It's Brian guys, but in this case HTH is actually "Hope That Helps" which I hope it did! Link to comment Share on other sites More sharing options...
