Tolga ULGUR Posted November 13, 2021 Share Posted November 13, 2021 Hello I am working on P-40 Geronimo and need help for clarifying the stencils on the left cowling panel. Do you know what is the writing on the indicated stencils ? My kit decal sheet has no stencils and I would like to install these stencils which are visible on the light tone of sand-desert pink. Thanks in advance Link to comment Share on other sites More sharing options...
John1 Posted November 13, 2021 Share Posted November 13, 2021 Interesting picture. Was the desert sand topside painted in the field? Almost looks like whoever painted it simply masked off the original stencils since each one appears to be against a darker, presumably OD, background. D.B. Andrus and Tolga ULGUR 2 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted November 13, 2021 Author Share Posted November 13, 2021 4 minutes ago, John1 said: Interesting picture. Was the desert sand topside painted in the field? Almost looks like whoever painted it simply masked off the original stencils since each one appears to be against a darker, presumably OD, background. Yes exactly, od background is visible. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted November 13, 2021 Author Share Posted November 13, 2021 Well, I decided not to worry too much about it and found a palliative solution. I tried to simulate them with what I found in my spare box. I'm going to end it like this. John1 and TankBuster 2 Link to comment Share on other sites More sharing options...
waroff Posted November 14, 2021 Share Posted November 14, 2021 the"stencils" were in reality decalcomania which had black lettering on clear background. They were applied on "Army camouflage" (OD41+ fringe Medium Green 42/ Neutral gray 43) the two little doors on port side of bottom cowl : oil - heating and on the rear cowl above the front wing fillet: coolant drain Tolga ULGUR, D.B. Andrus and John1 3 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted November 14, 2021 Author Share Posted November 14, 2021 46 minutes ago, waroff said: the"stencils" were in reality decalcomania which had black lettering on clear background. They were applied on "Army camouflage" (OD41+ fringe Medium Green 42/ Neutral gray 43) the two little doors on port side of bottom cowl : oil - heating and on the rear cowl above the front wing fillet: coolant drain Thanks for the information Waroff, really appreciated. Link to comment Share on other sites More sharing options...
John1 Posted November 14, 2021 Share Posted November 14, 2021 (edited) 8 hours ago, waroff said: the"stencils" were in reality decalcomania which had black lettering on clear background. They were applied on "Army camouflage" (OD41+ fringe Medium Green 42/ Neutral gray 43) the two little doors on port side of bottom cowl : oil - heating and on the rear cowl above the front wing fillet: coolant drain I hope the factory first applied a thorough coating of Future. If there was any silvering, there would be hell to pay. Edited November 14, 2021 by John1 Link to comment Share on other sites More sharing options...
John1 Posted November 14, 2021 Share Posted November 14, 2021 (edited) Duplicate post... Edited November 14, 2021 by John1 Link to comment Share on other sites More sharing options...
