I'll be starting an inflight helo build similar to Pete's HH-60G build soon and I need some help.
I will be using the Live Resin helicopter pilot, but I need his legs to be more straight down as he will be sitting in the doorway of a HH-60L medevac operating a hoist during a rescue.
20210303_035841
I need to cut his legs where you see the red lines, but how do you reposition his lower legs?
Hot water?
Thanks
Tim
Edited by Hawkwrench
In much smaller figures, I have cut a wedge out of the back of the knee. If you check your own leg (assuming it still bends) The front of your leg doesn't change much 'cos that's where the bones are. The back gets shorter as the muscles contract
If you try to bend it, you'll end up lengthening the front, which will look weird
And I'd be having kittens at the thought of either bending or cutting a figure so well sculpted as that!
Richard
MORE: I've just noticed this is 1/35th, so a bit of cutting and sculpting should be OK. I've done this with 1/32nd figures
Edited by RLWP
Thanks Pete, I'll check them out.
How did you put together your Franken figures?
Tim
1 hour ago, Dany Boy said:
Tim, you can try to hit the parts you want to make moveable with open flame from a spirits lamp or a candle.
I've never done that before. I'll keep that as a last resort move. Thanks for the tip!
Tim
On 3/8/2021 at 6:22 PM, Hawkwrench said:
Did you use paperclips for the positioning of the limbs followed by the Apoxie sculpt?
Tim
no pins. The Apoxie sculpt is firm enough to hold the Limbs in position
