cbk57 Posted August 16, 2018 Share Posted August 16, 2018 I messed around with a yellow black combo. I have tamiya xf-4 yellow green so I mixed that with black per the commentary above, I felt it too olive drab. I felt in the end it needed something else. The variation I have found so far is a 1 part tamiya flat blue, 1 part semi gloss black and 4 parts xf-4 yellow. I am not saying it is right but it looked like a good cockpit great to me. I may try a bit of green instead of the blue and see where I end up also. Out2gtcha 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted August 17, 2018 Share Posted August 17, 2018 6 hours ago, cbk57 said: I messed around with a yellow black combo. I have tamiya xf-4 yellow green so I mixed that with black per the commentary above, I felt it too olive drab. I felt in the end it needed something else. The variation I have found so far is a 1 part tamiya flat blue, 1 part semi gloss black and 4 parts xf-4 yellow. I am not saying it is right but it looked like a good cockpit great to me. I may try a bit of green instead of the blue and see where I end up also. Should not start with yellow green. Zinc chromate is a yellow. Yellow green comes from the mixing with tinting black with it. Similar to what Jennings says, I would start with an off the shelf interior green, but mix your yellow-black for accessories for variation of color as any part from a subcontractor would not be a perfect match, and give that nice visual variation. Link to comment Share on other sites More sharing options...
cbk57 Posted August 17, 2018 Share Posted August 17, 2018 12 hours ago, Jennings Heilig said: Why not just use any of the perfectly good out of the bottle Interior Greens? I don’t have one on my shelf at the moment, might end up doing that. Since someone said mix the chormate yellow with black, I happened to have similar colors on the shelf. I wanted to see what I would get and if I liked the mix. I did not really like the result. I did not think it looked right. LSP_K2 1 Link to comment Share on other sites More sharing options...
