Thanks Maru! :)
Been working with hardpoints and weapons. Pics will come soon.
I also had to sort which color to use. Think I got that sorted now. :)
HÃ¥kan
I've been working a bit both here and there! :)
Parts to the loadout.
The main rotor.
I glued the rear rotor.
Part of the rotor assembly on top of the cockpit.
Which also shows the color I've choosed to use.
Fitting the cockpit took some work, and I hope I've done enough, as I glued the cockpit to one fuselage half.
Next I'll be joining the fuselage halves.
I've also dipped the glass in future/pledge.
Not easy as an airplane canopy as the windows are large and flat.
HÃ¥kan
Edited by Azgaron
Shawn, I assume by looking at your build, that you had problems joining the fuselage due to the cockpit?
Need to check where the problem is and try to sort it.
HÃ¥kan
Ok, could be possible, as the casting is part of the issue.
I tried to fit the other half, and it turned out like this, more or less.
So in order to try and correct that, I painted white on suspected parts of the cockpit.
And here's the culprit. :)
I did some sanding like this.
I think it is enough, or at least should lessen the pressure some, meaning enough to get the fuselage together.
HÃ¥kan
Thanks Boris! :)
Still had to use force to glue the nose. Think I maybe missed some problem area.
HÃ¥kan
Thanks Maru! :)
Yes, I think the details is very nice considering the age of the kit.
I think I can make the deadline. Once the body is glued properly, I can start puttying and sanding, and then paint.
Good that most parts should have the same color. :)
HÃ¥kan
Gluing the fuselage was no easy task as something still was in the way somewhere, but I decided to proceed anyway.
I took a pic when I've glued the front and held it together with mild violence! :)
I let it rest during the night and most of the day, before I continued with the rest of the body.
I just had to take a pic with the rotor on
Looks pretty nice I think! :)
I've also masked all the glass, in- and outside.
Still not entirely done with the body, but will be, and can start puttying soon.
I also have a lot of small parts like weapons and gear to paint. I'm happy it's still progressing! :)
HÃ¥kan
Needed to use some force on the lower part of the nose too.
Been working with various bits and pieces too.
Found a bag for the rear door in my Stuart kit. Some putty and minor mod and it's ready to go.
I made a retainer for the gun mount, as it's just pushed into place and I wanted it to stay and keep movability.
The rear tire had a sink mark and needed some putty.
More small parts that needs some attention before paint and assembly.
I have do check that radar/recon thing, as I have no idea what colors should go behind the glass.
Looks like some kind of lens inside one of them
I also don't know the purpose of the glass in the bottom.
HÃ¥kan
Hello HÃ¥kan,
The force seems to be with you :thumbsup:
Cheers
Boris
