blackbetty
superbug, twin tails ´n twin engines FINISHED
started on the fuselage top, there are some things to correct (disclaimer: your milage may vary, the faults in the kit are just my opinion, i love trumpeter kits, everyone is allowed to do OOB builds and has my full respect...did i forget something - i appologize in advance :DodgeBall: )
first i made some templates to cut the PE screen from Aber:
and cut the screen to fit:
the engine bypass vents are very basic, so these will be modified and thinned. for the whole build i will use jakes superhornet book as a reference, its invaluable!
the vent on th right has been thinned:
and some detail added. the cutout behnind it has sharp edges that are not present on the real thing, so i rounded them with some sanding
Edited by blackbetty
thank you all, this makes a nice break in glueing a zillion vortex vanes to my scooter
stacks finished (not glued), vents relocated
the flush mounted antennas on the spine are heavily engraved on the kit, so i puttied them and sanded them flush. i think i will use a decal to represent them
here is the dry fit, pretty good. since the lower fuselage of the kit consist of seperate sidewalls that have to be shortened to use the intakes, i have first attached the resin parts to the lower fuse
careful to avoid extensive cleanup here:
i only glued the inside and the bottom in front of the chaff ejectors first
and used some sprue and thick CA to get some stability further back
after drying i will try to fit the sidewall as clean as possible and later fit the whole assembly to the upper fuselage part
stay tuned
