oldthudman5 Posted June 2, 2014 Author Share Posted June 2, 2014 (edited) May I make another suggestion? It may sound a bit strange, but it works for me. I use professional acrylic floor polish. Not Future, or what ever it is called there. It is like water and milky looking. I pour a bit in a small plastic cup, dip a finger in it and wipe quickly from the hub outward. Use very little. Do the other side, let dry for a minute or so, and do it again. It will fill any minute scratches and makes a nice surface. Don't use much, it will run if you do. Make your mold after it is fully dry. Where can you buy it?.............. OK I see Home Depot has a Pro Acrylic polish.........I'll check it out............ Edited June 2, 2014 by oldthudman5 Link to comment Share on other sites More sharing options...
Harold Posted June 2, 2014 Share Posted June 2, 2014 Where can you buy it?.............. OK I see Home Depot has a Pro Acrylic polish.........I'll check it out............ I get mine at a restaurant supply store. I gallon jug will last the rest of your life. Link to comment Share on other sites More sharing options...
Bruce Posted June 9, 2014 Share Posted June 9, 2014 maybe I can help you with the casting. I do casting as PartsrParts. http://partsrparts.homestead.com/start.html I have all the rubber and resin, etc. that is need to cast them. Bruce Girlscanplay2 1 Link to comment Share on other sites More sharing options...
oldthudman5 Posted June 9, 2014 Author Share Posted June 9, 2014 maybe I can help you with the casting. I do casting as PartsrParts. http://partsrparts.homestead.com/start.html I have all the rubber and resin, etc. that is need to cast them. Bruce I'll think about it................Thanks!........ Link to comment Share on other sites More sharing options...
oldthudman5 Posted June 9, 2014 Author Share Posted June 9, 2014 Here's a great walk-a-round of the A-26A/B-26K Counter Invader that's at the museum at DM Tucson Az..........A bit worn but shows all the antennas/scoops/pylons/etc..........Good close-ups............ http://nabe3saviation.web.fc2.com/waB26.html Link to comment Share on other sites More sharing options...
oldthudman5 Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) A couple of bits........... VHF 101 Antenna..(Collins Blade) HF 103 Antenna pole..... AN ARC-27 UHF Antenna The FM-622 A antenna..........coming along.. ADF Antenna Edited June 10, 2014 by oldthudman5 Girlscanplay2 1 Link to comment Share on other sites More sharing options...
oldthudman5 Posted June 11, 2014 Author Share Posted June 11, 2014 AMS Tip Tanks (T-33) cut & glued together......... Tank dump tubes added... Harold and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
andromeda673 Posted June 12, 2014 Share Posted June 12, 2014 nice work! my hats off to you for tackling this Link to comment Share on other sites More sharing options...
polsam Posted June 22, 2014 Share Posted June 22, 2014 This is fantastic. I'm also doing up one of these using the ID Models kit. The work on the prop is out of this world. From what I can see the Combat kit appears to be the better of these two models. There is a great walk around on google . These are a virtual walk around of the 5 airframes that were flown to Nha Trang in 1969 http://napoleon130.tripod.com/id242.html Lots of pictures taken by an Army dude. Hope these can help you. I'm doing the one named MAGNET ASS. There is also a resin source for the "Funny Bomb" cluster units carried in the Bombay. Its available from Sprue Bros. and is by Daco. Youll find that there is an awful lot available for everything except the aircraft itself. oldthudman5 1 Link to comment Share on other sites More sharing options...
Girlscanplay2 Posted June 22, 2014 Share Posted June 22, 2014 Good Tips here, Looking good keep it up, looking forward to seeing more Teresa Link to comment Share on other sites More sharing options...
oldthudman5 Posted June 22, 2014 Author Share Posted June 22, 2014 (edited) This is fantastic. I'm also doing up one of these using the ID Models kit. The work on the prop is out of this world. From what I can see the Combat kit appears to be the better of these two models. There is a great walk around on google . These are a virtual walk around of the 5 airframes that were flown to Nha Trang in 1969 http://napoleon130.tripod.com/id242.html Lots of pictures taken by an Army dude. Hope these can help you. I'm doing the one named MAGNET ASS. There is also a resin source for the "Funny Bomb" cluster units carried in the Bombay. Its available from Sprue Bros. and is by Daco. Youll find that there is an awful lot available for everything except the aircraft itself. The Combat Models version (vs the I.D./Tigger models kit) comes with drawings and resin parts....(BTW the clear parts are very nice)..To my knowledge the Tigger ID A-26 kit does not.......????......... Edited June 23, 2014 by oldthudman5 polsam 1 Link to comment Share on other sites More sharing options...
oldthudman5 Posted June 23, 2014 Author Share Posted June 23, 2014 (edited) Well, I'm ready to start on the fuselage (the scary part)............Have cut the major parts out ..........next the main partitions, icockpit nterior, doghouse interior, wheel well, gun nose detail, and scribing (the fun part....yuk!!!!)................Also the 2 wing pilot fuel tanks......... Sorry for the dark pic........Found I had the settings wrong......... Edited June 23, 2014 by oldthudman5 Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2014 Share Posted June 23, 2014 Getting more interesting all the time !...........Harv Link to comment Share on other sites More sharing options...
andromeda673 Posted June 23, 2014 Share Posted June 23, 2014 coming together nicely, I don't have the guts to try and tackle a kit like this, so I'm going to live vicariously through you and your build thread oldthudman5 1 Link to comment Share on other sites More sharing options...
oldthudman5 Posted July 2, 2014 Author Share Posted July 2, 2014 (edited) Started the vertical fin..........It's wider........Yes, it does look crude at this point..... Edited July 2, 2014 by oldthudman5 Link to comment Share on other sites More sharing options...
