LSP_Kevin Posted March 18, 2014 Share Posted March 18, 2014 oh - also, the formation lights - the 3 lights under the fuselage are incorrectly positioned and too small Once you clean up the fuselage join in that area, you can't keep them anyway, as they end up being mostly sanded off. Plus, they're raised circles, and I'd imagine that on the real thing they're recessed flush with the fuselage skin. I'll either mask and paint mine, or use coloured decals. If I were doing it again, I'd probably cut holes and fill them with either acetate circles or tinted Kristal Kleer. Kev Kev Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 19, 2014 Author Share Posted March 19, 2014 some work on a few parts sandokan and Sharkmouth 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 19, 2014 Author Share Posted March 19, 2014 seat parts glued, trying to fill the irritating ejector pin marks on the prop blades. drilled out fuel caps Busy remaking the upper bulkhead with the 2 holes in it as the holes are not correctly positioned (hardly worth the effort but im doing it anyway) flattened one ailerons ribs so far sandokan and Sharkmouth 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 19, 2014 Author Share Posted March 19, 2014 underside showing camera doors and one of the formation lights sandokan and Sharkmouth 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 19, 2014 Author Share Posted March 19, 2014 undercarriage bay detail sandokan and Sharkmouth 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 19, 2014 Author Share Posted March 19, 2014 underside detail Sharkmouth and sandokan 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 20, 2014 Author Share Posted March 20, 2014 Since I am not going to be doing anything in the area between engine and firewall and nothing will be visible I have decided to make a new firewall and keep the original - seems a shame to loose that moulded detail on the other side, and its a pretty easy piece to make, so busy test fitiing things so far Sharkmouth and sandokan 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 20, 2014 Author Share Posted March 20, 2014 Sharkmouth and sandokan 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 20, 2014 Author Share Posted March 20, 2014 Glueing engine halves together, and they ONLY go together 1 specific way - but even so the fir is not perfect and does need some minor pressure to keep cylinders together. I hope any gaps will not be noticeable in the end. trying to run glue into the gaps on the sides of culinders just doesnt work as the glue immediately runs down the cooling fins. so maybe more care and thought in this area. Sharkmouth and sandokan 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 20, 2014 Author Share Posted March 20, 2014 I wasnt going to do much extra work - but i guess I am enjoying the opprtunity of correcting detail on this large scale Harvard. So decided the wheel wells and centre section is an area id like to get right. Part of this is because I soon need to do this all in 1/7 scale, so might as well practice while I can sandokan and Sharkmouth 2 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 20, 2014 Author Share Posted March 20, 2014 sandokan and Sharkmouth 2 Link to comment Share on other sites More sharing options...
Loic Posted March 20, 2014 Share Posted March 20, 2014 Lovely work Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 23, 2014 Author Share Posted March 23, 2014 Decided to do work on the 1/48 Harvard first and start getting that scheme underway sandokan 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 23, 2014 Author Share Posted March 23, 2014 Took ages to cover the red - not my best work at all sandokan 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted March 23, 2014 Author Share Posted March 23, 2014 Im doing Repsol Texan type of scheme. fictitious Reno Texan using Motorcycle racing theme. Need to figure out a good colour arrangement sandokan 1 Link to comment Share on other sites More sharing options...
