Azgaron Posted September 5, 2008 Author Share Posted September 5, 2008 Thanks Ed and Peter! I'll do my best! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Azgaron Posted September 23, 2008 Author Share Posted September 23, 2008 Got a small package with cockpit and exhaust parts in the mail today! Thanks Blackbetty! Now I'll try and figure how to work things out, making them fit and all that! Pics are coming as soon as I got something to show! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Azgaron Posted September 25, 2008 Author Share Posted September 25, 2008 With only one computer accepting the camera, SWMBO and three kids it's sometimes hard to get access! Anyway, here's a pic of the parts I got! Here's a comparasion of the cockpit parts! There are details on the Revell part but they doesn't show in the pic! Here's another pic that shows the difference in the detail of the panel behind the pit! With some cutting and sanding, I hope I can make things fit! Cheers, Azgaron Link to comment Share on other sites More sharing options...
blackbetty Posted September 25, 2008 Share Posted September 25, 2008 have fun with it! Link to comment Share on other sites More sharing options...
Azgaron Posted September 25, 2008 Author Share Posted September 25, 2008 I will, thanks! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Azgaron Posted October 2, 2008 Author Share Posted October 2, 2008 As this is the first time I replace kit parts, and the replacement isn't meant for the kit, I'm still trying to figure how to fit some of the parts (cockpit mainly) into the fuse. Meanwhile I made some sub-assemblies! The exhaust nozzle is one the parts that needs some attention! First of all I want to use the kits (afterburner something I think) part! But there's a slight problem with the fit! But cutting away the rim and widening the inner diameter a bit will take of that I think! Here's a pic for comparasion! The intake looks like this! Somehow I don't think the air gets very far with that intake So I'm thinking of changin that by cutting it open and prolong the shaft! Can I find somewhere information on how it should look and how far in the fan sits? Measurements too hopefuly! Not that I know if I can do such a thing, but I'd like to try! Cheers, Azgaron Link to comment Share on other sites More sharing options...
blackbetty Posted October 2, 2008 Share Posted October 2, 2008 I should have sent you the academy intakes too (I used the CE seamless) they aren't perfect, but better than revell Link to comment Share on other sites More sharing options...
Azgaron Posted October 2, 2008 Author Share Posted October 2, 2008 That would have been nice, but there's another solution that I didn't think of at first (in fact someone suggested it ), and that is to make a cover! I guess that's a lot easier! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Azgaron Posted October 4, 2008 Author Share Posted October 4, 2008 I found this pic in a walkaround! Exhaust nozzle By the looks of this pic and the parts I got, the inner and outer feather sets have about the same lenght/depth, and the thingie at the bottom is further in than it's supposed to be on the model according to Revell! So I'm thinking that it would look better if I cut away the stop that's supposed to hold the afterburner thingie or whatever it is and add a tube that will push it a bit deeper into the body! I hope this was somewhat understandable, and I'm sorry for my lack of the correct terminology, but I hardly knows what it's called in Swedish! Is there anywhere I can find the measures of the intake? Drawings? Cheers, Azgaron Link to comment Share on other sites More sharing options...
stusbke Posted October 4, 2008 Share Posted October 4, 2008 I found this pic in a walkaround! Exhaust nozzle By the looks of this pic and the parts I got, the inner and outer feather sets have about the same lenght/depth, and the thingie at the bottom is further in than it's supposed to be on the model according to Revell! So I'm thinking that it would look better if I cut away the stop that's supposed to hold the afterburner thingie or whatever it is and add a tube that will push it a bit deeper into the body! I hope this was somewhat understandable, and I'm sorry for my lack of the correct terminology, but I hardly knows what it's called in Swedish! Is there anywhere I can find the measures of the intake? Drawings? Cheers, Azgaron yep and making it OOb can be tricky however I have a little trick to make them look a little better. take the outer feather part and sand the inside of it only on the edge so that there's a gap between the inner and outer part and then add some small strips of styrene between the two parts it should look something like this when done hope this helps mate Greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
Azgaron Posted October 4, 2008 Author Share Posted October 4, 2008 Thanks Frederick! That's a very neat trick that I'll apply! I can also se on your pics that I was correct, that there is something between the feathers and the bottom! Doing something that looks like that can be tricky, but perhaps I can do a good lookalike! Can you provide me with the diameter and depth measures? Cheers, Azgaron Link to comment Share on other sites More sharing options...
Texas Posted October 4, 2008 Share Posted October 4, 2008 Very Nice and it looks great. Texas Link to comment Share on other sites More sharing options...
stusbke Posted October 4, 2008 Share Posted October 4, 2008 Thanks Frederick! That's a very neat trick that I'll apply! I can also se on your pics that I was correct, that there is something between the feathers and the bottom! Doing something that looks like that can be tricky, but perhaps I can do a good lookalike! Can you provide me with the diameter and depth measures? Cheers, Azgaron yeah the exhaust pipe is 2cm in diameter and its about 2.5 cm to the flame holder HTH as far as the intakes concerned if you're not going to use the seamless set you're in for a big job. I tried it and its one hell of a job to get it looking ok, I'm adding FOD covers on mine next time I'll try it again untill it works its just that the intakes are so narrow its hard to sand them and also the curves inside are not realy making it easier but he its your model mate Greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
Azgaron Posted October 4, 2008 Author Share Posted October 4, 2008 Thanks Frederick! Ok, then I can at least try to make the exhaust pipe! I'll see what I'll do about the intakes, but ofcourse FOD is the easiest, and perhaps nicest option! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Azgaron Posted October 6, 2008 Author Share Posted October 6, 2008 Well, here's my attempt at spicing up the nozzles a bit! Strangely it isn't until now I noticed that the outer nozzle parts have different looks on their feathers! Are there two sets with the Academy kit? I also been trying to make a suitable tube that will be used as the missing piece of exhaust pipe! Cheers, Azgaron Link to comment Share on other sites More sharing options...
