I've been thinking the same thing lately, and here's what I came up with:
Like the others said the Sea Fury wing is the Tempest wing with the centre section taken out. The wheel wells and gear is the same on the Tempest and the Fury, but very different from the Typhoons. The fury wing has intakes in the inner leading edge that you need to remove - should be do-able.
The Typhoon had a very different wing - very much thicker, so fitting the Fury wing on the Typhoon fuselage might be difficult. I'm thinking about using parts of the Fury fuselage combined with the Typhoon fuselage, although I'm not completely done checking out if there are differences I haven't seen yet. The Fury's cockpit was raised a bit for carrier operations, so I think I'll use the lower fuselage from the firewall (or bulkhead just ahead of the cockpit) back to some point behind the cockpit and then use the whole fuselage behind that. I must repeat I'm not completely sure this will be correct. You'll need to reshape the fin at least.
I think you can use the top of the Typhoon centre fuselage and then use the Fury canopy
Most difficult part in my opinion will be to reshape the rear part of the cooler as the Typhoon had the wing overlap and the tempest had the wing behind the cooler. A bit of shaping needed here.
Does anyone know if the Typhoon spinner is appropriate for the Tempest?? How about the cockpit - more Typhoon than Fury or what? Wheels could be different as the Fury was a carrier plane while the Tempest was not.
