WrongWay Posted October 21, 2008 Share Posted October 21, 2008 Here I go with my second model and first online build. Hope I don't blow this! Thinking about going with Brown 18 from Eagle Editions. I used a PE set from another 190 that I got for cheap on e-Bay. Looks close enough for me. I had to cram it in around the ammo counters but you won't notice it once the fuselage goes together. The used and abused look. Link to comment Share on other sites More sharing options...
big matt Posted October 21, 2008 Share Posted October 21, 2008 Wow. That panel looks great. Those belts look really nice too. Whose are they? Did you paint them? I have the decals to do "brown 18" also and will be watching your build. That one and "blue 12" are on my list of coming projects. Great job so far. Matt Link to comment Share on other sites More sharing options...
LSP_Ron Posted October 21, 2008 Share Posted October 21, 2008 The belts look great! can you explain how you got them to look like that? Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted October 21, 2008 Share Posted October 21, 2008 That´ll be one more stunning D9 on LSP! Very inspiring work... Cheers, Chris Link to comment Share on other sites More sharing options...
WrongWay Posted October 22, 2008 Author Share Posted October 22, 2008 Thanks guys! I really hope I can pull off the paint job. Here is what I did for the belts. 1. I used a standard Eduard PE belt set in the light color. 2. I lightly sprayed the belts in khaki green. A light spray so that the stitching shows and gives a faded look. 3. I used the Tamiya Weather Master set B and went around the edges of the belt with soot and also rusty brown. It just gives a soiled look to it. Thats all that was necessary and it's very easy. You will find the Tamiya weathering system to be a very handy tool. I use it on my radio control models as the finish needs to be routinely touched up. Small update. Here are some 20's I scratched for the Dora. I'm working on the engine plug now. Link to comment Share on other sites More sharing options...
didiumus Posted October 22, 2008 Share Posted October 22, 2008 Great cannons! Really great work on the belts, too. I don't think I have seen that approach before. Keep up the good work. Scott Gentry Link to comment Share on other sites More sharing options...
WrongWay Posted October 26, 2008 Author Share Posted October 26, 2008 Got a little bit done today. I'm being hampered by supplies a the moment. Seems like every time I order something it's backorderd. I hope to get more done tonight and tomorrow. The greased engine. I mocked it up to show what will be seen from underneath. Might add some more hydraulic lines before I start on the wings. I need to clean up a bit of flash on one of the hoses. Did not notice that bit until I snapped the photo. Link to comment Share on other sites More sharing options...
LSP_Ron Posted October 27, 2008 Share Posted October 27, 2008 Good stuff Ron Link to comment Share on other sites More sharing options...
WrongWay Posted December 15, 2008 Author Share Posted December 15, 2008 I'm still here! I just started up again after moving. I wanted to spray some paint today but it's too cold in my work room. More to come. Here I added a new access panel and latches out of drink can aluminum. Scribing is not my strong point so this is my solution. I'm repainting the weel bays as I was not happy with the hydraulic lines. Moskit metal exhausts an Eagle radiator cowling test fitted. Eagle E. tail wheel installed. I'm going to try and make the wheel caster by installing a metal pin in the base. Link to comment Share on other sites More sharing options...
Texas Posted December 15, 2008 Share Posted December 15, 2008 Looking Good Texas Link to comment Share on other sites More sharing options...
LSP_Ron Posted December 15, 2008 Share Posted December 15, 2008 Looking Good Texas I agree with that Link to comment Share on other sites More sharing options...
big matt Posted December 16, 2008 Share Posted December 16, 2008 That Eagle cowl looks really good. Hmmmm. Might have to order that and the tail wheel. The latches and panel look great. Not being a competent scriber myself, I have used bare metal foil. Your technique looks a little more convincing. Matt Link to comment Share on other sites More sharing options...
WrongWay Posted December 16, 2008 Author Share Posted December 16, 2008 Thanks all. It's 26 degrees out so I guess I won't get any paint sprayed tonight either. I'm tempted to paint inside but I don't believe my other half would appreciate that. Link to comment Share on other sites More sharing options...
WrongWay Posted January 7, 2009 Author Share Posted January 7, 2009 Well I've been so busy at work I've not had much time for the old girl. Here is what I have done so far though. I've got all the body work and scribing done. I added the metal tube that the spinner slides onto and also made a gun camera out of the same tubing. A bit hard to see in that photo. The prop and spinner are not together yet I just mocked it up to see how it will eventually look. I hope to put in some solid work on her this weekend. I made the tiny cowl flap actuators from scrap PE. I fixed the hood around the instrument panel and have modified the gun sight to drop in once painted. I'm still up in the air on which machine this will end up being. It won't be Brown 18 as I first thought though. She now carries an etc rack and will have a drop tank in place. One more. All seams appear clear as I use Zap CA as a filler. I hate putty! Link to comment Share on other sites More sharing options...
maverick728470 Posted January 7, 2009 Share Posted January 7, 2009 Did anybody tell u that u'er good at what u do here the D-9?Keep it up.Larry Link to comment Share on other sites More sharing options...
