vvwse4 Posted August 6, 2008 Share Posted August 6, 2008 Well, it is time to start something new. Thanks to Larry I got this one. I want to do some more with the model and want to make open hatches, lower the flaps and add a lot af detail. That is very ambitious but I want to give it a try. So far I have been doïng some work on the cockpit area. About the hatches in the fuselage, what is the best way of cutting them out, is it easier to drill a lot of holes and make a new hatch or should one just cut on the lines. I could use some tips on this one. It will be a long job, that is for sure. Rick. Link to comment Share on other sites More sharing options...
theseeker Posted August 6, 2008 Share Posted August 6, 2008 Rick, You are off to a nice start. As far as the hatches go, it is a matter of what you are most comfortable with. I usually drill and then use a small razor saw. Rocky Link to comment Share on other sites More sharing options...
Texas Posted August 6, 2008 Share Posted August 6, 2008 HI Great start. As far as the hatches it depends on the size and shape. If there fairly large and square or rectangle then you can use a number 11 blade backwards to scribe them out and reuse them. If they are small or a rounded shape you may have to drill many holes, cut them out and make a new one. Just my two cents. Texas Link to comment Share on other sites More sharing options...
rotary Posted August 6, 2008 Share Posted August 6, 2008 and sand them down on the inside heavily first----two reasons, it makes em easier to cut out and it thins everything down to near scale thickness.----sorry if it was obvious mate. cheers, dave. Link to comment Share on other sites More sharing options...
Guest Rigor Posted August 6, 2008 Share Posted August 6, 2008 Rick, first off welcome,and nice start i have this kit too,so i will be watching Link to comment Share on other sites More sharing options...
vvwse4 Posted August 6, 2008 Author Share Posted August 6, 2008 and sand them down on the inside heavily first----two reasons, it makes em easier to cut out and it thins everything down to near scale thickness.----sorry if it was obvious mate.cheers, dave. Dave, Never thought of that. I will give it a go. Thanx Rick. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 11, 2008 Author Share Posted August 11, 2008 Been doing some work on the side console And I have made the wiring for the forward machine guns and did the deeper instrument panel I have a question also. I am trying to make seat belt out of aluminium, after I saw what one can do with a sixpack here on LSP. I have not been able to make buckels that looked good. Does anyone ever gave that a try, please let me know how you did it. Thanks for looking, Rick. Link to comment Share on other sites More sharing options...
Guest Rigor Posted August 12, 2008 Share Posted August 12, 2008 Rick,nice update looking good as for the buckels you could try wire,shape it,then flaten it if you know what i mean Link to comment Share on other sites More sharing options...
johng Posted August 12, 2008 Share Posted August 12, 2008 Wire staples are a good material to make buckles from. Drive a straight pin into a wood block and shape the staple around it, using needle nose and chain nose pliers, to get tight corners. For a pattern, take a look at the belts sold by Radu on his website. After seeing those fantastic belts, you just might want to buy his instead of making your own. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 12, 2008 Author Share Posted August 12, 2008 Wire staples are a good material to make buckles from. Drive a straight pin into a wood block and shape the staple around it, using needle nose and chain nose pliers, to get tight corners. For a pattern, take a look at the belts sold by Radu on his website. After seeing those fantastic belts, you just might want to buy his instead of making your own. In saw those seatbelts and they are great but the wrong scale, 1/32 instead of the 1/24 I need. Rick. Link to comment Share on other sites More sharing options...
maverick728470 Posted August 12, 2008 Share Posted August 12, 2008 Rick, Eduard makes some really great colored seat harnesses for that FW u have.Their about 12.00 US.Larry Link to comment Share on other sites More sharing options...
johng Posted August 13, 2008 Share Posted August 13, 2008 In saw those seatbelts and they are great but the wrong scale, 1/32 instead of the 1/24 I need. Rick. Sorry, Rick. I musta had a brain fart when I wrote what I did. The bit about the staple wire still holds though. It's what I used when making belts for a 1/18th scale 'pit and I thought it came out looking pretty good. Link to comment Share on other sites More sharing options...
bcauchi Posted August 13, 2008 Share Posted August 13, 2008 Lovely detialing Rick, you are doing a great job. Have that model, must build it one day so I better stalk you out on this one. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 24, 2008 Author Share Posted August 24, 2008 Slow but steady progress. The best part of this build is when I feel like breaking things I can do this: On the other hand I can also make things: I still haven't got the seat belts right, I might as well do what Larry suggested and pay a visit to the Eduard site. Rick. Link to comment Share on other sites More sharing options...
Azgaron Posted August 24, 2008 Share Posted August 24, 2008 Excellent work so far Rick! It'll be interesting to foloow this build! Cheers, Azgaron Link to comment Share on other sites More sharing options...
