mark31 Posted June 26, 2017 Share Posted June 26, 2017 Hello to you all Im planning to build a F-15E from the Saudi air force and now I need your help I already have the decal sheet I know the exhaust is difrent Are there other things that I have to change? Are there any sets out there? Thanks Mark mpk and Luca 2 Link to comment Share on other sites More sharing options...
Luca Posted June 26, 2017 Share Posted June 26, 2017 I also have a E to be converted to Saudi, I'm interested mpk 1 Link to comment Share on other sites More sharing options...
do335b6 Posted June 26, 2017 Share Posted June 26, 2017 I am as well mpk 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted June 26, 2017 Share Posted June 26, 2017 (edited) The left vertical fin has the smaller fairing at the top, as per the F-15J kit, parts B3 and B7 from kit no. 60307... A simple exhaust fix http://partsrparts.homestead.com/F15tailcones.html F-15J instructions https://www.super-hobby.com/products/Mcdonnell-Douglas-F-15J-Eagle-JASDF.html If you look at the very end of the fuselage on the F-15E past the tailplanes they are rounded on both sides, however on the F-15S they are rectangular, the right vertical, left horizontal. https://theaviationist.com/2012/05/11/strike-eagle-djibouti/ http://www.airliners.net/photo/Saudi-Arabia-Air-Force/Boeing-F-15S-Strike-Eagle/1333015/L Edited June 26, 2017 by Kagemusha mpk and mark31 2 Link to comment Share on other sites More sharing options...
eaglekeeper Posted June 26, 2017 Share Posted June 26, 2017 Basically the E model airframe with CFT's set up for dual mission capabilities, air to mud and air to air. As said both both vertical stabs have the weighted counter balances and the squared off antenae's on the stingers. Composite turkey feathers on the engine nozzles. Tail hook fairing was removed in the factory as per all E model airframes that have rolled off the assembly line. No ICS has been installed as that's specifically for the USAF and the S model mostly likely has some locally installed avionics and defensive systems. The left vertical and right vertical stab tourque box beef up plates at the top near the counter balances will need to be put on the kit stabs. Nothing really much of changes from the E, this is just going with the deliveries before 2001 when I worked them in transit. After that year and deliveries after that i am not aware of if they modified them. mpk 1 Link to comment Share on other sites More sharing options...
jmel Posted June 27, 2017 Share Posted June 27, 2017 This may be of help to you. http://www.reidairpublishing.com/product-p/rap014.htm mark31 and mpk 2 Link to comment Share on other sites More sharing options...
