Jasta 14 addict Posted October 20, 2019 Share Posted October 20, 2019 Hi everyone, anybody know's if there is aftermarket resin ACMI pod's in existence?? This type i need for my F-16CJ project. Could it be scratch made, maybe of a Sidewinder? I don't know if the dimensions are the same? Regards Danny Link to comment Share on other sites More sharing options...
kikka Posted October 20, 2019 Share Posted October 20, 2019 Harold makes great pods , i have a couple . no problems , multiple tips . Link to comment Share on other sites More sharing options...
Uncarina Posted October 20, 2019 Share Posted October 20, 2019 Danny, For whatever it’s worth, I scratchbuilt mine: Cheers, Tom Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted October 20, 2019 Share Posted October 20, 2019 26 minutes ago, Uncarina said: Danny, For whatever it’s worth, I scratchbuilt mine: Cheers, Tom Very nice Tom. May i ask what you used to build the ACMI pod?? Regards Danny Link to comment Share on other sites More sharing options...
Marcel111 Posted October 20, 2019 Share Posted October 20, 2019 Hello Danny, The pods are significantly longer than Aim-9's, not sure of the exact length but check some pics, eg. of the NSAWC F-16's, you can see how much more they extend to the rear of the wingtip. They are are the same diameter as an Aim-9, so you can use 4mm styrene rod as a start, the rest of the scratch building should be easy. Cheers, Marcel Link to comment Share on other sites More sharing options...
thierry laurent Posted October 21, 2019 Share Posted October 21, 2019 The length problem may be easily solved if you simply use two missiles to create one ACMI pod. Link to comment Share on other sites More sharing options...
Uncarina Posted October 21, 2019 Share Posted October 21, 2019 22 hours ago, DannyVM said: Very nice Tom. May i ask what you used to build the ACMI pod?? Regards Danny Danny, Thanks! I used Evergreen plastic tubing and rod, creating the leading edge taper by sanding at an angle while rotating the section. Hope this helps, Tom Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted October 21, 2019 Share Posted October 21, 2019 Ok thank's very much guy's, time to get busy. Link to comment Share on other sites More sharing options...
