Joel_W Posted May 30, 2017 Share Posted May 30, 2017 (edited) As for favorite all time cars: That's easy. Lotus 49c driven by Jim Clark. Lotus 72E driven by Emmo Fittipaldi, McLaren M6A, and M8B driven by Bruce McLaren or Denny Hulme. I have all these kits. I don't have the skills to build the multi media 1/20 scale 1967 AAR Eagle that won the Spa Grand Pix with Dan Gurney at the wheel. I'd kill for a Porsche 356 coupe in my garage. I grew up right in between Grummans and Republic. My favorite aircraft are the F4F-3/4, F6F-3/5, P-47D bubble and Razorback. Yet I do love the F4U Corsairs. Current aircraft naturally are the F-14 series and the A-10. Yet I have a real fondness for all Scooters. That's as current as this old timer gets. Joel Edited May 30, 2017 by Joel_W SirBlueHenry 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 31, 2017 Author Share Posted May 31, 2017 Joel_W 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 31, 2017 Author Share Posted May 31, 2017 Spent time on the formation lights mountings - but still need to get the actual clear parts cleaned up enough to fit in there. Then a lot of time preparing to glue in one of the horizontal stabs. So I managed to get 1 side in but it need a lot of tweaking to keep it well glued and no gap. Getting it square was another issue but finally it came out beautifully (which you cant tell from the photos of course. Tonight the other side and more on the formation lights. Link to comment Share on other sites More sharing options...
Joel_W Posted May 31, 2017 Share Posted May 31, 2017 SBH, Your method for gluing and aligning the horizontal stabs is well thought out, and will keep them exactly where you intended them to be. Joel Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 31, 2017 Author Share Posted May 31, 2017 Misaligned tailplane and main wings is just awful - so I go out of my way to ensure all is symmetrical. The worst example of this is where older kits have a fin that is slightly skew. Not enough to notice when you glue the fuselage halves together, but when you get your horizontal stabs all nicely glued on, square with the fin, and all is looking great, then finally you get to the mainplane and realise the entire tail structure is now off by a few degrees is enough to make you wanna quit and take a up a hobby like quilting Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted June 1, 2017 Share Posted June 1, 2017 Aha! You've built the Minicraft 757! Some days the only thing you can do is a tailectomy and subsequent reatachment with all alligned as it should be. Joel_W 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 1, 2017 Author Share Posted June 1, 2017 Haha - no actually some other kits - most recently an Occidental Spitfire and something else i cant remember now. I do have a Welsh models 757 but the halves are still separate. No - tailectomies make me feel uncomfortable. What I do is set the model aside, take a sip of coffee. Move slowly away from the model without making direct eye contact. Never make direct eye contact!! and then for the next week pretend that you dont know who's model that is .... Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 1, 2017 Author Share Posted June 1, 2017 I toned down the white wiring i had done - after looking at it all week, I decided it need to be done - even if not visible. Looks much better and more subtle. Thanks for the suggestion. Joel_W 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 1, 2017 Author Share Posted June 1, 2017 The final bracing done on the stabilisers and test fitting shows I now have a perfect square tailplane. Whew. Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 1, 2017 Author Share Posted June 1, 2017 Link to comment Share on other sites More sharing options...
Joel_W Posted June 1, 2017 Share Posted June 1, 2017 without the white wiring it looks so much more realistic. I'm confident that it will still be quite visible once the fuselage is closed up, especially if one uses a small pen flashlight. Joel Link to comment Share on other sites More sharing options...
Joel_W Posted June 1, 2017 Share Posted June 1, 2017 without the white coloring, the wiring it looks so much more realistic. I'm confident that it will still be quite visible once the fuselage is closed up, especially if one uses a small pen flashlight. Joel Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 1, 2017 Author Share Posted June 1, 2017 On a different note - Heres a 1/72 Blenheim ive been sprucing up a bit. Just painted the crew and added a map and navigators logbook. Link to comment Share on other sites More sharing options...
Shawn M Posted June 2, 2017 Share Posted June 2, 2017 he's had his arm blown off that one! love the cockpit work on the BC, that blenheim looks the bit as well Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 2, 2017 Author Share Posted June 2, 2017 hes missing leg parts as well. I always found it funny that Airfix and some others would mould crew with missing bits, rather than mould the cockpit to be more correct. But thanks, yes I quite like the way they have come out (for minimal effort). Link to comment Share on other sites More sharing options...
