Having issues with Tamiya Panel line washes
panel line wash
  • Please log in to reply
13 replies to this topic
#1 Gerhard
Gerhard
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 644 posts
  • Gender:Male
Posted 06 August 2017 - 02:49 PM
Hi Guys, so I completed a model and gave it a coat of Tamiya Clear Gloss (TS 13). Let it cure properly and then applied Tamiya black panel line wash. Try as I may. I cant get the excess panel line wash off. It's as if the wash ate into clear coat. This well and truly ruined the model.
Must your clear coat be Acrylic? I dont have any odorless mineral spirits at hand. Is that  the only product to use to clean up the panel line wash.
Any tips please?
Thanks
Gerhard
  • Peterpools likes this
#2 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 513 posts
  • Gender:Male
Posted 06 August 2017 - 03:07 PM
I believe TS13 is a lacquer, I believe that the panel line wash is thinned with mineral spirits. They should not affect each other, you should be able to clean up the wash without eating into the clear.
  • Zero77 likes this
#3 CANicoll
CANicoll
    Senior Member
  • LSP_Members
  • 1,158 posts
  • Gender:Male
Posted 06 August 2017 - 03:08 PM
Gerhard,
The Tamiya washes are enamel based so they should not have interacted with your clear coat.  A couple of things come to mind:  How long did you let that clear coat dry for? (But sounds like you let it cure for a long time).  The other is what are you trying to clean off the wash with?  You need to use some sort of mineral spirits or turpentine.  Nothing for an acrylic will work (and just makes a mess.  Ask me how I know.......).
Try those mineral spirits and see how it works out.  Should not do anything to your clear coat and should take the wash right off.  (A lot of 'should's there I know, sorry!).
I did a quick internet search of the usual model forums and I've not seen anyone report a similar problem (admittedly, not an extensive search).
Good luck and let us know how you sort it out.
Chris
Edited by CANicoll, 06 August 2017 - 03:09 PM.
#4 Gerhard
Gerhard
    Senior Member
  • LSP_Members
  • 644 posts
  • Gender:Male
Posted 06 August 2017 - 03:26 PM
Thanks guys, I will go out and get some clear mineral spirits and give it a bash. Hey, I might have turpentine, will check.  I did see on the Britmodeller forum they say your clear coat MUST be Acrylic.
Edited by Gerhard, 06 August 2017 - 03:29 PM.
#5 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 23,830 posts
  • Gender:Male
Posted 06 August 2017 - 06:09 PM
Gerhard
I sue Tamiya Panel Line Wash all the time with no problems at all but as a pin wash. If I'm doing all the panel lines on the entire model model, I normally use Flory's Water Based Wash.
eter
  • CANicoll likes this
Trumpeter SBD-1
#6 CANicoll
CANicoll
    Senior Member
  • LSP_Members
  • 1,158 posts
  • Gender:Male
Posted 07 August 2017 - 02:18 PM
Like Peter, I use Flory's too actually.  And some MIG.  Good luck!
#7 Gerhard
Gerhard
    Senior Member
  • LSP_Members
  • 644 posts
  • Gender:Male
Posted 07 August 2017 - 03:04 PM
Flory's and MIG not available in South Africa.
#8 1to1scale
1to1scale
    Senior Member
  • LSP_Members
  • 513 posts
  • Gender:Male
Posted 07 August 2017 - 05:07 PM
I buy direct from Flory in UK, they ship anywhere as far as I know. I personally use mostly water based washes now, I tried using acrylic, but not overly impressed with them, they even dry a little sticky. Nice thing about water wash, if you really screw up, rinse them off with water. I even tried streaking with them and a wet brush.
#9 Gerhard
Gerhard
    Senior Member
  • LSP_Members
  • 644 posts
  • Gender:Male
Posted 08 August 2017 - 05:34 AM
Phew, expensive.
#10 Gigant
Gigant
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 324 posts
  • Gender:Male
Posted 09 August 2017 - 07:36 PM
For me this brings up two questions:
  1. Is this why I see this product being "dumped" on certain supplier websites?
  2. Arn't panel lines normally done before the finish/final coat?
:innocent: Tom
:innocent: Tom
My photo album: https://www.flickr.c...1984@N04/albums
#11 CANicoll
CANicoll
    Senior Member
  • LSP_Members
  • 1,158 posts
  • Gender:Male
Posted 16 August 2017 - 02:01 AM
:innocent: Tom
I don't always use a top or final coat after weathering and that includes panel lines.  Depends on the look I'm going for and how well the finish looks.
#12 Gerhard
Gerhard
    Senior Member
  • LSP_Members
  • 644 posts
  • Gender:Male
Posted 16 August 2017 - 05:10 PM
:innocent: Tom
Gloss coat, decals and panel line wash, then final coat.
#13 Maxim
Maxim
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 434 posts
Posted 18 August 2017 - 07:24 AM
I use Tamiya Clear Gloss in the jar and spray it through the airbrush. I use the Tamiya panel line wash and it comes off with a little mineral spirits.
Maxim.
#14 Gerhard
Gerhard
    Senior Member
  • LSP_Members
  • 644 posts
  • Gender:Male
Posted 18 August 2017 - 11:56 AM
Yeah, I think my issue was the incorrect cleaning agent. Will get some mineral spirits or turps.
