D Bellis Posted April 6, 2006 Share Posted April 6, 2006 There are two color-coded ports on the starboard side of the fuselage, just aft of the cockpit. Thanks to Radu's thread HERE, the forward one of the two (coded blue with 2 white stripes) can be identified as the breathing oxygen fill port. What is the red coded port just aft of it? Thanks, D Link to comment Share on other sites More sharing options...
PietvWdV Posted April 6, 2006 Share Posted April 6, 2006 It's an 24 Volt electrical Port. That's all I know. What excactly was done with someone can hopefully come tell us. Link to comment Share on other sites More sharing options...
stevegallacci Posted April 6, 2006 Share Posted April 6, 2006 The port is a tiny spring-loaded hatch with a socket inside for external electrical power. If you are desperate, I can try to find a very close close up of one I photographed. Link to comment Share on other sites More sharing options...
LSP_Matt Posted April 7, 2006 Share Posted April 7, 2006 no probs Steve, this is from the G14 walkaround on Hyperscale. I stared and stared and stared at this plane when I saw it in the Treloar centre in Canberra War Memorial....homer drooling. Link to comment Share on other sites More sharing options...
D Bellis Posted April 7, 2006 Author Share Posted April 7, 2006 Thanks fellas! The primary reason for asking is because I wasn't sure if it needed to be on the starboard fuselage of my '109Z. Since it is safe to assume the port fuselage (with cockpit) would serve as the "master", then the starboard fuselage's breathing oxygen and electrical ports can be left unmarked. Now I can get on with the decalling... Thanks again! D Link to comment Share on other sites More sharing options...
