For 0.4 brass tube with an internal diameter of 0.22.
Ideal for small scale rigging and control line rigging in 1/32.
Fine elastic will go through once, while light fishing line (as shown) will go through twice.
Available on my website @ https://www.bobsbuckles.co.uk/order.html
Cheers for looking.
Von Micro Nut! ;) :blink:
:m0152:
Great stuff Bob, Ive been meaning to pick up some of that super light duty stuff.................Although, I've actually gotten elastic to go through your cut tubes twice Bob!   I just had to dip the end in ultra thin CA to get it to thread through.
Hello Brian,
 You may of got the elastic to go through 0.5mm tube twice, but I doubt (unless you're some kind of rigging God) you will double back through 0.4mm tube. I've tried! :blink:
Hence the reason I went with fine fishing line. :yahoo:
Which elastic do you use?
Cheers,
The Blind Buckle Man :beer:
Ive managed to get both the fine EZ Line (with a bit more trouble) twice through your .5 tubes as well as the Ushi standard and fine. The EZ Line can be a bit problematic and takes a deft hand for sure.  No way to do it without thin CA first however...............otherwise its like trying to push cooked spaghetti around!
