daveculp Posted November 7, 2019 Share Posted November 7, 2019 I'm waiting for a primer coat to dry, so far about 8 days, and it's still tacky. I used "Rust-oleum Professional Primer", which is made for enamel top coat. In order to prevent this from happening again I need to figure out where I went wrong. The object I sprayed is made of resin. Here are some possibilities: 1) I didn't shake the can enough 2) I applied too thick of a coat 3) The part had a oil film, or something, on it Can you think of any more possibilities? Which mistake is most likely? Thanks, Dave Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 8, 2019 Share Posted November 8, 2019 I had exactly this same problem with Rust-oleum Flat Grey Primer, and eventually just overcoated it with Mr. Surfacer. All was fine after that. I believe this is a common problem with this brand's products, so I doubt you did anything wrong. Kev daveculp 1 Link to comment Share on other sites More sharing options...
1to1scale Posted November 8, 2019 Share Posted November 8, 2019 It’s possible that a chemical in the primer reactivated the resin, I had resin wheels react with acetone once, they went sticky, and never dried out. chrish and daveculp 2 Link to comment Share on other sites More sharing options...
